The AC Schnitzer TENSION = Concept M6
Tema en 'Foro General BMW' iniciado por pLEy, 21 Oct 2005.
  1. pLEy
    pLEy Clan Leader
    21 Ago 2002
    Al besuguillo le han sacado otra preparacion, no se si sera repost, pero lo acabo de ver...
    World Première at the IAA 2005: The AC Schnitzer TENSION
    The basis for the was BMW M6, which underwent a performance upgrade. Optimising the entire engine management system and fitting an exhaust manifold system withl catalyst, sports rear silencer with tailpipe trims in "Sports Trim Design" help the TENSION achieve an incredible 406 kW / 552 HP.
    Even more imposing than the pure engine power is the maximum torque of 540 Nm at 6200 rpm, which pushes the driver back in the seat and catapults the TENSION to 100 km/h in just 4.5 seconds.
    The Vmax delimiter means that the acceleration thrust continues to 325 km/h before the speedo needle can relax.
    To achieve good deceleration values, development of a braking system was essential. On the front axle this takes the uncompromising form of an 8-pot fixed caliper with perforated and vented brake disks in (Ø 374 mm) and with 36 mm thickness. On the rear axle, a 4-pot fixed caliper is used.
    The wheels are also a new development: lightweight "Forged Wheel" with bi-colour finish embodies an apparent contradiction: reduction in weight with at the same time the largest possible diameters and widths.
    The TENSION is fitted with wheels size 10.0J x 20" all round. The offsets of -12 on the front and -2 on the rear allow tyres of size 285/30 ZR 20.
    To improve driving dynamics the TENSION has been equipped with an adjustable racing suspension. As well as lowering by 30 mm, the spring and damper rates have been clearly modified towards sporting performance. Furthermore antiroll bar kits and the specially developed strut brace in aluminium-carbon combination have been used.
    The TENSION body conversion is absolutely breathtaking, and is totally dedicated to optimising the aerodynamics. A further focal point of the development was the improvement of the air supply and extraction for the power plant and braking system.
    In comparison to the M6 a 50 mm wider body is the result of the complete conversion. At a glance: bonnet with power bulge, front skirt with large air intake, front wings with air outlet openings and 3 chromed ribs with integrated flashers, striking side skirts with large air shaft, rear skirt incl. unique underfloor wing construction with exchangeable diffuser, exchangeable rear wing.
    The interior is a combination of developments from the AC Schnitzer range and special one-off products.
    The AC Schnitzer TENSION was developed as a technology platform, which would cost around € 260,000 There are no plans for series production.
  2. NOVA
    NOVA Forista Legendario
    2 Abr 2002
    Gipuzkoa
    requeterepost!!!!
  3. Gus
    A 1800 kms del Ring
    Lo bueno de ello, pLeY (aparte de que lo vea quien no lo viera en su dia, porque es de hace más de un mes y no de antesdeayer ) es que te ahorrarás los comentarios sarcásticos que me dirigieron VAGticanistas y Mier-cedistas al unísono cuando lo puse en su dia biggrin Y además, no te sentirás en la obligación de responder como si la criatura fuera creación tuya :descojon:
    ...asi que muy bien puesto, ea
  4. ReZn0r
    ReZn0r //Mmmmmmmmm
    10 Jun 2002
    Galicia
    Vaya mierda de branquias cromadas estilo merchi :toimonst:
  5. pLEy
    pLEy Clan Leader
    21 Ago 2002
    biggrin biggrin biggrin
    Pues no lo vi, raro, deberia de acordarme de la avispa esta embrutecida biggrin biggrin biggrin
  6. blixa
    blixa Miembro del Club
    23 Ago 2002
    Tarragona
    pues el culillo no está nada mal
  7. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    Es feo, pero feo de eso que cuando lo ves en la pantalla dices....pero que cosa más fea, que me vas a romper los catódicos estos.
  8. leij
    leij Forista Legendario
    9 Abr 2004
    A Pobra do Caramiñal
    Nissan Xtrail
    Al verlo, pensé por un momento que en Barcelona habían decidido cambiar el diseño de los taxis y que se habían decidido por un Serie 6 :)
  9. Till
    Till Guest
  10. pLEy
    pLEy Clan Leader
    21 Ago 2002
    Gracias Till, veo que tienes mucho tiempo libre...:descojon: :descojon:
  11. Till
    Till Guest
    Tanto como para seguir el link al otro post en este mismo :descojon:
  12. pLEy
    pLEy Clan Leader
    21 Ago 2002
    Me referia a buscar el anterior post ;-)
  13. Till
    Till Guest
    Y yo ;-)
    Mira abajo del todo... los enlaces a post parecidos :)
  14. Manuel
    Manuel Forista Senior
    29 Mar 2002
    Principado de Asturias
    Me encantan las avispas.
  15. Toni Montana
    Toni Montana Guest
  16. Till
    Till Guest
    Oñe, es que hice un photoshop del e46 en base a ese post... no el tuyo ya, sino el original del cual el tuyo ya era repost :mus- :) pero que volví a pegar en tu post y, casualmente, tengo de fondo de pantalla en la PSP... que está delante mío, en modo MP3 :finga:
    For show one button:
    Subido a imageshack el 14 de septiembre... así que ese día fue el post original ;-)
  17. Toni Montana
    Toni Montana Guest
    Bonito choping :)
    Por cierto, el mío tiene fecha de 13 de septiembre :):)
    http://www.bmwfaq.com/showthread.php?t=73509
    :moon: :moon:
  18. Till
    Till Guest
    Pues juraría que lo hice en otro post y comentándolo antes... ahora no lo encuentro pero ya veremos :)
    Por ahora ya he encontrado otro repost anterior de lo mismo:
    http://www.bmwfaq.com/showthread.php?t=77545 :)
    TOMA!
    Post REPOST de GUS:
    http://www.bmwfaq.com/showthread.php?t=73625
    Lo vi después que el tuyo y por eso primero posteé mi photoshop ahí y luego en el tuyo :) Por no poner fotos en el tuyo :moon:biggrin
