0-100 en 3'' y consume 0 litros, lo titulan "el coche que podría salvar el planeta"
Tema en 'Foro General BMW' iniciado por Furius, 8 May 2006.
Estado del tema:
  1. Strap
    Strap
    6 Abr 2002
    Forense
    El "otro" ARIEL ATOM
    jodo petaca, ELECTRICO, con baterias pero fijaros en los números....flipante
    [FONT=Verdana, Arial, Helvetica, sans-serif]X1 Prototype Specs[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] 3-phase AC induction motor, 236hp at the motor shaft[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] 182 ft lbs torque at the motor shaft, from 0 rpm to 6,000 rpm[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] 13,300 rpm rev limit[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] weight 1,500 lbs[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] no clutch, single gear ratio 8.35:1[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Quaife limited slip differential[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Alcon front calipers, 4 piston[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Dymag Magnesium Alloy wheels[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] inboard Bilstein race dampers, Eibach 2-stage springs[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] steering: rack and pinion, 1.5 turns lock-lock[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Lithium Ion battery pack[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Performance[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] 0-60 ~ 3.0 seconds[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Standing quarter mile ~11.5 seconds[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Top speed 112mph (electronically limited)[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Range >100 miles in urban use [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Charger: onboard conductive. Input 100-250V 50 or 60 Hz. Current: user adjustable up to 80A [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] Energy consumption 200 WHr/mile in urban use, equivalent to 170 mpg (33,705 WHr/gallon) [/FONT]
  2. Rellik
    Rellik Forista Senior
    15 May 2003
    Barcelona
    jose, lo tienes un poco mas abajo :D
    increibles tiempos ciertos,pero falta para que pueda ser una referencia fiable del avance ecologico.
  3. guakarimaso
    guakarimaso Clan Leader
    3 Oct 2002
    Oviedo-Asturias
    530IA touring
  4. Strap
    Strap
    6 Abr 2002
    Forense
    Oño sorry :fs: :fs: :fs:
  5. Gorki
    Gorki Forista Legendario
    27 Abr 2004
    Donosti,paraiso natural!
    Estoooo...y si llueve que? :)
  6. little_homer
    little_homer Guest
    como que sorry , creo que como mínimo mereces un baneo... :)
  7. guakarimaso
    3 Oct 2002
    Oviedo-Asturias
    530IA touring
    le perdonamos si nos cede algun kit de esos que le regala AMG:descojon::descojon::descojon::descojon:
  8. Strap
    Strap
    6 Abr 2002
    Forense
    tu aún no tienes edad para geriatrico cha____val :descojon: :descojon:
  9. guakarimaso
    3 Oct 2002
    Oviedo-Asturias
    530IA touring
    entonces TU???? yogurin:descojon::descojon::descojon::descojon:
  10. Strap
    Strap
    6 Abr 2002
    Forense
    :descojon: :descojon: :descojon: :descojon:
  11. little_homer
    little_homer Guest
    hablando de edades.. Strapp tu edad siempre es 39 ? :D O hay truco por ser el AMO? :descojon:
  12. Strap
    Strap
    6 Abr 2002
    Forense
    que c**o siempre 39....este mes da el salto :roll: :roll: :roll: :roll:
  13. guakarimaso
    3 Oct 2002
    Oviedo-Asturias
    530IA touring
    el tiempo derrr taco va mas despacio:descojon::descojon::descojon::descojon::descojon::descojon::descojon:
  14. little_homer
    little_homer Guest
    Ahi queria llegar yo... a que te invitas ? :descojon:
  15. supercanedas
    supercanedas I have gambas I have chopitos... Moderador Miembro del Club
    9 Feb 2004
    Goteborg
    987/ TUONO V4
    jejeje tu siempre buscando invitaciones:)
  16. Gavira
    (∀ꟽ) sn̗uɐꓭ oʇɹǝnԀ
    [​IMG]:)
  17. little_homer
    little_homer Guest
    La cabra siempre tira para el monte..
    Pero en tu caso rey... era para que tu pasión ciega por el Madrid te hiciera apostar.. i entonces seria cornudo y apaleado, el barça campeón de europa y tu pagando la cena :descojon: :descojon:
  18. supercanedas
    9 Feb 2004
    Goteborg
    987/ TUONO V4
    jeje,esa apuesta sigue en pie,no te preocupes que ya tengo el dinero ahorrado ...desgraciadamente:-s :descojon:
    un saludo!
  19. Pepo79
    Pepo79 Forista
    2 Feb 2005
    Madrid-Badajó
    q maravilla!! ojala prosperen propuestas de este tipo?? os imaginais un M3 electrico?
  20. jmborja
    26 Ene 2002
    Centro "geodésico" de España.
    M57 + S54 = 527
    Cuidado con ciertos comentarios,
    empiezo a estar jodido de la próstata, que ya son 99 años
  21. TRIAL_BCN
    TRIAL_BCN Forista Senior
    29 Nov 2005
    Penedès (BCN)
    Mira que es fácil. Se hacen las carreteras con unos cuantos canalillos y todos con coches scalextric.
    Luego está la opción autochoque. Se pone una redecilla en las autopistas y los coches con pértiga.
    Luego una nuclear con dos Pelayos y a hacer kms. a 1 € a los 100. :D
  22. PeRTxoN
    PeRTxoN Forista
    29 Ago 2007
    Gipuzkoa
    M POWER tu avatar es un descojono jajajja
  23. Gulf627
    Gulf627 Clan Leader
    14 May 2005
    Europa
    E86/S54-F20/B58
    Salvara el planeta si saben como producir la electricidad que consume, y si saben como hace baterias de manera no costosa para el medio ambiente.....
    Si es que los de marketing venderian a su madre
  24. QTPTN
    QTPTN Forista Legendario
    30 Abr 2005
    L'Eliana (Valencia)
    320D - 318is
    c**o, como me suena esto a lo que está pasando hoy dia. y este post ya tiene un tiempo. #-o
  25. M@X
    M@X Forista Legendario
    17 Ago 2006
    Girona
    EVO 9 TypeR E61
    el problema es el cable de conexión desde casa para darle autonomía que se enreda por el camino :descojon::descojon:
  26. Caifás
    Caifás Forista Legendario
    13 Abr 2005
    No me creo, que el toledo éste :descojon: coja 160 km/h en 1 segundo.... Como si tendría 2.000 cv y tracción en las 8 ruedas y también en la de repuesto...
  27. M@X
    17 Ago 2006
    Girona
    EVO 9 TypeR E61
  28. poderosobmw
    poderosobmw Forista Legendario
    9 May 2007
    NOROESTE
    E30/E39/RX7/GSI
    esto seria la solucion a todos nuestros problemas.
  29. AFG19
    AFG19 Forista Legendario
    15 May 2004
    Eso da igual....
    Tenemos un foro lleno de pescadores que rescatan post del 2006 :descojon: :descojon: :descojon:
  30. Zipper
    Zipper Forista
    18 Oct 2007
    Barcelona
    weno a mi me gusta el mini bolido jajaj solo falla el sonido... hecharia de menos el de la gasolina
Estado del tema:
