Pantalla Motorizada Dvd Tdt....
Tema en 'Audio BMW' iniciado por SrMenDi, 23 Jul 2006.
  1. SrMenDi
    SrMenDi Forista Senior
    13 Jul 2006
    Spain!
    Que os parece?
    RM-7005
    One Din 7-inch Touch screen TFT LCD DVD/VCD/CD/MP3/AMP/AM/FM/TV
    7" fully motorized in-dash TFT colour monitor
    Play DVD/VCD/CD/MP3/CD-R
    Can add Camera and Rear Sensor(optional)
    Can be With 6-discs changer outside(optional)
    RDS(optional)
    DVB-T receiver(optional)
    one Din Car DVD player/FM/AM/TV/4x45W amp/GPS connector/DVB-T optional
    MODEL NO.WD7005
    lOne DIN size. All Function in One Unit.
    lIn-Dash Motorized Wide 7” Monitor.
    lAlternative Two Display Panel.
    lBuilt-in DVD Player (Compatible with DVD /VCD /CD /MP3 /WMA/JPG /CD-R /CD-RW / DVD-5 /DVD-9 /DVD-18/DVD-R /DVD+R /DVD-RW/DVD+RW).
    lBuilt-in FM/AM Radio (RDS Optional).
    lBuilt-in 4x45W Amplifier.
    lReady for TV or DVB_T receiver.
    lReady for DVD/CD Changer.
    lReady for Navigation.
    lLine Audio Output(FL/FR, RL/RR)
    l1 AV Input .
    l2 AV Outputs for Different Sources.(3 Zone)
    lRear Camera Input.
    lTouch Screen.
    Specifications:
    Monitor Unit
    Power Supply: DC12V(10.8V-15.8V)
    Current Consumption: Less Than 10A
    Operational Temperature Range:
    -20℃ to +70℃
    Weight: 2 Kg
    Audio Section
    Rated Output: 23W×4ch(1KHz, 1﹪, 4Ω)
    Maximum Power Output: 50W×4ch
    Rated Speaker Impedance: 4Ω
    Pre-AMPL Output Voltage: 2Vrms
    Pre-AMP Output Impedance: <220Ω
    AV Input/Output Section
    Video: 1 Vp-p(75Ω)
    Audio: 500mVrms
    Monitor Section
    Picture Size: 7 inches wide screen(17.7cm)
    154(W)×87(H)mm
    Display System: Transparent TFT LCD panel
    Number of pixels: 336,960 pixels(480H×234V×RGB)
    Video System: PAL / NTSC
    Viewing Angle: Up to 65°Down to 40°
    Left-Right at 130°
    FM Stereo Radio Section:
    Frequency Range:
    U.S.Standard: 87.9-107.9MHz
    Outside U.S.: 87.5-108.0MHz
    Usable Sensitivity: 5dBμV(S/N=30dB)
    S/N ratio: >60dB
    TV Tuner Section:
    Colour System: NTSC, PAL-B/G, PAL-I, PAL-D/K,PAL-M,PAL-N
    Channel Selection System:pLL Frequency Synthesizer System
    Usable sensitivity: 41dBuV
    RDS(optional): 15€
    PRECIO:385€(1-4unidades)
    Que os parece?
  2. alber_biker
    alber_biker Forista
    24 Mar 2006
    madrid
    F20 - M
    Pues ami me parece bastante barato. ¿ Sabes de que marca es? y ¿ Donde se consiguen?
  3. victor.T
    victor.T Guest
    En comparacion a otros esta muy bien de precio, i tiene buena pinta!!!!;-)
  4. Vic120d
    Vic120d Guest
    Baratisimo!!!!!!!!
    Lo Mismo En Pioneer Cuesta 2000 Euros
    No Te Da Mala Espina??
  5. SrMenDi
    13 Jul 2006
    Spain!
    nop xq seguro q es de alguna marca de esas q las conoce su madre..
  6. lfranco
    lfranco Guest
    Que tal,
    Tienen fotos de esto?
