leij;7915373 dijo:
Pues a mi me gusta porque no es la típica preparación recargada o gótica que a veces se ven por ahí. Pero ¿es sólo fachada o también se le retoca el corazón?
es solo maquillaje
We are proud to release our all-new limited edition GTS3 line up for the BMW E92/90 M3 models
consisting of a full front bumper & hood replacement unit.
GTS3 Front Bumper features (Application: E90/E92 M3 Only):
Vacuum Bagging Carbon Fiber Construction (Optional)
Utilizes all factory mounting points, screws, grills & ducting
Revised center mouth opening with 6.35mm extension
Lowered ground clearance with downward extension of 25.4mm
Redesigned side ducting eyebrows to enhance appearance
Replaceable 1-Piece Design Carbon Fiber Front Splitter
Improved overall aerodynamics & increased airflow to radiators & air box
[Available Front Bumper Options:]
Full visible carbon fiber construction w/ carbon fiber front spoiler attachment
Dry Vacuumed Woven Plastic construction w/ carbon fiber front spoiler attachment
1-Piece carbon fiber front splitter attachment (Shown Above)
2-Piece carbon fiber splitters (Available in September 2009)
As part of new the GTS3 front fascia we have also developed a new functional power dome vented
carbon fiber hood to replace the factory aluminum unit.
GTS3 Vented Power Dome Hood features (Application: E92 M3 Only):
Utilizes all factory mounting points, screws & shocks
Revised central power dome with sharper tension edges
Integrated dual ventilation openings for engine heat extraction
Rolled composite carbon fiber edges
[Available Vented Hood Options:]
Double sided carbon fiber construction w/ carbon fiber underside paneling
Single sided carbon fiber construction w/ black DVWP underside paneling
