INEOS Styrolution’s composite StyLight® accelerates BMW M cars 11/19/20 Frankfurt, Germany Aesthetic carbon look Cost-effective production INEOS Styrolution, the global leader in styrenics, announced today that BMW M has selected the aesthetic composite StyLight® as the material of choice for a new generation of ergonomically optimised carbon shift paddles. The selected material for the shift paddle application is INEOS Styrolution’s carbon composite StyLight Aesthetic S C245-1-060, backmoulded with PC/SAN GF30. It was specifically developed for automotive interior and exterior applications and a range of applications in the electronics as well as the sports and leisure industries. In addition to its aesthetic appearance, StyLight offers a high chemical resistance. The StyLight solution meets all high BMW M standards. A significant benefit of the solution is its cost-effectiveness. For example, StyLight can be used without coating (compared to a PC based composite) and no extra compression moulding step is required since the high surface appearance is achieved directly by the backmoulding step. Martin Köhler, Business Development Manager Composites at INEOS Styrolution comments: “I am excited about the collaboration with BMW M. This is the kind of application we developed StyLight for.” Shift paddles allow drivers of cars with automatic transmission to manually shift gears. While automatic transmissions are very advanced, some drivers still prefer to shift gears manually to anticipate bends in the road, to select a more responsive gear or taking advantage of the engine speed to slow the car, particularly in bad weather or slippery descents. https://www.ineos-styrolution.com/news/INEOS-Styrolutions-composite-StyLight-accelerates-BMW-M-cars --------------------------- El compuesto StyLight® de INEOS Styrolution acelera los automóviles BMW M 19/11/20 Frankfurt, Alemania Aspecto de carbono estético Producción rentable INEOS Styrolution, el líder mundial en estirénicos, anunció hoy que BMW M ha seleccionado el compuesto StyLight estética ® como el material de elección para una nueva generación de levas de cambio de carbono ergonómicamente optimizado. El material seleccionado para la aplicación de la paleta de cambio es el compuesto de carbono StyLight Aesthetic S C245-1-060 de INEOS Styrolution, moldeado con PC / SAN GF30. Fue desarrollado específicamente para aplicaciones de interior y exterior de automóviles y una gama de aplicaciones en la electrónica, así como en las industrias del deporte y el ocio. Además de su apariencia estética, StyLight ofrece una alta resistencia química. La solución StyLight cumple con todos los altos estándares de BMW M. Un beneficio significativo de la solución es su rentabilidad. Por ejemplo, StyLight se puede utilizar sin recubrimiento (en comparación con un compuesto basado en PC) y no se requiere ningún paso de moldeo por compresión adicional, ya que la apariencia de alta superficie se logra directamente mediante el paso de moldeo por contrafuerte. Martin Köhler, Business Development Manager Composites en INEOS Styrolution comenta: "Estoy entusiasmado con la colaboración con BMW M. Este es el tipo de aplicación para la que desarrollamos StyLight". Las levas de cambio permiten a los conductores de automóviles con transmisión automática cambiar de marcha manualmente. Si bien las transmisiones automáticas son muy avanzadas, algunos conductores todavía prefieren cambiar de marcha manualmente para anticipar las curvas en la carretera, seleccionar una marcha más sensible o aprovechar la velocidad del motor para reducir la velocidad del automóvil, particularmente en condiciones climáticas adversas o descensos resbaladizos.
