Acrónimos de BMW
Tema en 'Foro General BMW' iniciado por GroovyDrifter, 3 May 2007.
  1. GroovyDrifter
    GroovyDrifter Atento oyente Miembro del Club
    10 Ago 2006
    Depende.
    NX-01
    Pues eso, para que cuando alguien diga que si te afeitan los kilometros se pueden leer los km de verdad en el LCM, nadie bizquee y ponga caras raras, porque se viene a este post u otro similar y rapidamente descubre que se trata del modulo de control de luces :wink:
    A - processed vehicle speed signal
    A - "out" (Aus)
    AB - Airbag
    ABL - Brake system warning Lamp (2 color)
    ABS - Anti-lock Braking System
    AC - Air Conditioning (from ETK)
    ACC - Active Cruise Control
    ACS - Active Comfort Seats
    ADB(X) - Automatic Differential Braking
    ADS - engine intake air control
    ADV - windshield wiper pressure control
    AEGS - Automatic Electronic Gearbox Control (also EGS)
    AFM - Air Flow Meter
    AGD - suction silencer (from ETK)
    AGR - emission reduction
    AGS - Adaptive transmission control
    AG - Automatic Gearbox (transmission)
    AHK - Active rear-axle Kinematics
    AHK - trailer hitch (from ETK)
    AHM - trailer Module (not for US models)
    AHPS - Advanced HPS
    AIC - Automatic Interval Control (rain sensor)
    AKF - activated carbon canister (from ETK)
    AKS - Active head restraint
    AKS - pressure regulating device (from ETK)
    ALC - Automatic Light Control
    ALR - Automatic Lamp Range Adjustment
    AMM - Air Mass Meter
    AMP - radio system AMPlifier
    ARI - car radio information system (from ETK)
    ARS - Active Roll Stabilization
    ASC - All Season traction
    ASC-EZA - ASC w/ engine timing and injection intervention
    ASC+T - ASC+ Traction control
    ASK - Audio System controller (Kontroller)
    ASR - self starter block relay (from ETK)
    AST - Automatic Slip control (marketing term)
    AT - remanufactured part (from ETK)
    AT - Antenna (from ETK)
    ATF - Automatic Transmission Fluid (from ETK)
    ATL - exhaust gas turbo charger (from ETK)
    AUC - Automatic air recirculation
    AUT - AUTomatic transmission (from ETK)
    AVT - Antenna amplifier Tuner
    AZD - tightening torque specifications (in TIS)
    A/D – Analog/Digital
    B - Benzene (gasoline)
    BAT - BATtery (from ETK)
    BC - Board Computer
    BC1 - Body Controller 1
    BL - Brake Light (from ETK)
    BLS - Brake Light Switch
    BMBT - Board Monitor
    BS - Block diagram
    BST - Battery Safety Terminal
    BVA - Brake pad wear indicator (from ETK)
    BZM - center console control center
    BZMF - center console control center, rear
    CAN – Controller Area Network (Multiple ECU Controller)
    CAN-Bus - Controller Area Network (bus)
    CANH-Bus - CAN bus, High
    CANL-Bus - CAN bus, Low
    CANP - fuel tank ventilation valve
    CAS - Car Access System
    CBC - Corner Braking Control
    CBS - Condition Based Service
    CCM - Check Control Module
    CD - Control Display
    CDC - Compact Disk Changer
    CDS - CD player (from ETK)
    CEL - CELsius (from ETK)
    CIM - Chassis Integration Module
    CO - Carbon monOxide (from ETK)
    COMBI – Electronic Instrument Cluster
    CON - CONtroller
    CU - Copper (from ETK)
    CVM - Convertible top Module
    CVT - Constantly Variable Transmission
    CW - drag coefficient (from ETK)
    D1 - Xenon light/ gas discharge (from ETK)
    D-Bus - Diagnosis bus (same as TXD)
    DBC - Dynamic Brake Control
    DBS - Dynamic Braking System
    DCS - Dealer Communication System
    DE – Diagnostic Unit
    DD - Dynamic motor Drive
    DDE - Digital Diesel Electronics
    DIN - German industrial standards
    DIS - Diagnosis and Information System
    DISA - Differential air intake control
    DIVA - continuously variable length intake runners
    DK - throttle housing/valve
    DKB - throttle w/ brake intervention
