BMW M3 E91 Touring SMG by Manhart Racing: 5.0 V10 550cv 0/100-4.3" 324 km/h
¡¡¡¡LO FRUTERO ES BELLO!!!! :finga:
Manhart Racing has unveiled a V10-powered BMW "M3" E91 Estate.
Now, let that sink in for a second. BMW doesn't make an M3 Estate, and Manhart equipped one with the M5's 5.0-liter V10 engine instead of the M3's 4.0-liter V8! If that isn't insane enough, the company also added revised engine electronics and a HJS stainless-steel exhaust system (with two 200-cell racing catalytic convertors) which allows the engine to produce 550 PS.
Backed up by various M-spec parts (it uses the seven-speed SMG transmission and 100% limited slip differential from the M5 E60, while the axles and steering system come from the M3 E90), the M3 Estate rockets from 0 to 100 km/h in 4.3 seconds, before topping out at 324 km/h (201 mph).
Other performance tweaks include a Bilstein PSS10 coilover suspension, a Stoptech braking system (with six-piston calipers and 380mm brake discs up front / four-piston calipers and 355mm brake discs out back), and RÄD Monza three-part forged wheels wrapped in Hankook S1 Evo tires.
While the performance is mind boggling, the styling is fairly typical. The exterior receives a traditional M3 body kit, while the interior boasts leather and Alcantara upholstery, carbon fiber trim, and heated sport seats.
If you like what you see, be prepared to send Manhart a check for €120,000 ($177,955 USD).
Source: Manhart Racing
gibito16
Baneado
Baneado
12 Mar 2009
lo siento, no me gusta, el frontal del e 92? [-(
bmw...
23 Nov 2008
bonito frutero!
pero pa preparar asi un frutero preparo un berlina..........
330concept
E92 M3. 997Gt3
17 Abr 2005
Esos buckets me tienen enamorado y el volante ya ni te cuento con el shiftlight integrado
mario90
Baneado
Baneado
18 Dic 2008
j*der!! sería perfecto si no tuviera las llantas negras...
3
330m-power
precioso guapisimo excelente impresionante.. se me ocurren mas calificativos pero creo que soran ya
SALUDOS.
albvalper
E85 F54 F55 F20
21 Jul 2007
No se yo si va a tener suficiente motor para tirar de un touring, en cuanto lo cargue un poco con los niños, la suegra y la compra.............:descojon::descojon::descojon:. Vaya aparato.
TML
20 Nov 2008
Joer!! No se conformaban con el V8?? Es impresionante! Unicamente me quejaría por las llantas, pero esos baquets son.... uff!! :xray:
Azazel1988
21 Ene 2008
Seguro que con estos coches las frutas llegan mas frescas a su destino y mas rapidas que con ningun medio de transporte:descojon:. Porque sino no entiendo el fin de crear un deportivo ranchera no va con mi filosofia tal vez sea debido a mi juventud.
Cris
///M3 ///M330 ci
22 Jul 2005
cybermad;7834688 dijo:
pues toma, para que te vayas acostumbrando biggrin
el audi RS6 tambien cabe entre los V10.
asique asi seria un m3 touring si existiera :xray::xray::xray::xray:
Carlos
20 Jul 2005
Seguro q cuando salga la nueva generación E9X en 3 años, se plantean la ranchera en versión M teniendo en cuenta el grado de aceptación en Europa de esa carrocería que va comiendo terreno a la berlina y es algo q le está pasando tanto a BMW como a AUDI.
Sargento_Duke
2 Oct 2005
Para que hacer rancheras "M" cuando la gente solo quiere aparentar y les sobra con un X1
Mejor un frutero vitaminado que una frago!!!
Elsustanciero
23 Dic 2007
330m-power;7834281 dijo:
SALUDOS.
+1 brutal el frutero este en Manhart saben lo que acen:supz:
Luis Rivero
120i
2 Abr 2006
con toda la metralla que le han puesto y siguen dejando los pedales de goma :-& los M tendrían que llevar unos buenos pedales de aluminio perforados, o de carbono si me apuras, pero que monten los mismos pedales que un ford ka o cualquier utilitario urbano me parece una :butthead: muy notoria.
NOVA
2 Abr 2002
Luis Rivero;7836659 dijo:
Prefiero a que trabajen en el motor y chasis y que dejen los pedales que traen los ///M, chorrada de carbono en los pedales, si ni los veo y estan para pisarlos!!! :-#
Manolo71
M3E46,545E61
4 May 2008
mario90;7834274 dijo:
Si señor....que mania con poner las llantas negras a todos los coches....sean coupes,berlinas,fruteros o lo que sea.....en fin....
El coche?? El coche es un makinon.....lobo con piel de cordero y eso me encanta....
Urko
R1200RS/S-MAX
11 Oct 2005
Manolo71;7879589 dijo:
Por mas que lo miro yo no le veo la piel de cordero por ningun lado:xray:
