Video BMW 340i M Perfomance Power Kit, autoblocante y 360cv
Tema en 'Foro General BMW' iniciado por cybermad, 6 Nov 2015.
  1. cybermad
    Some first official details on 340i M Performance Power Kit (MPPK), with sound clip
    While at SEMA 2015, we managed to get some official first details on the upcoming 340i M Performance Power Kit (MPPK) and limited slip differential (LSD).
    Q: What are the details on the 340i M Performance Power Kit (MPPK)?
    A: It should be available by beginning-mid of December. The power kit now only comes bundled with the M Performance Exhaust since they work in tandem. The stock exhaust has too much back pressure to work with the higher flow of the new power kit, so the 340i M Performance Exhaust has reduced back pressure to work with the remapped ECU of the power kit.
    There's two ways to increase power - intake more air, or reduce back pressure allowing for faster air exit. With the previous MPPK (for the N55 engine) we went the route of more air intake, but for the 340i (B58 engine) we modified the the exhaust system to reduce back pressure and allow the air to exit the car faster, which together with the modified ECU, results in more power.
    Q: What are the expected gains for the 340i MPPK (ECU + Exhaust)?
    A: We're not ready to share final numbers, but expect it to be around 360hp (going from 240kw to 265kw), and 369 lb-ft (going from 450Nm to 500Nm).
    Q: Details on the 340i M Performance Exhaust?
    A: It's the new generation flap exhaust. Valves open/close depending on which driving mode the car is in. [See our video below from SEMA showing the difference between the factory exhaust sound and the MPPK (DME + M Performance Exhaust) sound.]
    Q: When will 340i limited slip differential (LSD) be available?
    A: The LSD for automatic and manual 340i is now available. No LSD for xDrive 340i.
    BMW 340i Factory Exhaust vs. MPPK sounds
    (pre-recorded sound clips in order to hear the exhaust under load):
    http://f30.bimmerpost.com/forums/showthread.php?t=1191782
    A Navero y ER330d les gusta esto.
  2. Spidiman
    17 Jun 2012
    Barcelona
    e61 530i
    Me conformo con el autoblocante. Me quiten el aleroncito, las franjas y las llantas que ya me buscaré yo la vida. Y el escape tampoco me mata, casi prefiero el sonido stock.
    Y el chispazo más de lo mismo, para 40 cv tampoco hay que hacer ingeniería aeroespacial.
  3. ER330d
    4 Abr 2013
    Lavadora
    Que horterada
    Prefiero uno azul/beige , pero con el autoblocante y los 360 cv
    A Kaiser-x, sergiomp94 y Navero les gusta esto.
  4. otorre
    otorre Forista Legendario
    24 Sep 2006
    Cantabria
    El escape lo justifican para la ganancia de potencia y debe sonar mejor pero opino igual, esos 2 tubarros cromados parecen del Norauto.
    A spidiman y ER330d les gusta esto.
  5. Manolo71
    Manolo71 Forista Senior
    4 May 2008
    Tarragona
    M3E46,545E61
    Me gusta la chaqueta blanca que lleva la tia en la penultima foto.
    A ER330d le gusta esto.
  6. Spidiman
    17 Jun 2012
    Barcelona
    e61 530i
    A mi me tira más la culata, que quieres que te diga :ANAL:
  7. Spidiman
    17 Jun 2012
    Barcelona
    e61 530i
    Más que la estética es el sonido el que no me acaba de entrar. No se, es que automáticamente lo comparo con sus hermanos atmosféricos y....
    A otorre le gusta esto.
  8. Pedro6844
    Pedro6844 Ahahahaha!! Miembro del Club
    25 Feb 2010
    Zgz
    MX5 2.0/ 2022
    Como le sigas quitando, te quedas en un 330i :p
    A spidiman le gusta esto.
  9. Olagüe
    Olagüe Clan Leader
    27 Oct 2006
    New York City
    333i e92
    Manda huev*s que saquen el autoblocante ahora en la serie 3 normal!
    Ya lo podian haber montado en el e92!
  10. tonodiez
    tonodiez En Practicas
    24 Ene 2013
    El problema de este coche que en cuanto te pones a meter chucherías de M-Performance a un 340i te acercas peligrosamente en precio a sus hermanos mayores los M3 y M4...
  11. Pichi
    Pichi Forista
    29 Dic 2004
    Si, es un pelin macarra. Los adhesivos M fuera pero ya. Que obsesión con pegarla los colorines.
    No me gusta.
  12. Pichon82
    Pichon82 Forista Legendario
    3 Jun 2009
    Alcobendas
    cabrio v8 y M3
    pues a mi me gusta...tambien decir que venia del tuning entonces jaja.
    le veo chulo con un toque de distincion frente a los demas serie 3.
