Escucha La Sinfonía del E92 M3 & Caracteristicas Motor
Tema en 'Serie 3 (E90/E91/E92/E93) (2005 - 2011)' iniciado por Carlos318, 26 Mar 2007.
  1. Carlos
    Carlos Clan Leader
    20 Jul 2005
    Por los Mares
    NEW M3 V8: LISTEN TO IT HERE
    PH obtains exclusive sound files!
    The new V8
    The web is alive at the moment with technical details of the new M3 V8 engine, and we know many of you already have much of the details. If you don't, this is the full set of information released by BMW. To hear the engine being worked hard, click on the links below to hear what our man came back from BMW with...
    Sound file 1 (MP3) Test bed 0-200km/H
    Sound file 2 (MP3) Nurburgring
    The key details are:
    • 3999cc
    • 414bhp @ 8,300rpm
    • 295lb ft @ 3,900rpm (251lb ft available from 2,000rpm)
    • 8,400 max engine speed
    • Engine weighs 202kg – 15kg lighter than old ‘six’
    • Aluminium silicon alloy crankcase, iron-coated pistons run directly in the bores of hard silicon crystals
    • Bedplate structure
    • Crankshaft weighs 20kg – 5 main bearings
    • Oil cooled pistons
    • High-strength steel magnesium alloy connecting rods weighing 623g each
    • Single piece alloy cylinder heads with 4 valves per cylinder
    • Double Vanos variable camshaft control
    • Double chain-driven cams
    • Oil system works to 1.4G with 2 pumps
    • 8 individual throttle bodies. Accelerator pedal position monitored 200 times per second. Takes 120 milliseconds to reach maximum opening point.
    • No air mass sensor – ecu does the calculations from the range of data available to it
    • Two, 4-1 ‘fan type’ exhaust manifolds
    • 4 cats
    • MSS60 ecu – development of the one found in the V10 M engine. Three 32bit processors. Can handle more then 200 million individual operations per second.
    New M3 V8 engine specs
    FuelRON 98 (95)Max output bhp414 at 8,300rpmMax torque lb ft 295 at 3,900rpmMax engine speed8,400rpmStroke mm75.2Bore mm92.0Displacement cm33,999Distance between cylinders mm98Cylinder arrangement 8-cylinder V-engineValve plate diameter, intake mm35.0Valve plate diameter, outlet mm30.5Compression ratio 12.0:1Fuel injectionIntake pipe fuel injectionFuel injection pressure bar3–6Average combustion chamber pressure bar12.6Maximum combustion chamber pressure bar100Engine weight to BMW standard kg202Output per litre bhp/litre 103.5CrankcaseAluminiumValvetrain Infinite camshaft adjustment and hydraulic valve clearance adjustment for intake and outlet (double VANOS)
    :LOL: :LOL: :wink: ..q pasada!!!!!!!!!!
  2. Pepin
    Pepin Forista
    14 Mar 2006
    Spain
    Bmw X3 3.0d
    Oño Carliños, que acabas de llegar a currar
  3. JAVMAD
    JAVMAD Repartidor... Moderador Miembro del Club
    3 Oct 2005
    F60&T8-Plug&RS
    :err: :-({|= :-({|= :-({|= :rock: :rock: :rock: :LOL:
  4. Carlos
    Carlos Clan Leader
    20 Jul 2005
    Por los Mares
    me tienes controlado..:LOL: :LOL: :LOL: ....con el cambio de hora ...:err: :err: :err: me he dormido...:wink:
    mi mujer tiene más controles médicos q la "Leti"......:LOL: :LOL: :LOL: ..y hay q acompañarla...:wink:
  5. Carlos
    Carlos Clan Leader
    20 Jul 2005
    Por los Mares
    :LOL: :LOL: si si una mezcla entre sinfonía clásica y rock duro....:wink:
  6. HHM
    HHM Guest
    No os habreis equivocado??
    Yo creo que suena a "D".con centralita.jejejje
    Dios como suena el bicho.
  7. webcom
    webcom Forista
    21 May 2006
    Don Benito (Badajoz)
    Estoy babeando todavia..........
  8. 330coupediesel
    330coupediesel Clan Leader
    29 Mar 2006
    Gallaecia
    BMW y Kawasaki
    ese es el diesel!
  9. Carlos
    Carlos Clan Leader
    20 Jul 2005
    Por los Mares
    :LOL: :LOL: :LOL: :LOL: ...pues como suena para der Diesel....:wink:
  10. miguvid
    miguvid Forista
    28 Jul 2005
    Valladolid
    j*der pero quien c**o ha subido el sonido q grabé de mi coche?
  11. Carlos
    Carlos Clan Leader
    20 Jul 2005
    Por los Mares
    :LOL: :LOL: :LOL: :LOL: :LOL: .. he sido yo, soy un chico malo.....:LOL: :LOL: :LOL:
  12. 330coupediesel
    29 Mar 2006
    Gallaecia
    BMW y Kawasaki
    es que lo diesel de ahora!:axe::supz:(:P):rock:
  13. Pabloide
    Pabloide Forista Senior
    11 Oct 2006
    Ains... no me dejan escuchaaaaar... alguien que se lo haya descargado y me lo pueda mandar el MP3?
    pablosalas@bmwfaq.net
