Jodo, es esto verdad??? hablan de que con las nuevas tecnicas de construcción de chasis (aluminio pegado con adhesivo) la nueva generación de BMW tiene un gran problema a la hora de sufrir un accidente y que el coche quede perfecto, hablan de la vulneravilidad al menor impacto y lo dificultoso de su perfecta reparación, dios mio no quiero ni imaginar una reparación en un conce "al uso", leyendolo me ha recordado a lo que comentaba Gus del A 8 :???: :???: :???: :???: By Ralph Vartabedian, Los Angeles Times If you hear talk about things such as rivets, epoxy adhesives and aluminum structures, you might guess the subject involves airplanes. But in this case, we are talking about the front ends of recent BMW Series 5 and Series 6 cars, which are constructed with many of the same techniques you might find at the Northrop Grumman F-18 assembly plant in El Segundo. BMW touts the vehicles for their remarkable handling, fuel economy and elite engineering, but critics of the designs say they are impractical, vulnerable to minor accidents and difficult to repair the way BMW recommends. The technology is another step in a much broader auto industry trend that is making collision repairs ever more costly, a kinder way of saying manufacturers are building throw-away cars. It means that more cars are totaled when they have relatively modest damage, particularly if they are more than five years old. Although BMWs can certainly be repaired, it requires a degree of sophistication and cost that may be unprecedented. BMW will certify auto body technicians only if they are employees of BMW dealerships, using BMW-approved parts, tools, adhesives and rivets. Though independent shops can buy equipment and get training, they are not allowed to say they perform certified repairs, BMW's official seal of approval. "It is a game," said Don Feeley, owner of three independent body shops in Riverside. "Absolutely, they are shutting auto body shops out of their business." Of course, BMW does not see it like that. The BMW system, code named the Grav 60, was introduced in the 2004 model year. It features an aluminum firewall, which separates the engine compartment from the interior, and frame rails that extend forward, all riveted and glued to the rest of the car's steel structure. When the cars come out of the factory they are built to a tolerance of 1 millimeter, about the thickness of a dime. The entire front structure weighs just 100 pounds, meaning the vehicles have a nearly perfect 50/50 weight distribution between the front and rear wheels, said Jeff Kohut, BMW's paint and body business development manager. "It handles better," Kohut said. "Go drive a car with a steel nose and you can tell the difference cornering, braking and turning." But one important question is what happens when your prized BMW gets kissed in the real world. With steel frame cars that are robotically welded at the factory, a body expert can put the car on a rack and bend it back into shape. Under BMW's guidelines, any bending on the front end is verboten. An accident that deforms the front end by more than 1 millimeter requires the replacement of the main front-end structures. Because the engine, transmission, suspension and body are all connected to those structures, it is a labor-intensive process. What's more, BMW specifies technicians can use only certain specialized tools, such as rivet extractors and rivet guns. Kenneth Zion, an auto body instructor at El Camino College and an independent collision consultant, says a shop can spend as much as $100,000 to fully outfit itself for BMW repairs. Zion, who has learned the system and will introduce the technology at El Camino, said the new system is unprecedented in how tightly the manufacturer is controlling the repair process. It is so tight, in fact, that the repair and insurance industries are going a little nuts.
otro articulo recogiendo lo mismo de Los Angeles Times AUTOMOTIVE NEWS Note to owners of BMW 5- and 6 Series cars: Drive with care. Even slight damage to the front of the car can be expensive. In some cases, insurers are declaring a lightly wrecked car a total loss. Why? Because the front end of the car -- built with high-tech aluminum, rivets and glue -- can be hard to repair, according to the Los Angeles Times. The front-end structure, which includes an aluminum firewall and body rails, weighs only 100 pounds. The minimal weight helps BMW achieve an ideal 50/50 fore-aft weight balance for better road handling. Because tolerances are so tight, if the front structure is bent by more than 1 millimeter in a crash, it must be replaced, not bent back to place, BMW says. The automaker recommends that repairmen be specially trained and use only BMW-certified tools and supplies, such as rivets. Experts say it can cost an independent repair shop as much as $100,000 for the training and special tools.
