Ghost Rider
Tema en 'Foro General BMW' iniciado por Lilipuf, 8 Mar 2005.
  1. Lilipuf
    Lilipuf Forista
    28 Nov 2004
    cat
    Aqui tenéis un trailer de unas de sus pelis.
    http://speedfreaks.dahhosting.nl/gr/GR2_trailer1.mpg
    Las motos del loco.
    SUZUKI R1000 CARBON
    ENGINE:
    988cc
    Port & Gas Flow Cylinder Head
    Factory cylinderhead gasket
    Suzuki GSX-R600 K1 valve springs
    Yoshimura stage 2 cams with slotted cam Sprockets
    Yoshimura tri-oval full race system
    Factory fuel injection system
    Power comander PC3R
    Nicko G-pack
    Factory kit gearbox
    NRC engine covers
    power, 191hp on the back wheel
    BODY WORK:
    Carbon fuel tank
    Carbon Frameguards
    Carbon Rear Hugger - Vented
    Carbon Heelplates
    Carbon Exhaust Hanger
    Carbon chainguard
    EVO Undertray
    Carbon fairing
    Carbon race Seat
    Crash mushroms on the frame & front wheel
    CHASSI:
    Fully race prepared front forks by Wilbers
    Race reardamper, Wilbers
    Öhlins stearing damper
    NBM hydraulic steel brake lines in front and rear.
    Harris footrest kit with adjustable footpeg position.
    Race brake pads in front and rear
    ISR mastercylinder/front brake
    ISR clutch lever
    ISR brake discs in front and rear
    Harris clip-on
    ISR dual full floating 300mm discs in front
    ISR 220mm disc in rear
    PERFORMANCE:
    195 mph+
    SUZUKI HAYABUSA TURBO SPECIAL (500 cv!!!!)
    ENGINE:
    1298cc
    McXpress racing turbo kit with everything + much more & bigger
    JE low compression pistons
    Steel rods
    Johnson race crankshaft
    Kent cams, high performance camshafts
    Laminova watercooled oilcooler
    NBN hudraulic steel clutch line
    TTS gearbox with 15% higher speed on 6 gear
    Front sprocket, 17-19
    Rear sprocket, 32-38
    BODY:
    Fuel tank, GSX-R1000 K2
    Race seat, GSX-R1000 K2
    Rear light, GSX-R1000 K4
    Front light, Derbi senda
    Carbon front Mudguard, vented
    Carbon heelplates
    CHASSI:
    Special made frame by Andersson turbo system
    Öhlins special made front forks
    Öhlins rear damper
    Öhlins steering damper
    ISR dual 6-piston radial-mount calipers in front
    ISR 6-piston caliper in rear
    ISR dual full floating 320mm discs in front
    ISR 240mm disc in rear
    ISR radial master cylinder and lever
    ISR clutch lever
    Harris adjustable yokes triple bolt bottom fixing
    Renthal handlebar
    PVM forged magnesium 10-spoke wheel in Y-spoke design, front and back
    PERFORMANCE:
    Power, 499bhp on the back wheel
    Topspeed, enough even on one wheel
    Performance, 0-300km/h 9.1 second
    BMX SUPER SPECIAL
    ENGINE:
    Ghostrider
    Anabolic tuning
    0,37 BHP
    CHASSI:
    Really dangerous front brake
    A small rear brake
    Super soft front suspension
    Even softer rear suspension
    Ghostrider as a steering damper
    12kg dry weight
    PERFORMANCE:
    36 km/h (22,37mph)
  2. pLEy
    pLEy Clan Leader
    21 Ago 2002
    Ese tio esta como una cabra :D...a 320 km/h y levantado rueda con la Hayabusa en plena autovia, escapando a la policia una y otra vez, quemando goma delante de una comisaria, corriendo con una moto de nieve modificada por la ciudad, etc tc...increible....Tengo todos sus DVD's y merece la pena verlos todos.
    La escena en la que lo detienen con la bici es graciosa :)
  3. Lilipuf
    Lilipuf Forista
    28 Nov 2004
    cat
    Sólo he visto la segunda peli, ahora ha sacado la tercera pero no parece muy guapa...
    Muy cachondo cuando hacia "surf" encima de la moto. Impresionante cuando la R1 va a 300 a tope de revoluciones y la yahabusa turbo lo adelanta a una velocidad bestial, y muy gamberro cuando quemaba rueda con el culo de la moto pegado a una abuelita, jajajaja casi la ahoga con el humo jaja :descojon:
    Lo de la moto de nieve por en medio de la ciudad yo me meaba de la risa, el tio dando vueltas en medio de la carretera entre el tráfico y la peña mirando con una cara.... :descojon: :descojon: :descojon:
  4. leoper
    leoper Baneado Baneado
    5 Oct 2004
    Albacete
    Pues con los subarus tampoco van despacio....
  5. Lilipuf
    Lilipuf Forista
    28 Nov 2004
    cat
    es cierto que se mató el tio ese?
  6. aranda
    aranda Forista Senior
    18 Jun 2004
    valencia
    con tios así da miedo circular , igual te va a 300 en contra direccion y cosas así ... menuda gentuza ¡¡¡
  7. pLEy
    pLEy Clan Leader
    21 Ago 2002
    Pues es la primera noticia que tengo, que yo sepa no...de echo lo pondria en la web, no?
  8. Lilipuf
    Lilipuf Forista
    28 Nov 2004
    cat
    Pooooooooooooooooooo.... zi
  9. kako
    kako Forista
    22 Ago 2004
    Donde me dejan
    Esta colgao el tio
  10. Delauer
    Delauer Forista Legendario
    6 May 2004
    Bizkaia
    Yo también tengo el segundo, está loco!! Pero lo mejor es cuando va en mini-bici y le multan :descojon:
