Cambio de frecuencia radio japonesa a europea
Hola,
tengo un z3 1999 roadster y la radio original solo toma la frecuencia japonesa,
alguien sabe como puedo cambiar a la frecuencia europea en el menú secreto de la radio? :argue:
govillard
STF777;12886898 dijo:
Hola,
Hola...
Joé, me parece algo dificil asi derrepente. Alguna radio kenwood que tuve se cambiaba la opcion desde teclado.
Otras tienen algun jumper por la placa, que se puede cambiar de posicion para cambiar la recepcion, y en otras hay que desoldar/soldar alguna pista para hacer el cambio.
En la tuya ni idea. Pero busca por el subforo electronica.
Suerte
Castanya
En la web de:
e36 radio nz - bimmersport.co.nz
Hay esto:
Hi,
I think I may be able to help you.
Turn the radio off and then back on.
Keep "m" pressed (10-12 seconds) until it shows you the serial number of the radio. This "m" button is the same button that you use to manually tune the radio frequency, and should be inbetween the "<" and ">" buttons.
Once it shows the serial number, you are in service mode.
Now you can cycle through all the different service mode options using the "+" and "-" buttons.
Cycle through until you get to the option that says AREA: JAPAN
Now you can use the "1" button to cycle through the different areas, so choose Europe or Oceania.
Thats it! Now press "<" or ">" and the radio will automatically restart, and the frequency band range will have changed from 77-90 to 88-108.
I have done this in my OEM E46 business CD, and I am hoping it will work on your E36, because although BMW changes the fascia between the two generations, the software update only accounts for very little change between different versions.
My car was imported from Japan, and due to the lack of this knowledge the dealer installed a band expander!
Apologies if this does not work on the E36, but it might be worth a try
Good luck!
PS. Yay! my first post!
I've accessed to the radio menu and saw the SN
But then, I can't use the + and - buttons,
Trying other ways Ive found
GAL 1 GAL 2
GAL 3 GAL 4 etc,
Somebody knows more about it?
puntoloco
Pero porque hablan ustedes en ingles? Se os va la pinza, como empiece yo a subir bricos en hebreo..
jaja lo mismo me pregunte cuando leí en ingles, solo respondí por si nuestro colega no habla español!
La radio de mi Z es igual a la de la foto, no como la del video.
es muy raro que no pueda usar los teclados de + o - .
Un taller especializado me comento que puede resetear la radio y hacer que capte las señales EUROPEAS aunque me dijo que tarda un par de horas ya que también reconfigura luces, parte eléctrica, etc.
Lo que no quiero es que afecte el sistema central.
Que me aconsejan? Es cierto lo que me dijo el mecanico?
Castanya
Jajajajajaja
Respondí en español citando un post de un hilo de un foro de Nueva Zelanda (lugar en el que pensé que podia existir esa problematica) El caso es que lógicamente no traduje la respuesta por no resultar impreciso. Eso sí n me digas que no es iinsólito que tengas la radio acotada en frecuencias de Japón... jjejeje