    DKE – Throttle Increase
    DKI - throttle position
    DKR - throttle reduction
    DKT - throttle position signal
    DKV - preset throttle position value
    DME - Digital Motor Electronics
    DM-TL - Diagnostic Module Tank Leakage
    DOHC - Double Over Head Camshafts (from ETK)
    DS - gasket set (from ETK)
    DSC - Dynamic Stability Control
    DSP - Digital Sound Processing
    DTC - Diagnostic Trouble Code (SAE)
    DTC - Dynamic Traction Control
    DWA - theft deterrent system
    DWS - tire pressure Warning System
    DZM - revolution counter (from ETK)
    E - "in" (Ein)
    EBA - installation instructions (from ETK)
    EBV - Electronic Brake force proportioning
    ECE - European market version (from ETK)
    ECM - Engine Control Module (SAE term)
    ECU - Electronic Control Unit
    EDC - Electronic Damper Control (from ETK)
    EDR - Electronic throttle control
    E-KAT - Electrically heated catalytic converter
    EZA - see ASC-EZA
    ECO - Controller for I-Drive system
    EDC - Electronic Dampening Control
    EDC-K - Electronic Dampening Control - Continuous
    EDK - Electronic throttle valve
    EDS - pressure regulator
    EFH - Electric window lifter (from ETK)
    EGS - Electronic transmission control
    EH - Electronic-Hydraulic
    EHC - Electronic Height Control
    EKM - Electronic body Module
    EKP - Electric fuel Pump
    ELV - Electronic steering lock
    EM - Electro-Mechanical
    EMF - Electro-Mechanical parking brake
    EML - Electronic Motor Load regulation
    EMV - Electro-Magnetic sensitivity (from ETK)
    EO - component location
    EPC - Electronic Parts Catalog (also ETK)
    EPROM - Erasable/ Programmable chip Memory (from ETK)
    ETK - Electronic parts catalog (also EPC)
    ETM - Electrical Troubleshooting Manual
    ESS - Electronic anti-theft device
    EV - injection Valve
    EWS - Electronic drive-away protection
    FB - Function description
    FBC - Fading Brake Control
    FBD - remote control services
    FBZV - radio frequency locking system
    FGR – Vehicle Speed Control (Cruise Control)
    FH - window lifter
    FHK - rear Heater/ air conditioner
    FLC - automatic Light Control
    FRU - Flat Rate Unit
    FS – Crash Sensor
    FZV - central lock receiver
    GAL - speed dependent sound volume
    GM - General Module
    GMR - yaw moment control
    GPS - Global Positioning System
    GRII - cruise control
    GRS - rotation Rate Sensor
    GS – Belt Tensioner
    GWK - torque converter lock-up control
    H - "rear" (Hinten)
    H2 - Xenon headlights
    HA - rear Axle (from ETK)
    HC – Hydro Carbon
    HD - Heavy Duty (from ETK)
    HDC - Hill Decent Control
    HFM - Hot Film air mass Meter
    HG - manual Gearbox (transmission)
    HKL - Hydraulic trunk lid Lift
    HLM – Hot Wire Air Mass Meter
    HPS - Head Protection System
    HR - Heater control (from ETK)
    HVA - Hydraulic Valve Adjuster (from ETK)
    Hz – Hertz (Cycle)
    I-Bus - Information bus
    IB - Interior lighting control signal
    IHKA - automatic Heating and A/C
    IHKAF - IHKA w/ micro filter
    IHKR - regulated Heating and A/C
    IHKRF - IHKR w/ micro filter
    IHKS - standard Heating and A/C
    IHPD - Internal High Pressure Deformation
    IHR - Integrated Heater control (from ETK)
    IKE - Instrument cluster Electronics
    ILH - Interior Lighting, rear
    ILV - Interior Lighting, front
    IMS - Instant Mobility System (from ETK)
    IR – Infrared
    IRS – Infrared Locking System
    ISC – Idle Speed Control
    ISIS - Intelligent Safety Integration System
    ISN - Individual Serial Number
    ISOFIX - standardized mounts for child restraints
    ITS - head airbag assembly/ Inflatable Tubular Structure
    IVM - Integrated power supply Module
    K-Bus - body bus (Karosserie)
    KAT - catalytic converter
    KATON - converter creating (signal)
    KD - Kick-Down
