fallo capota hidraulica
Tema en 'Serie 3 (E46) (1998-2007)' iniciado por victor aguilera, 23 Dic 2006.
  1. wenas se ha estropeado el sistema hidraulico de la capota, como puedo hacer pa descapotarlo manualmente?¿
    sds!!
  2. Potenza
    Potenza Forista
    30 Abr 2006
    Valencia
    Yo lamento n poder ayudarte,pero si de pasa Fer o algun otro entendido n tardarán en decirtelo,Q sea leve ese problemilla.
  3. gracias igualmente haver alguna solucion...
  4. 330mcabrio
    330mcabrio Guest
    mira en el manual de usuario, ahi venia una forma para quitarla. ahora mismo no me acuerdo de como era!
  5. no tengo el manual haver si alguien me hecha una mano..
  6. 330mcabrio
    330mcabrio Guest
    Open the convertible top
    Operate the convertible top only
    when the vehicle is stationary.
    With the luggage compartment lid
    open, you will not be able to unlock the
    convertible top compartment lid to
    avoid any possible damage.<
    1 Flip the locking handle out (see illustration),
    and turn it up to the end
    stop.
    2 Raise the convertible top slightly
    (release the tension).
    46cde064
    3 From ignition key position 1 on press
    the switch to unlock the convertible
    top. The convertible top unlocks and
    opens slightly. The side windows
    lower slightly.
    If the indicatior lamp comes on
    while the switch is pressed, the
    convertible top can not be released
    because the convertible top compartment
    panel is raised, refer to page 41.
    Fold down the convertible top compartment
    panel, and close the luggage
    compartment lid.
    4 Position the rear convertible top bow
    vertically and grip it firmly.
    You can support the rear convertible
    top bow while lifting it up by
    pressing the designated area (arrow).<
    46cde073
    5 Reach into the gap of the slightly
    opened convertible top compartment
    lid and open it all the way by
    hand (1).
    6 Lay the rear convertible top bow in
    the convertible top compartment (2).
    Release the rear convertible top
    bow before laying down the
    convertible top, otherwise the side trim
    panel could be damaged.<
    7 Lift the top up at the front and move it
    toward the rear.
    Push the convertible top
    completely into the convertible
    top compartment. This makes it easier
    to close the convertible top compartment
    lid, especially at lower temperatures.<
    46cde068
    8 Press down slightly on the convertible
    top compartment lid from above
    (arrow). The closing procedure will
    then be carried out automatically.
    9 Either close the slightly lowered side
    windows or move them into the
    desired position.
    compartment lid from above only
    in order to avoid pinching.
    If the convertible top compartment lid
    has not been closed properly, you will
    not be able to open the luggage
    compartment lid. This is to avoid any
    possible damage.
    Central locking will unlock automatically
    after the convertible top compartment
    lid has been closed, i.e., the
    luggage compartment lid is no longer
    locked and can be opened again.
    To avoid permanent damage from
    moisture, never store the convertible
    top when it is wet. Refer to the
    chapter "Care," starting on page 156).<
    Closing the convertible top.
    1 Put the ignition key in position 1.
    2 Press the switch to unlock it.
    The convertible top compartment lid
    will be unlocked and the side
    windows will lower slightly.
    3 Open the convertible top compartment
    lid completely by hand.
    4 Lift the convertible top out by the
    lateral guide section (1) and the front
    convertible top bow (2), swinging it
    forward until you encounter perceptible
    resistance.
    bow vertically only after the
    convertible top has been swung toward
    the front, otherwise the side trim panel
    could be damaged.<
    46cus037
    5 Either close the slightly lowered side
    desired position.
    6 Press down slightly on the convertible
    top compartment lid from above.
    The closing procedure will then be
    carried out automatically, refer to
    page 46.
    in order to avoid pinching.<
    After the convertible top compartment
    lid has been closed, the
    central locking system will unlock automatically,
    i.e. the luggage compartment
    lid is no longer locked and can be
    opened again.<
    7 Holding on to the locking handle, pull
    the front part of the convertible top
    frame up onto the windshield frame,
    and lock the convertible top by
    turning the handle until you hear the
    convertible top engage.
    The rear convertible top bow will automatically
    be pressed down onto the
    convertible top compartment lid and
    because of the tension, will close completely.
  7. fu el ingles no es mi fuerte y no lo entiendo muy bien..
  8. elcuadraodeljesus
    elcuadraodeljesus En Practicas
    18 Ago 2006
    CARTAGENA
