Video BMW X3 M / X4 M presentación oficial
Tema en 'Foro General BMW' iniciado por cybermad, 4 Feb 2019.
  1. cybermad
    No quieres caldo, pues toma 2... zarrios biggrin
    Última edición: 4 Feb 2019
    botminik, tronco39, luxo46 y 2 otros les gusta esto.
  2. cybermad
    Parece que ya los van a presentar, esto ya lo vimos hace tiempo...
    A jagus le gusta esto.
  3. Gus
    A 1800 kms del Ring
    Ginebra está ahí mismo...
  4. luxo46
    luxo46 Forista Senior
    27 Ene 2013
    Me alegro de que los escapes sean de verdad.
  5. cybermad
    Aquí están :)
    A davidW le gusta esto.
  6. cybermad
    A Llorens le gusta esto.
  7. cybermad
    Highlights:
    3.0L Twin Power Turbo inline 6 cylinder (S58) engine
    473 HP / 442 LB-FT (Standard model)
    503 HP (Competition model)
    0-60 in 4.1 seconds (standard model)
    0-60 in 4.0 seconds (Competition model)
    155 MPH top speed (electronically limited)
    174 MPH top speed (for standard model if optioned with M Driver's Package)
    177 MPH top speed (for Competition model if optioned with M Driver's Package)
    Production begins April 2019
    Engine / Exhaust
    473 HP (standard model) and 503 HP (Competition model) from 6250-7200 RPM
    442 LB-FT torque from 2600-5600 RPM (standard model) and 2600-5950 RPM (Competition model)
    Forged crankshaft
    7200 RPM redline
    Closed deck design
    Wire-arc sprayed-on iron coating for cylinder walls
    3D printing technology cuts weight of cylinder heads
    Two mono-scroll turbochargers
    350 bar maximum fuel injection pressure
    Valvetronic and Double-VANOS variable camshaft timing
    100 mm exhaust tailpipes
    M Sport exhaust system standard for Competition models
    Transmission / Cooling
    8 Speed M Steptronic transmission with three shift modes
    M xDrive intelligent all-wheel-drive system
    Active M Differential (allows rear lockup between 0-100%)
    Cooling
    One large central radiator and two smaller radiators sides
    Engine oil cooler and a separate transmission oil cooler
    Lightweight oil sump has two separate chambers and an integrated suction channel
    Chassis / Suspension
    Strut brace in the engine compartment that links the shock towers
    Carbon fiber strut brace will be available as an option beginning August 2019
    A-strut in front section near the firewall, with two further struts increasing stiffness between the shock towers and the front of the car
    Large rear brace and model- specific rear axle control arms
    Double-joint spring strut front suspension and Five-link rear suspension feature model- specific bushings
    Custom-made swivel bearings, torque arms and wishbones in front suspension
    Increased front wheel camber
    Model-specific components and custom bushings in rear suspension
    Stiff camber arm
    M-specific rubber mounts for all control arms and the rear suspension subframe
    Model-specific anti-roll bars (larger bars on the Competition models)
    Adaptive M Suspension controls damping forces for each wheel individually
    Steering
    M Servotronic system combines speed-sensitive power assistance and a variable ratio
    Steering response can be varied by pushing a button to select one of three settings
    Brakes / Wheels / Tires
    Four- piston fixed front calipers and single-piston floating rear calipers at the rear
    Drilled, inner-vented brake discs measure 395 millimeters (15.6 inches) in diameter at the front and 370 millimeters (14.6 inches) at the rear
    Cast- iron brake discs with aluminum hubs
    M light-alloy wheels in V-spoke design and mixed size high-performance tires (non-runflat)
    20-inch wheels in polished Orbit Grey finish with 255/45 ZR20 tires at the front and 265/45 ZR20 tires at the rear (standard model)
    21-inch wheels with a polished Jet Black finish with 255/40 ZR21 tires at the front and 265/40 ZR21 at the rear (Competition model)
    Exterior / Colors
    Seven exterior colors, including new Toronto Red metallic and M-exclusive Donington Grey metallic.
    Competition Model
    Standard equipment on the Competition models includes:
    21-inch M light-alloy wheels in polished Black
    M Sport exhaust system with tailpipes in Black Chrome
    Specially designed door sill plates and model badging
    M Carbon Exterior Package
    Optional M Carbon exterior package (expected to be available from August 2019), will feature design elements in carbon fiber- reinforced plastic (CFRP) for the front air intakes, the air blades in the front apron, the rear diffuser and the exterior mirror caps
    On the BMW X4 M and BMW X4 M Competition, these elements will be joined by a CFRP rear spoiler
    Interior
    Standard: heated sports seats in Vernasca leather with embossed M logo
    Optional: M Sport seats in extended Merino leather (standard on Competition model)
    Vernasca leather upholstery in a choice of Black or Oyster with an embossed M logo at the top of the backrests,
    Interior trim strips in Aluminum carbon structure.
    Competition X3M and X4M come standard with M Sport seats in extended Merino leather upholstery that can be specified in either Black or bi-color choices in Sakhir Orange/Black or Adelaide Grey (optionally available for standard models)
    Optional extras include BMW Individual extended Merino leather upholstery in Ivory White and Tartufo (only in conjunction with the M Sport seats) and Carbon Fiber interior trim strips.
    Extended Merino leather upholstery in the new Midrand Beige/Black color choice with Alcantara applications is available exclusively for the BMW X3 M Competition and BMW X4 M Competition models
    Standard and Optional Equipment
    Standard:
    Adaptive Full LED lights
    Harman Kardon surround sound audio system
    SiriusXM Satellite radio with 1 year subscription
    Navigation with Apple Car Play compatibility
    Comfort Access keyless entry
    Full array of advanced driver assist systems including Active Guard, Active Protection Active Driving Assistant and Frontal Collision Warning with City collision mitigation.
    Optional packages include:
    Driving Assistance Plus Package with Active Cruise Control with Stop & Go and Extended Collision Mitigation
    Executive Package with heated steering wheel, heated front and rear seats, parking assistant plus, head-up display, wireless charging, WiFi hotspot and gesture control.
    A botminik le gusta esto.
  8. cybermad
  9. cybermad
    Llevan el S58, el mismo motor que el M3 G80 y M4 G82
  10. EÄRENDIL
    16 Oct 2002
    En un sofá.
    Arkana Bonito..
    Ya era hora que sacaran estas versiones, falta les hacía.... lo sé, soy un hereje .
    Pero el problema que le veo a lis nuevos X3 es lo mismo que les pasó a los F25 o serie uno actuales, y son los faros tanto delanteros como traseros, enturbian la imagen del coche, y los poco que he visto por la calle más se acrecenta esa sensacion.
    Por lo demás, habrá que ver cómo sale en un cara a cara contra un Stelvio....
    A MACO le gusta esto.
  11. inthenight
    inthenight Clan Leader
    19 Feb 2005
  12. Julián JG
    Julián JG En Practicas
    2 Sep 2015
    Cádiz
    420GC
    Pues cuando salió el x4 no me llamó la atención en nada, pero con el paso del tiempo me ha ido encajando cada vez más, hasta el punto de verme mirando precios de seminuevos, menos mal que ahí ya se deshace el hechizo...
  13. MACO
    MACO Hay un mundo mejor, pero es carísimo!! Miembro del Club
    13 Sep 2003
    Extrema&dura
    510 POTROSGREEN
    Pintan bien, al menos para mi. Aunque a algunos os haga daño el saber que existen estos modelos ya en básico, más aún con estas versiones con pretensiones.
  14. jangel
    15 Dic 2002
    Hormigonera
    Para cuando el
    Scooter c1 M ?
    Creo que es el que queda ! :hungover:
    A gorka le gusta esto.
  15. grinch
    grinch Forista Senior
    14 Abr 2009
    waterworld
    X6 F16 //M2Comp
    Pues...me lo pido!!
    A jangel le gusta esto.
  16. jangel
    15 Dic 2002
    Hormigonera
    Me llevas atrás? ! Siempre quise ir atrás abranzando el carenado :love:
    No homo
    A puntoloco le gusta esto.
  17. tonodiez
    tonodiez En Practicas
    24 Ene 2013
    Auténticas bestias pero estéticamente muy mejorables, la senda de diseño de BMW con los riñones hipertrofiados y faros extraños no atrae mucho ni siquiera en estas versiones top M.
    Sin embargo los interiores son brutales muy bien rematados y muy bonitos.
    A josetanitau y tronco39 les gusta esto.
  18. tronco39
    tronco39 Clan Leader
    16 Ago 2007
    Comunidad de Madrid
    Unos cuantos
    Coincido con @tonodiez, de motor irán sobrados y escandalosamente bien, pero a nivel estético exteriormente me parecen sosos, continuistas, y en el caso del x3 se incrementa aún más... :(
  19. grinch
    14 Abr 2009
    waterworld
    X6 F16 //M2Comp
    Y sin moto también te llevo biggrin
  20. gorka
    gorka Forista Legendario
    13 Jun 2002
    Zaragoza
    911 S
    Esperando a los serie " active tourer con sus traccion delantera y motor de 3 cilindros y su M.
    No me voy a poner en plan purista, todo tiene su mercado y cuanto mas haya donde elegir, mejor, pero para mi esa M de Motorsport en estos casos es la de Me la pelan.
  21. jangel
    15 Dic 2002
    Hormigonera
    ya lo sé onvre pero de la otra manera es un show :floor:
    A grinch le gusta esto.
  22. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    Hay que competir con RS, AMGs y Macanes...aunque no tenga mucho sentido el coche en si mismo.
    A jangel y grinch les gusta esto.
  23. GELI///M
    GELI///M Forista Senior
    9 Abr 2007
    Pues no lo veo mal. Han arreglado (dentro de lo que cabe) el X4, y el S58 veo que es un motor que va a dar mucho que hablar... No me digáis por qué pero lo intuyo por concepto el sustituto del N54 en cuanto a potenciaciones.
  24. lito_S1
    lito_S1 Forista Senior Miembro del Club
    11 Jun 2007
    e36i f23i G01i
    Pues me encanta, me dejaron un X3 nuevo durante un mes en el conce FULL equipe y me encantó todo menos el motor 20d, con este motor tiene que ser brutal.
  25. cybermad
    Ya salió hace unos meses, que no estás a lo que tienes que estar, el BMW X2 City eléctrico :ANAL:
  26. cybermad
  27. cybermad