No me apetece leerlo entero, pero te puedo decir que aqui tuvieron que ahcer cursos especiales durillos, por l oque se comenta, adem´sa de que hemos recibido un huevo de nuevos adhesivos y útiles desde la aparición del E60. Lo que está claro, es que cómo el E30, nada!
estaba deseoso de leerte llubi, hablan de que un conce necesita una inversión de 100.000 $USD en utillaje especial para dichas reparaciones :-& :-& :-& :-& :-& :-&
Si... lleva un cemento y un pegamento especial, además de unas "pistolas" para no se que... Strap, desconozco el desembolso de esto, pero te puedo decir (ya que lo he llevado yo) que el coste de la máquina para ver que el sensor del ACC (adaptative Cruise Control) es correcto, vale 7 kilos. Y no es nada más que un juego de espejos, un montón de lasers y un ordenador... Es la booomba.... eso si, son de un bonito...
También decir, que etenemos un E87 sin casi nada (morro hundido) que se va siniestro... coche nuevo.. llega un punto en que igual que con los caudas, no se repara, se cambia.
En Burgos, la priemra reparacion de un e60 por colision lateral y desplazamiento y separacion del vano motor, se realizo en un taller semi-oficial bmw, donde yo llevo mis coches, y quedó PERFECTO. 7 meses tuvieron la culpa ya que era el primer e60 reparandose, pero a quedado perfecto. Los mecanicos asistieron a cursos de reciclaje y el taller invirtio mucho para poder acabarle. El coche en el momento del alcanze, tenia 500km
al final como le cambien la suspension al coche por una mas dura, el kit de emergencia va a ser un bote de loctite pal chasis, lo estoy viendo yo... xDDD
Pues si huele a las mismas dificultades (o parecidas) derivadas del empleo del aluminio...ahora si lo resolverán mejor o peor (es dificil, esto :???: ) que Audi el menor rozónen un A8...que nos cuente llubi. Al menos es solo la parte delantera, no?
Oño, que no había leído esto. Vale :ang: Pues estamos bien con el aluminio. Cada 'avance' que nos dan las marcas complica la cosa hasta límites insospechados, vamos. Por cierto, y si le das un fostio a un techo de carbono como el del M6 ó el CSL que hay que hacer ya, ¿darle una vueltecita en un transbordador espacial pa' que peque bien?
Es como cuando aparecio el magnesio en las llantas de las motos de 500 cc en sustitucion del aluminio, las primeras rompian sin ton ni son. Freddy Spencer se rompio una pierna entrenando por culpa de una rotura mientras probaba estas llantas, en teoria mas ligeras y mas resistentes que el aluminio....
Con el A8 al principio, con la estructura ASF de Aluminio....sólo había talleres en Madrí y Barcelona por el tema de las soldaduras del aluminio y su complejidad....... Lo q veo en BMW es algo similar, pero no sé por qué me da q será más acusado...
El problema es que esos materiales y tecnología provienen de la aeronáutica, como dice el artículo, por tanto los talleres de chapa y pintura del automóvil no están preparados para manejarlo. Personalmente no creo que sea tan complicado, sino "diferente", lo cual evidentemente implica tiempo y dinero... que es de esperar será repercutido en el cliente final (conductor o compañía de seguros). De todas formas, os puedo decir que en Alemania las compañías de seguros se miran muy mucho los costes de reparación a la hora de calcular las cuotas, así que si lo que pone en el artículo es medio cierto, los E6x deben costar un webo de asegurar... Lo de las pistolas que comenta Llubi, son pistolas de roblonar (poner "remaches" o roblones que es el nombre correcto de las cosillas ésas).
Seguramente, lo unico que va a pasar es que van a subir las cuotas del seguro :argue: :argue: Salu2 ;-)
