Barra entre torretas M2 competition
Guntak
M2
5 Ene 2022
Hola buenas quisiera saber si alguien le ha puesto al M2coupe la barra entre torretas del M2 competition ,o sea si es compatible y donde la puedo comprar
alex16v
24 Nov 2015
Yo he visto a un ingles que la lleva, eso si requiere modificaciones y tiene puesta la kW clubsport 2ways del m4
Red - F87 M2 chassis has no place for these to be bolted in
Yellow - voids a brake hard line out the ABS so that's a no go
Green - you'd have to cut the wing to access the bolts & makes it a nightmare to get on/off the car
So you're left with this - making it a straight fit for an M2 .... once you've had a play with the trim covers as well
Guntak
M2
5 Ene 2022
Vale ,gracias por la info
Pondre una barra weicher y andando