    KHI - interface for headphones
    KL - terminal designation
    KL15 - run bus (ignition switch run position)
    KL30 - battery bus (hot at all times)
    KL31 - ground bus (chassis ground)
    KL50 - start bus (ignition start position)
    KLR - accessory bus
    KO - compressor "on" signal
    KOMBI - instrument cluster
    KOREL - compressor relay signal
    KR – Contact Ring
    KSK - Knock Sensor
    KVA - fuel consumption signal/value
    KW - crankshaft
    KW - KiloWatt (from ETK)
    LCM - Lamp Check Module
    LDP - Leak Diagnosis Pump
    LEV - Low Emissions Vehicle
    LEW - Lateral acceleration sensor
    LHD - Left-Hand Drive (from ETK)
    LKM - Lamp control Module
    LL - closed throttle
    LM - Light Module
    LMM - air flow meter/sensor
    LMR - Light alloy wheel
    LRA - vertical headlight aiming
    LSM - steering column memory
    LSZ - Lamp Switching center
    LVA - air supply system (for EHC system)
    LWR - vertical headlight aim control
    LWS-5 - steering angle sensor
    M-Bus - IHKA/IHKR stepper motor bus
    MAL - center armrest
    MBC - Maximum Brake Control
    MDK - Motorized throttle valve/system
    MFL - Multi-Function steering wheel
    MFC - Multi-Function Controller
    MFU - Multi-Function Clock
    MID - Multi-Information Display
    MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp
    MIR - Multi-Information Radio
    MMC - Multi-Media Changer
    MoDiC - Mobile Diagnostic Computer
    MOST-Bus - Media Oriented System Transport bus
    MRS - Multiple Restraint System
    MSR - engine drag torque Regulation
    MV - Magnetic Valve (solenoid Valve)
    n-ab - rotational speed, transmission (rpm)
    n-mot - rotational speed, engine (rpm)
    NAVI - Navigation module
    NG - New Generation (as in N73 engine)
    NG - tilt sensor
    NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
    NSD - rear muffler (from ETK)
    NSL - rear fog Lamp (from ETK)
    NSW - fog lamp (from ETK)
    NTC - Negative Temperature Coefficient
    NW - camshaft (from ETK)
    OBC - On-Board Computer
    OBD - On-Board Diagnosis (SAE)
    P/N – Park/Neutral position
    P-Bus - Periphery bus
    PB - Pin assignments
    PBS - Parts Bulletin System (in TIS)
    PDC - Park Distance Control
    PGS - Passive Go System
    PM - Power Module
    PP – Impact Pad
    PTC - Positive Temperature Coefficient
    RLS - Rain-Light Sensor
    PWG - Pedal position sensor/ potentiometer
    RA - Repair instructions (in TIS)
    RAM – Random Access Memory
    RAL - Aluminum wheels (from ETK)
    RAL - standard color (from ETK)
    RDC - tire pressure Control
    RDS - Radio Data-broadcast System
    RDW - tire pressure Warning
    RHD - Right-Hand Drive (from ETK)
    RM - Relay Module
    ROZ - Research Octane rating/ fuel grade (from ETK)
    RPA - tire puncture warning (from ETK)
    RPS - Rollover Protection System
    RS - Repair kit (from ETK)
    RSW - back-up lamp (from ETK)
    RXD - wake-up Diagnosis line
    RZV - direct stationary ignition
    SASL - Satellite, A-pillar left
    SASR - Satellite, A-pillar right
    SAV - Sport ACTIVITY Vehicle
    SB - fuse assignments
    SBE - Seat occupancy detector/sensor
    SBFH - Seat module, passenger-side rear
    SBSL - Satellite, B-pillar left
    SBSR - Satellite, B-pillar right
    SBT - SI techniques/ tech reference information (in TIS)
    SCA - Soft Close Automatic/Actuator
    SD - sliding roof (from ETK)
    SD - silencer/ muffler (from ETK)
    SE - Special Equipment (from ETK)
    SES - voice recognition System
    SFAH - Seat module, driver's side rear
    SFZ - Satellite, vehicle center
    SG - control unit
    SGS - Seat integrated belt System
    SHD - sliding/ lifting roof (from ETK)
    SHD - Sunroof module (also SHDM)
    SI - Service Information (in TIS)
    SIA - Service Interval system (ver. I, II, III, IV, etc.)