  7. ZanZibar
    ZanZibar Guest
    el de pionner vale 1200€ pero viene ademas con GPS
  8. Cesllorsan
    Cesllorsan En Practicas
    19 May 2006
    La Cañada (Valencia)
    eso con gps ya seria la ostia, yo kiero hacerme con una tv dvd y eso portatil pal coche q tenga tdt incorporado y si ya encuentro con gps seria perfecto, si encontrais algo por ahi y alo pondreis
  9. yaker
    yaker Forista Senior
    5 Ago 2006
    Estepona-Cordoba
    y donde piensas montarlo? yo estoy dandole vueltas al tema y no me gustaria perder los mandos del volante que controlan la radio.
    si compro una radio barata como estas, te encuentras que no hay interface........ por eso estoy pensando en quitar todo el hueco del cenincero e intentar integrarla ahi, usando la salida de audio de la radio conectada a la entrada aux, asi por lo menos podria manejar el volumen..... y como añadido, siempre podrias usar la tapa del cenicero para dejar todo bien guardadito, y que no se vea desde fuera, ya que robar una radio de salpicadero integrada como las nuestras, no es demasiado "rentable" pero si una como la que muestras.
    cuenta a ver que tienes pensado
  10. beemer
    beemer Perro Flaco Miembro del Club
    5 Feb 2003
    Madrid, bueno, a un rato
    X5-C1-Insignia
    le falta el "detachable faceplate" para que no te destrocen el salpicadero para robartelo
  11. Adrian_118D
    Adrian_118D Guest
    la pionner con gps vale 2000 sin navegador vale 1200 sin mano de obra y la alpine 1300 y con navegador -+ 2000. a mi por lo menos me huele mal aparte lleva caja de expansion o no?
  12. yaker
    5 Ago 2006
    Estepona-Cordoba
    a ver, no os hagais pajas mentasles, la calidad de uno y de otro, no tienen nada que ver, no hay nada escabroso en esto, solo son cosas que vienen de china, y ya esta, seguramente (lo se por propia experiencia) sean productos, que estan fabricados en la misma cadena de montaje de un pionner, y sale tan barato, porque usan su maquinaria.
    es decir la empresa pionner monta en china una fabrica, y el chino, que trabaja en ella, se dedica a hechar unas pocas horas extras haciendo otra marca de menos calidad pero mucho mas barata porque todo son ganancias.
    Un set de scalextric vale en torno a los 120 euros el normalito, y un solo coche vale 32 ok? bien pues los chinos usaron las fabricas de scalextric en china y sacaron un producto clonado que se llamaba JIADA, por 40 euros con dos F1 dos mandos y las pistas........ vamos una pasada por ese precio..... y totalmente identicos.
  13. beemer
    5 Feb 2003
    X5-C1-Insignia
    claro claro.. lo mismito es...
    como el opel frontera ese chino.... y su crashtest
  14. LLenS
    LLenS Guest
    consejo...
    no te compres nada de esto que no sea de marca.
    saludos
  15. yaker
    5 Ago 2006
    Estepona-Cordoba
    NO NO NO NO, no me malinterpretes, no digo que sean de la misma calidad eh, sera de menor calidad, peeeeeeero, si os digo que la mayoria de los chips y componentes son de marca, pero los plasticos y demas son de peor calidad.
    Esta claro, que no son duros a pesetas es de inferior calidad, pero.... por ese precio te compras 4
  16. jose luis
    jose luis Guest
    Yaker tiene razon. Si desmontais unas cuantas tft o plasmas, vereis que el panel interno (lo mas importante) es o philips, Panasonic o GOLDSTAR. Y resulta que el precio es la mitad, ¿verdad?
    Pues eso, que los chinos, que no son tontos, en las mismas lineas de produccion de las marcas punteras fabrican sus propios productos y los comercializan sin problemas, plasticos de peor calidad, pero lo importante es lo de dentro.
    Ahhh, por cierto, las marcas punteras no se quejan porque los chinos cumplen de sobras con los limites fijados por estas marcas, y se callan, mas que nada porque a los chinos les dan 2 euros y trabajan 20 horas.
    Les sigue saliendo rentable. Yo personalmente estoy mirando comprarme el modelo RM2D-6503T, ya que me parece una autentica pasada
  17. kryfter
    kryfter Guest
    valen las de doble din para los e46?? yo habia oido ke hay unas tuberias internas ke no dejan el hueco suficiente para instalarlas....
  18. atestado
    atestado Forista
    1 Nov 2005
    la coruña
    lo malo que no lee divx
