Codigos de error 06,67,32 de un 528ie39
  • Iniciador del tema Fanatic
  • Fecha de inicio
F
Fanatic
Guest
Ayer fui al taller y me dieron una revision completa y estos son los codigos que arrojo la computadora
X431 DIAG Report LAUNCH
Total codes:003
CODE001:
06 Wheel speed signal, front right
CODE002:
67 Intermittent interference
CODE003:
32 Wheel speed signal, front right.
Me comenta que el balero delantero izquierdo necesita ser remplazado, y las balatas traseras, pero me dice que esos codigos pueden ser de ABS alguien sabe de que pueden ser?
dael
en el taller que te los ha sacado no saben que es cada codigo??? :-k:roll:
F
Fanatic
Guest
Encontre esto,
[FONT=Arial, Helvetica, sans-serif]ABS, ASC/DSC, ECM FAULTS
[/FONT][FONT=Arial, Helvetica, sans-serif]MODELS AFFECTED[/FONT][FONT=Arial, Helvetica, sans-serif]: E38(7 series)
FAULTS: The wire harness can get damaged. ABS, ASC/DSC ECM faults show:
- 66 wheel sensor signal supply voltage
- 67 intermittent interference
- 5,6,7 wheel speed (plausibility)
- 30 left rear wheel sensor
CAUSE: The sharp edges on the tilt sensor(NAG) bracket damage the wire. The leak diagnosis pump(LDP)
and the wire harness from the left rear wheel sensor is routed through the slot in the tilt sensor(NAG)
bracket.
SOLUTION: Remove the tilt(NAG) sensor, located behind the wheel arch in the left side of the trunk. Tape
the sharp edges of the tilt sensor bracket with electrical tape to prevent further damage to the wire harness.
Repair the wire harness and reinstall the tilt sensor. Using the DIS tester clear the fault codes.
[/FONT]