    SII - Service Interval Indicator
    SIL - SILicon (from ETK)
    SIM - Safety Information Module
    SINE - Siren/tilt sensor
    SKD - Steel sliding roof (from ETK)
    SKHD - Steel sliding/ lifting roof (from ETK)
    SM - Seat Module
    SM/SPM - Seat/Mirror Memory
    SMBF - Seat Module, passenger side
    SMFA - Seat Module, driver's side
    SMG - Sequential Manual Gearbox
    SP - Schematic
    SRA - headlight/fog light cleaning
    SRS - Supplementary Restraint System
    SSD - Steel sliding roof (from ETK)
    SSH - Seat Satellite, rear seat
    ST - connector views
    Steptronic - transmission shift control
    STVL - Satellite, left front door
    STVR - Satellite, right front door
    SVS - Speech processing System
    SWR - headlamp cleaning system (from ETK)
    SWZ - Special tool listings (in TIS)
    SZL - Switch center, steering column
    SZM - central switch center Module
    TAGE - door handle Electronics
    TCM - Transmission Control Module
    TD - engine speed signal (ignition pulse)
    TD - Technical Data (in TIS)
    TE - fuel evaporation control
    TEL - TELephone control unit
    TEV - evaporative purge control
    THZ - Tandem master cylinder (from ETK)
    ti - Injector "on" Time (duration)
    TIS - Technical Information System
    TL - part throttle / load signal
    TLEV - Transitional Low Emission Vehicle
    TMBFT - door Module, passenger side
    TMBFTH - door Module, passenger side rear
    TMFAT - door Module, driver's side
    TMFATH - door Module, driver's side rear
    TP - Tandem Pump (from ETK)
    TPS - Throttle Position Switch/Sensor
    TR - engine speed signal (rpm)
    TR - TRansistor (from ETK)
    TRG - fuel level sensor (from ETK)
    TRI - Technical Reference Information (also SBT)
    TRS - battery isolation Switch
    TSD - Torsional vibration dampener (from ETK)
    TSH - door lock Heating
    TSZI - Transistorized coil Ignition system (from ETK)
    TU - Technical Update (as in M50tu)
    TXD - Transmitting Diagnosis line
    U-batt - Battery voltage
    U-vers - supply voltage
    UERSS - rollover bar (from ETK)
    URS - rollover protection System
    USIS - Ultrasonic passenger compartment Sensor
    V - "front" (Vorn)
    V - vehicle road speed
    VA - front Axle (from ETK)
    VAT - front axle support (from ETK)
    VANOS - Variable camshaft timing
    VEP - distributor-type injection Pump (from ETK)
    VID - VIDeo module
    VL - full load (wide open throttle)
    VSD - front muffler (from ETK)
    VVT – Valve tronic
    WBG - hazard warning switch (from ETK)
    WIM - Wiper control Module
    WK - torque converter lock-up clutch
    WSS – Wind Shield (from ETK)
    WT – Valve tronic control unit
    Z - "central" (Zentrum)
    ZAB - ignition fade-out (reduction)
    ZAE - central Airbag Electronics
    ZAS - ignition starter switch (from ETK)
    ZGM - central Gateway Module
    ZK - cylinder head (from ETK)
    ZKE - central body Electronics
    ZKH - cylinder head cover (from ETK)
    ZMS - dual-Mass flywheel (from ETK)
    ZV - central locking system
    ZS - central lock (from ETK)
    ZSD - center muffler (from ETK)
    ZV - central locking system (from ETK)
    ZVM - central locking Module
    ZWD - idle control valve
    Fuente: http://www.mbmw.com/bmw_technical_acronyms.htm
  2. Eric Lar
    Eric Lar Forista Senior
    5 Ago 2005
    Reyno de Navarra
    Muy bueno Groovy. Sería bueno ponerlo en el archivo fijo.
