Lo frutero es bello BMW 330e Specifications: ▪ Length/width/height/wheelbase – 4,709/1,827/1,440/2,851 mm ▪ Ground clearance – 150 mm ▪ Est. kerb weight – 1,815 kg ▪ Est. cargo volume – 500 litre ▪ Engine – 2.0-litre (1998 cc), 4-cylinder in-line, turbo petrol - Max output – 184 hp (135 kW) at 5,000-6,500 rpm - Max torque – 300 Nm at 1,350-4,000 rpm ▪ Electric motor max output – 113 hp (83 kW) at 3,170 rpm ▪ Electric motor max torque – 265 Nm at 0-3,170 rpm ▪ Max system output – 292 hp (215 kW) ▪ Max system output – 420 Nm ▪ Transmission – 8-speed automatic, RWD ▪ Battery capacity – 12.0 kWh ▪ Charging time at 3.7 kW (16A/230V) – 2.4 hours to 80% ▪ Est. 0-100 km/h – 5.9 seconds ▪ Top speed – 230 km/h ▪ Electric top speed – 140 km/h ▪ Est. electric driving range – 59-66 km ▪ Est. fuel consumption – 1.6-1.9 l/100km combined ▪ Est. energy consumption – 14.8-15.4 kWh/100km ▪ Footage location – Munich, Germany
The new BMW 330e and 330e xDrive utilize an intelligently controlled powertrain consisting of an electric motor, a high voltage battery pack and an internal combustion gasoline engine to enhance the performance driving experience of the 3 Series. A 2.0-liter BMW TwinPower Turbo engine developing 181 hp @ 3,800 – 6,500 rpm and 258 lb-ft of torque @ 1,450 – 3,600 rpm is complemented by an electric traction motor developing 107 hp at 3,170 rpm and 77 lb-ft of torque @ 0 – 3,140 rpm. The combined power output is 288 hp and 310 lb-ft or torque with XtraBoost. A high-voltage 34 Ah / 12 kWh gross (9.09 kWh net) lithium-ion battery module located underneath the rear seats provides the storage capacity for electric-only and performance oriented driving.
