M Coupe Racing: Us$ 18.000
Tema en 'BMW Serie Z (1987 - Presente)' iniciado por jashan, 25 Ene 2005.
  1. jashan
    jashan Forista Senior
    23 Abr 2003
    Vice City
    Si queréis ser los Reyes del Harama la próxima Jornada de Puertas Abiertas, aquí tenéis...
    UPGRADES TO ’99 MCOUPE AS ALLOWED
    PER SCCA GCR FOR T2 CLASS AND
    BMW CCA I STOCK CLASS
    BRAKES
    ü Full floating euro MSport rotors
    ü KFP – P42A performance pads (front)
    ü KFP – P4211 performance pads (rear)
    ü ATE blue racing brake fluid
    SUSPENSION
    ü Adjustable front sway bar (23mm)
    ü Adjustable rear sway bar (21mm)
    ü Pinned rear sway bar link rods
    ü Reinforced front and rear sway bar mounting plates
    ü Fixed front camber correction plates
    ü Reinforced front shock tower mounting area
    ü Adjustable front Koni sport shocks
    ü Adjustable rear Koni sport shocks
    ü Billet aluminum rear shock mounts with Delrin bushings
    ü Adjustable trailing arm bushings (to allow rear camber and toe adjustment)
    ü Dinan stage 2 sport springs (4)
    ü Competition 4 wheel alignment
    DRIVE TRAIN
    ü Synthetic Redline transmission fluid (MTL)
    ü Synthetic Redline differential fluid (75W90)
    ü ACS removed (intake restriction)
    ü Dinan 3.0 download
    ü Custom built catalytic converter back exhaust – Flow Master chamber extraction technology
    SAFTEY
    ü Custom 6-point roll cage with additional reinforcement bracing and forward crash bar – welded base plates gusseted into body for strength – entire cage removable via threaded/doweled secondary base plates (no holes drilled through body)
    ü Sparco seats (Evo-Black) with custom built mounting frames (driver’s seat on sliders for seating adjustment)
    ü 5-Point harnesses with welded base anchor plates
    ü Removable window ner
    ü Cage mounted removable hand operated 2 ½ lb fire bottle (Halon)
    MISCELLANEOUS
    ü Integrated transponder
    ü Lap timer (internally wired)
    ü Aluminum pedals.
    ü Cool Shirt System
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4521558801
  2. twenty
    twenty Guest
    Para ser el rey del Jarama, lo suyo es quitarle el tubo escape y un subwoffer MXOnda.....
  3. Seguro que también eres el rey del taller.
  4. CARLOSZ3
    CARLOSZ3 Clan Leader
    15 Abr 2004
    León
    Juasssssss, seria rey del Jarama pero solo de la tortillas.:descojon:
  5. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    c**o las estabilizadoras del mismo grosor que le voy a calzar yo jeje
  6. jashan
    23 Abr 2003
    Vice City
    El valerón que lleva atrás sirve también para las tortillasjarameras, al igual que el 928... eso hay que tenerlo en cuenta!!!!
  7. David,¿qué problema has tenido con las estabilizadoras? ¿se han salido?.
  8. jashan
    23 Abr 2003
    Vice City
    están como él... perdiditas...je, je
  9. Y para poner los vodka limón,tirar de chiquiwini etc etc,es muy polivalente el jalerón [​IMG][​IMG]
  10. jashan
    23 Abr 2003
    Vice City
    JUASSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
    Enyel, tas fatásssssss... me parto
    ya te podías haber bajado con el curri, granuha!!!
  11. [​IMG][​IMG],ya te digo.Hay que hacer quedada "Rober ¿dónde está el coche?" YA!!!!.....[​IMG][​IMG][​IMG].
  12. jashan
    23 Abr 2003
    Vice City
    :descojon:
    lo triste es que no fue la primera vez que me pasó... ni la última...
    vaya noche...
    El Sábado estuve con Michelob, que me empieza a hablar de esa noche en el Gabana, que estábamos juntos... y le digo, "pero si yo no estuve contigo"...
  13. [​IMG][​IMG],y dices que yo estoy mal....recuerdo perfectamente que fuimos con él y con Arturo a que pillara un taxi [​IMG][​IMG].Después al after nawer [​IMG]ese que estaba chapado......y luego ligamos y todo [​IMG][​IMG][​IMG]con unos amigos de Charly boy´ss [​IMG].
  14. jashan
    23 Abr 2003
    Vice City
    dime que todo eso es mentira (por lo menos lo último!, que el Domingo no noté escozor alguno)
    es peor de lo que pensaba...
  15. [​IMG][​IMG][​IMG][​IMG][​IMG],se podía cortar la tensión con tijeras [​IMG][​IMG].
  16. twenty
    twenty Guest
    Anda que joiossss que callado os lo teniais ¡¡¡¡¡¡¡
  17. jashan
    23 Abr 2003
    Vice City
    ja, jaaaaaa...
    ... 400 pulsaciones/min
  18. [​IMG][​IMG][​IMG]
  19. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    Norl, le voy a poner unas de más diámetro para quitar buena parte del balanceo ;)
  20. Buena idea,¿por cuánto salen?.
  21. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    Unos 550 €, el plan es no tocar muelles para no rebajarlo y no vaya pegando por doquier
    Para el tuyo también hay
    www.h-r.de
  22. jashan
    23 Abr 2003
    Vice City
    H&R... que maravilla!!! de lo mehorcito
    por fin vas a hasser algo a derechas, wonsh
  23. CARLOSZ3
    15 Abr 2004
    León
    Bueno, lo de la Becker tampoc estuvo mal, sobre todo por el precio.:rolleyes:
  24. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    Y cuando le meta la stage I vais a flipar juasjuasss
  25. jashan
    23 Abr 2003
    Vice City
    le tienes nombre???????????????
  26. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    ein? que le tengo nombre al que??
  27. jashan
    23 Abr 2003
    Vice City
    "cuando le meta la estajeuno"
    otros no le tenemos nombre!
  28. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    ah!
    es que soy un auténtico tuner yankee shaval
    La estajeguan será cañera y barata jeje
  29. CARLOSZ3
    15 Abr 2004
    León
    Que os pasa en la boca............juassssssssss