  3. cromex77
    cromex77 Baneado Baneado
    20 Dic 2005
    no mandar MP
    esto lo has sacado con el aparatito de marras?
  4. PinkPanther
    PinkPanther Forista
    25 Ago 2004
    Barcelona
    Muchas gracias, es bastante útil. Voto por chincheta.
  5. blaki
    22 Ene 2007
    Curva de Gauss
    340 DIESEL
    chincheta ya
  6. Cris
    Cris Clan Leader
    22 Jul 2005
    cerca muy cerca...
    ///M3 ///M330 ci
    chincheta y traduccion jejejej genial trabajo gracias tio.
  7. DaviGarcia
    DaviGarcia Forista
    26 Dic 2006
    pontevedra
    pedazo de receta,interesante
  8. Plankton
    Plankton Forista Legendario
    1 Jun 2005
    paraiso
    mi no entender :(
  9. aquiles
    aquiles Forista Senior
    29 Mar 2007
    Valladolid
    sin BMW
    :wink: Gracias por la info.paz.
  10. Devil 320
    Devil 320 Forista
    17 Oct 2005
    Burgox
    Otro igual que yo :LOL: , que es lo que hay que hacer con eso? :embarrassed: :err:
    Salu2
  11. cromex77
    20 Dic 2005
    no mandar MP
    chichetísimaaaa
  12. jrubio
    jrubio Forista Legendario
    30 May 2005
    no entiendo na de na!
  13. 120De_miedo!
    120De_miedo! Forista Senior
    29 Jun 2005
    Baskeland
    X1 20i mhev U11
    por favor una explicación previa que lo del LCM luces y afeitar kilometors no ha quedado claro.
  14. lucas-e90
    lucas-e90 Forista
    21 Ago 2006
    Lorca - Murcia
    Un poco de ayuda porfa....
  15. CAMIRA
    CAMIRA Forista Senior
    24 Jun 2004
    Ahora aprendetelo como el Padre Nuestro :LOL::LOL:
    Gracias
  16. leij
    leij Forista Legendario
    9 Abr 2004
    A Pobra do Caramiñal
    Nissan Xtrail
    Ahi falta el H2O :rolleyes: :LOL: ¿no? esperaremos a que entre Guaka y nos los exlique, que para eso es profe de química :rolleyes: :wink: :LOL: :LOL: :LOL: :LOL: Es una coña marinera ¿eh?
  17. GroovyDrifter
    10 Ago 2006
    Depende.
    NX-01
    Aveee....
    acrónimo.
    (Del gr. ἄκρος, extremo, y -ónimo).
    1. m. Tipo de sigla que se pronuncia como una palabra; p. ej., o(bjeto) v(olante) n(o) i(dentificado).
    2. m. Vocablo formado por la unión de elementos de dos o más palabras, constituido por el principio de la primera y el final de la última, p. ej., ofi(cina infor)mática, o, frecuentemente, por otras combinaciones, p. ej., so(und) n(avigation) a(nd) r(anging), Ban(co) es(pañol) (de) (crédi)to.
    :rolleyes:
    Extrictamente hablando, esto más que acrónimos son siglas. El problema es que las siglas o acronimos que BMW usa proviene de palabras inglesas o alemanas (mas que nada) y resulta un poco complicado saber por las siglas a que se refieren en ciertos manuales y documentaciones.
    A mi por ejemplo me salio con un prog. de diagnóstico que tenia una alarma en el HKL, y despues de consultar esta lista me di cuenta de que no tengo HKL asi que no me tengo que preocupar. Porque HKL es la tapa del maletero hidráulica, y la mia es manual con cerradura electrica.
    Pero si te sueltan que tienes una alarma en el HKL te quedas mirandole con cara de "¿me estará insultando?"
    Por ejemplo el DDE es el modulo que gestiona el motor de gasoil, DME el de gasolina, ambos dos son una ECU.
    Hay muchos manuales tecnicos que dan estas siglas por sabidas y no las "decodifican", asi que creo que esto puede ser util para que los novatos nos vayamos enterando.
    Por otro lado:
    afeitar.
    (Del arag. o leon. afeitar, y este del lat. affectāre, arreglar).
    1. tr. Raer con navaja, cuchilla o máquina la barba o el bigote, y, por ext., el pelo de cualquier parte del cuerpo. U. t. c. prnl.
    2. tr. Esquilar a una caballería las crines y las puntas de la cola.
    3. tr. Recortar e igualar las ramas y hojas de una planta de jardín.
    4. tr. Adornar, componer, hermosear. U. t. c. prnl.
    5. tr. Taurom. Cortar o limar la punta de los cuernos al toro para que su lidia resulte menos peligrosa.
    6. tr. desus. Componer o hermosear con afeites el rostro u otra parte del cuerpo. Era u. t. c. prnl.
    7. tr. desus. Guiar, instruir, enseñar.
    Por lo tanto afeitar los kilometros del coche es... pues justo lo que parece, recortarlos, hermosearlos, arreglarlos, vamos, QUITARLE KILOMETROS. Esto es mas o menos complicado dependiendo del modelo de coche, en el E38 se ve que es muy sencillo, pero el coche es un señor alcahuete y guarda una copia del kilometraje correcto en el modulo de luces o LCM, ese que da alrama cuando pones leds o xenon en vez de bombillas y que te tiene que recodificar el conce para solucionarlo.
    No os mosqueeis, lo de las definiciones es para dejar las cosa claras, no va de coña con nadie.
  18. webcom
    webcom Forista
    21 May 2006
    Don Benito (Badajoz)
    Buenisima aportación muchas gracias
  19. NaCl
    NaCl Forista Senior
    17 Abr 2006
    CAI
    E46 320D
    Muy bueno :biggrin:
  20. E36Technik
    E36Technik Forista Legendario
    16 Jul 2005
    Madrid.
    me trae buenos recuerdos, ya q me pase casi un dia buscando esto.
  21. alghiem
    alghiem Guest
    Idem. Son muchos
  22. 328II
    328II En Practicas
    17 Sep 2007
    hola
    alguien sabe que fallos son estos
    DME/DDE
    DME MS42.0
    bmw part Nr. :7500255
    Hardware Nr :00
    Software Nr :E3
    Diagnose Nr :60
    Code index :00
    Bus index :Co
    Producion Date 20/99
    DME41_FE.DXT
    57 golpes el sensor:bac1
    cilinder 1,2,3
    posible error
    corto circuito en la tierra o en circuito abiero
    corto circuito en a batt +
    señal del sensor incorrecto
    57 golpee el sensor bac1
    cilinder 4,5,6
    posible error
    corto circuito en la tierra o en circuito abierto
    8 caliente pelicula masa de aire
    abieroto o cortocircuito en la masa de aire del sensor de flujo
    masa de aire y los cables del sensor de flujo
    suministro de enenrgia en el aire navidad sensor de flujo
    mi coche es un bmw 328I E46 de año 99 sabe algien cual pude ser la averia.
    saludos
  23. GroovyDrifter
    10 Ago 2006
    Depende.
    NX-01
    Pues vaya con las traducciones churriguerescas... Parece una alarma de caudalímetro... y de cortocircuitos... a saber.
  24. Mario525
    Mario525 Forista Legendario Moderador Miembro del Club
    10 Abr 2004
    Argentina
    Serie 3 G20
    Buena info: Gracias!!
  25. Jairo_Luis
    Jairo_Luis Guest
    Me falta Bayerische, pero bueno gracias
  26. GroovyDrifter
    10 Ago 2006
    Depende.
    NX-01
    Co.o es verdad... no esta BMW Bayerische Motoren Werke:descojon:
