Hola, tengo el coche dos meses y ayer le conecté el carly dándome 5 fallos. Como lo tengo en garantía he pensado en llevarlo a que me lo miren, pero que les digo... oye mira he visto con un obd2 que marca estos fallos? me dirán algo? No se que hacer
Este es el informe: Carly Diagnostics Report Date: 2019-02-20 Model: 1 (F20, F21) Build Year: 2017 ECUs: 17 Fault Codes and Info Memory Entries: 50 Motor Control Engine / Motor INFO 2AD400: CC message (ID 450): Auto Start Stop function deactivated INFO 277F00: DDE control unit internally (Recovery suppressed): Recovery occurred INFO 290800: Rail pressure control mode, plausibility: Undesirable switching from CPC (coupled pressure / quantity control) detected on flow control ABS / DSC / Brake Dynamische Stabilitäts Control / DSC Centralita OK, no hay códigos de fallos Heating / AC Air conditioning / Klimaanlage INFO 078022: message (vehicle condition 0x3A0) is missing INFO 07802B: COMM_E_NET_START_IND_CHANNEL_0 INFO 078043: LINIF_E_RESPONSE Immobilizer System Body Domain Controler INFO 804029: SEK battery undervoltage INFO 8040CB: Terminal 15 off via Timeout Cruise Control Active cruise control / Aktive Geschwindigkeitsregelung Centralita OK, no hay códigos de fallos Audio/Navi/Communication Infotainment INFO 8BAC73: NVM_E_REQ_FAILED INFO 100C01: System Crash INFO 101777: Reset: crashed process or canceled INFO 930002: Transmitter-receiver module (FOT): temperature exceeds threshold 1 INFO 93000C: Audio Source: Channel can not book in time (allocate) INFO 101742: A recovery function has been activated Chassis Steering /Lenkung Centralita OK, no hay códigos de fallos Body Rear Electronics Module / Elektronik Modul hinten 804876: :FRA output H L defective 804881: :Output RFS defective L INFO E59418: CAN message, vehicle condition (FZZSTD): Invalid signals Integrated Chassis Management Quer/Längsdynamik 482791: :LDM feature high-level navigation data flawed INFO 482740: AUTOSAR - Standard Core - CAN - Interface - Send buffer full INFO 030850: FAS - bull - triggered braking level 1 INFO 03081F: FAS - bull - triggered acute warning INFO 48276E: AUTOSAR - Standard Core - Non-volatile memory - failed Integitaet INFO 4827F9: QDM SKR - correction factor wheel radius - learning condition 2 INFO 4827F8: QDM SKR - correction factor wheel radius - learning condition 1 INFO 482651: Slip angle estimator - inputs not valid SBS INFO 4827A4: SBS function - pitch rate - error amplitude due to suspected error INFO 4827F4: Embassy errors (agreement navigation graph ID: NAV_GRAPH_MATCH) - Timeout INFO 4827F5: Embassy error (navigation system information, ID: NAV_SYS_INF) - Timeout Other Advanced Crash and Safety Management (ACSM) Centralita OK, no hay códigos de fallos Central Gateway / zentrales Gateway CD0487: :Synchronization process failed, CC was not in sync with the date of repeal of error Memory Lock / FLEXRAY StartUpFailed 801C15: :Faulty asleep at 30B INFO 101008: not resolvable ambiguous routing - SG is not in the target table SVT INFO 100600: FlexRay protocol startup time is too high INFO 100100: lost contact with FCM slave INFO 100104: HW Weckgrund ZGW INFO 100300: Commissioning could not be performed because TAS already busy INFO 100001: VcmResultSvtCheck - Identity check: There are differences between the SVT and is recognized SVT target. INFO 100203: DM software error Info Warning INFO 100204: Botschaftsueberwachung: failed system context signal Getriebesteuerung /Transmission INFO 420801: E circuit: Info counter for automatic insertion of P when the vehicle is leaving INFO 421732: E circuit: Info counter for N-holding phase Frontlichtelektronik links INFO D9D503: message (V_Veh): Timeout Elektronische Fahrzeug-Immobilisierung INFO DA1503: message (V_Veh): Timeout Gear switch / Gangschalter Centralita OK, no hay códigos de fallos Advanced Telematic Module INFO 610019: NVM_E_INTEGRITY_FAILED INFO E14405: Timeout CAN message MILE_VEH INFO E14406: Timeout CAN message GPS_PO_EXTS_MOST INFO E14426: Invalid signal in CAN message GPS_PO_EXTS_MOST INFO E1442C: Invalid signal in CAN message STAT_ZV_KLAPPEN INFO E14413: Timeout CAN message STAT_GANG_RUECKWAERTS INFO E14414: Timeout CAN message STAT_ZV_KLAPPEN INFO E14437: Invalid signal in CAN message GPS_PO_MOST Central Control / Zentrale Bedieneinheit Centralita OK, no hay códigos de fallos
A veces los coches guardan fallos que no tiene porq estar mal el coche...a veces hasta cuando salta baja temperatura exterior o cuando esta bajo de gasolina te guarda poca presion de gasoil...tu vete si te quedas trankilo...pero no yo no iria por algo asi...solo te lo van a borrar y listo...
Con el carli ese no se puede. Modificar. Nada no? Entonces no creo que te digan nada por haberlo usado para ver el estado del coche, creo
Da muchos errores,algunos sin ninguna importancia, intranquilizando al usuario. Por esas cuestiones me gusta Caristaapp,distingue los antiguos,de los aún existentes.
Borrarlos y listo. A mi también me sucedió al ser nuevo y pasarle Carly me daba vario fallos entre ellos Gestion de motor , pase por BMW y no le encontraron nada. Seguramente tengan los de Carly ajusta más la aplicación . Podrías también enviarles un correo con esos fallos a ver qué te cuentan.
A mi me pasa igual con mi coche, Paso carly y me salen unos 8 fallos sin embargo en la casa aparecen muchos menos 2 fallos y esporádicos.
Esta app,da más fallos de los necesarios,suele haber la creencia que sí, detecta fallos es mejor el producto. Muchas veces cuesta descifrar que es,y como solucionar,para lo caro que es, la descripción de defectos,es bastante escueta.
Buenas gente!! A mi también me salen 11 fallos, tanto como manipulación de los kilómetros, pero el VIN que me da en ese error no se corresponde con en el coche.
Hola, A me pasa parecido. Paso el carly y salen un montón de fallos. Haz como te dicen, borra con el carly los fallos y vuelve a pasar el análisis de fallos. Después de hacer eso a mi se me borran un montón de fallos y suelen quedar 2 recurrentemente. Cuando lo llevé a la BMW a hacer una revisión se lo comenté y al pasar su maquina no salió nada. Saludos.
