B1214_M0UBH
171 Plausibility, system, engine throttle P0601 B1214_M0MDK
B1214_M0SGS
B1214_M0UBH
172 Signal, driver's-wish sensor,potentiometers 1 and 2, short circuit P1542 B1214_M0MDK
173 Signal, throttle sensor, potentiometers 1 and 2, short circuit P0120 B1214_M0MDK
174 Throttle sensor, potentiometer 1/2, adapt'n P0120 B1214_M0MDK
175 Driver's-wish sensor 1, adaptation P1542 B1214_M0MDK
176 Driver's-wish sensor 2, adaptation P1542 B1214_M0MDK
186 Voltage excursion before cat.sensor,bank 1 P0134 B1214_M0LV1
187 Voltage excursion before cat.sensor,bank 2 P0154 B1214_M0LV2
188 Heat output, oxygen sensor bef.cat., bank 1 P1132 B1214_M0LV1
189 Heat output, oxygen sensor bef.cat., bank 2 P1133 B1214_M0LV2
190 Heat output,oxygen sensor aft. cat., bank 1 P1186 B1214_M0LH1
191 Heat output,oxygen sensor aft. cat., bank 2 P1187 B1214_M0LH2
202 Oxygen-sensor control, bank 1, control stop P0170 B1214_M0LV1
203 Oxygen-sensor control, bank 2, control stop P0173 B1214_M0LV2
204 Plausibility, idle speed (leakage air) P0505 B1214_M0GAB
208 Speed monitoring not plausible EWS B1214_M0EWS
209 EWS tampering protection B1214_M0EWS
210 Error in ignition-current measurement at more than 2 cylinders
211 Idle-speed control valve, mechanical fault P1510 B1214_M0LLS
214 Signal, vehicle speed P0500 B1214_M0VSI
215 Signal,oxygen sensor, post-cat. bank 1, no signal P0136 B1214_M0LH1
216 Signal,oxygen sensor, post-cat. bank 2, no signal P0156 B1214_M0LH2
217 Signal CAN EGS P0600 B1214_M0CAN
B1214_M0UBH
219 Monitoring CAN B1214_M0CAN
220 Voltage, oxygen sensor 1, post-cat. , sensor too slow P1184 B1214_M0LH1
221 Voltage, oxygen sensor 2, post-cat. , sensor too slow P1185 B1214_M0LH2
222 Plausibility, coolant temperature P0125 B1214_M0TMO
223 Leap time, oxygen sensor, post-cat. bank 1 P1180 B1214_M0LH1
224 Leap time, oxygen sensor, post-cat. bank 2 P1181 B1214_M0LH2
225 Function, oxygen-sensor control, post-cat,bank 1 P1192 B1214_M0LV1
226 Function, oxygen-sensor control, post-cat,bank 2 P0193 B1214_M0LV2
227 Oxygen-sensor-control. fluct., bank 1,too large P0188 B1214_M0LV1
228 Oxygen-sensor-control. fluct., bank 2,too large P0189 B1214_M0LV2
229 Control frequ., oxy. sensor, bank 1, faulty P0133 B1214_M0LV1
230 Control frequ., oxy. sensor, bank 2, faulty P0153 B1214_M0LV2
231 Switching time, oxygen sensor, bank 1 P1178 B1214_M0LV1
232 Switching time, oxygen sensor, bank 2 P0179 B1214_M0LV2
233 Catalytic-converter efficiency, bank 1 P0420 B1214_M0LV1
234 Catalytic-converter efficiency, bank 2 P0430 B1214_M0LV2
235 Function, oxygen-sen. control, pre-cat.,bank 1 P1190 B1214_M0LV1
236 Function, oxygen-sen. control, pre-cat.,bank 2 P1191 B1214_M0LV2
238 Misfire, cylinder 1 P0301 B1214_M0AUS
239 Misfire, cylinder 2 P0302 B1214_M0AUS
240 Misfire, cylinder 3 P0303 B1214_M0AUS
241 Misfire, cylinder 4 P0304 B1214_M0AUS
242 Misfire, cylinder 5 P0305 B1214_M0AUS
243 Misfire, cylinder 6 P0306 B1214_M0AUS
244 Segment timing, true running disturbed B1214_M0KWG
245 Flow rate, sec. air system, too low, bank 1 P1423
246 Flow rate, sec. air system, too low, bank 2 P1421
247 Secondary-air valve open,stuck mechanically
