airbag e46
sergio_320
22 Nov 2006
hola como al pasar el bmw scaner me salia fallo de airbag he desmontado el asiento y he echo el brico de la esterilla ahora y he pasado la maquina para borrar fallos y sale esto.
al dar al contacto salen la luz del airbag y la del cinturon y se quita primero la del airbag y luego la del cinturon.
al borrar los errores el boton del airbag se encendia y se apagaba solo.
copio un pantallazo del bmw scaner.
el testigo hace el chequeo y se apaga
# USER INFO FIELDS
Unit Date VIN Odometer Assembly Software Service Dealer Tester Program ver.
DDE -> 26.04.01 WBAAL71020CF55226 0 km 7.788.359 7.788.360 2.247.073 000049 4.0!. -
# USER INFO FIELDS
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY ERRORS AFTER CLEAR
DDE -> 7.786.887 52 D5 1 error / 1 error no errors / no errors
EWS -> 6.905.668 03 08 no errors
ABS -> 6.756.286 08 42 3 errors 3 errors
A/C -> 6.907.897 23 06 no errors
SRS -> 6.912.755 10 30 no errors / 1 error no errors / 1 error
IKE -> 6.910.277 10 21 no errors
LCM -> 6.907.948 10 20 4 errors / 1 error no errors / no errors
ZKE -> 6.914.363 11 20 3 errors / no errors no errors / no errors
MFL -> 0.000.000 01 11 no data
PDC -> 6.904.023 01 13 1 error no errors
SZM -> 6.914.718 02 03 no errors / no errors
SHD -> 6.910.471 05 27 no errors
SPMFT -> 6.913.364 02 02 no errors / no errors
SPMBT -> 6.913.364 02 02 no errors / no errors
SMF -> 8.263.133 07 0B no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DDE -> 08/48 - Glow-plug system
Shadow-memory:
Errors after clear:
no errorsShadow-memory:
no errors
ABS -> 95/00 - CAN timeout DME/DDE
14/00 - Wheel speed sensor front left start up detection
24/00 - Wheel speed sensor front right start up detection
Errors after clear:
SRS -> Shadow-memory:
70/20 - Seat occupancy detector, break of seat mat
Errors after clear:
Shadow-memory:
LCM -> 16/01 - Turn lights switch / wire, short circuit to ground
17/01 - High beam / headlight flasher switch, short circuit to ground
22/22 - HVAC, front load sensor, short circuit to ground
24/22 - HVAC, rear load sensor, short circuit to ground
Shadow-memory:
3C/03 - Licence plate light
Errors after clear:
no errors
ZKE -> 2A/21 - Central locking system: Relay doesn't switch to on at Central saving
43/21 - Anti-theft alarm system: Interior protection rear
3B/02 - Interior light: Short circuit
Errors after clear:
no errors
PDC -> 13/8E - Converter, rear centre right
Errors after clear:
no errors
# CLEAR DTCS END
haber si me podeis decir algo
kanario_2h
26 May 2010
No entiendo nada de lo que pone lo que si se es que la luz del airbag se tiene que encender unos segundos y luego apagarse como la del cointuron
jfac_2013
17 Nov 2012
yo tengo echo el brico q lo ice ayer y la verdad es que funciona de lujo y no me sale nada de eso
juanjete33
320i 2.2 Steptronic.
30 Dic 2008
Pues en el tema de la esterilla, si dices que ahora se apaga y viendo los errores de SRS pues parece que esta bien ahora, tienes el error, pero no presente.
DRC compact
DiagnosisCoding
23 Feb 2005
Esterilla caput,si el brico es bien hecho tiene que apagarse y borrar el fallo con la dignosis y parece que despues de borrar fallos,ese persiste...si no se borra,posiblemente modulo (caja negra de debajo del asiento) caput.
sergio_320
22 Nov 2006
no se queda fija pero al pasar la maquina sigue sale error.
