Buenas acabo de instalar esto: Pantalla motorizada 6,4 pulgadas Built-in: TV * Built-in: FM * Built-in: CD Controller * Built in: Amplifier * Motorized * Remote Controller System parameters Built-in function: FM, TV, VCD, CD, AV and amplifier. Automatic memory: All set characteristics and positions can be remembered automatically, and can be restored automatically Display. System: AUTO PAL or NTSC. Remote controller: Remote controller can fulfill all function. Menu function: OSD menu can indicate all operations, and real-time is also available. Signal sources: 2 Channels of input (comprise one channel of back running input). Back running detection: This system has back running video input, the input system will be switched to back running input to monitor the back running process. Mode selection: Video preset mode. which enables quick adjustment of picture quality conveniently. Self-protection: The monitor panel can detect any fault in the process of hiding or rolling out. Items Parameters Voltage DC 12V Current 1.5A(Amplifier off MAX) 10A Video system Auto PAL or NTSC Inputs Two channels of video (Comprise one channel of back running video) Sizes 17.8(W)X20.2(L)X5(H) cm Sizes (Internal) 17.8(W)X18(L)X5(H) cm Weight 2.0 kg Screen size 6.4 inch (diagonal) Resolution 960X234 pixels Dot pitch 0.136(H)X0.416(V)[/CENTER] Y la instalacion la he hecho yo , por primera vez y claro memorizo radios o demas cosas y al apagar el coche se me borran todas , tambien le he instalado un dvd Vieta , que me aconsejais que le puedo meter , me refiero a cargador de cd , television , etc . Muchas gracias.
Hola. Has conectado la corriente en el cable que no es, hay otro que solo te da paso cuando el coche esta en marcha, ahi es donde has de conenctarlo. Saludos
El coche tiene dos cables de alimantacion para la radio,un con corriente a traves de contacto (cable morado/blanco) y otro directo de bateria para las memorias,(cable rojo/verde) este ultimo no lo has conectado bien.
Creo que si esta conectado al mismo que ha al radiocd , para mas informacion es amarillo y los tengo los dos a la vez conectados .
Lo tienes mal puesto ya que estas perdiendo las memorias de la radio, señal de que cuando lo apagas, pierde totalmente la alimentacion. Haz lo que comenta Fer. Saludos
