¿Alguien tiene de algun sitio el codigo de errores de cuadro del Serie1 E87? Son del estilo CC-ID xxx. He encontrado los errores del e46, pero necesito los del Serie1: http://www.ultimate-bmw.com/bmw_knowledgebase/bmw_obd_and_fault_codes.htm Muchas gracias y un saludo!
joe, yo lo encontré en una web alemana creo :S a ver si te lo encuentro, pero casi no cuentes con ello :S
a ver si es esto!! está en inglés (casi mejor que en alemnán :S:S jeje) BMW Service Codes 00000000 through 0999999900110170 E34/E38 M60B30 Secondary air shutoff valve 00110171 E31/32/34/38 M60 automatic USA piston ring wear detectors 00110174 E34 M60 HS Cylinder wear detectors 00110175 E31,32,34,38 M60 Cylinder wear detectors 00110176 E31,32,34,38 M60 Cylinder wear detectors 00110178 E36 318tds Oil dipstick 00110179 E36/M52 DME File Update (cylinder wear detectors, M52) 00110184 E31/E38/E39 M62 Crankcase 00110185 E38/E31/E39 with M62 - Crankcase base plate - only VPC NU 00110202 R53 Replacing crankcase ventilation line 00110301 E36 328iA US An additional tensioner pulley is missing 00110302 E46 E60 E61 E83 M57/TU - Replacing engine (crankshaft) 00110401 E36/M52 - Lambda probe plug is not located 00110402 E53 M57/TU Replacing engine 00110501 E36 M52 B20 Israel Cylinder barrel surface wear detector 00110502 E87 M47/TU Replacing turbocharger 00110601 E36 Coolant hose rubs on the oil filter housing 00110602 E65 M57/TU Reworking acoustic cover for engine 00110801 E39 LHD M62 - Engine support trestle rubs 00110802 E46 M47/TU Replacing intake manifold 00110901 E36 - O-ring between oil filter and timing cover case 00110902 E60 S85 Replacing engine oil pump 00111001 E36/M43 - Piston rings 00111401 E36 S50 B32 VANOS needle bearing 00111501 E36 M44 Front intake support (ZA only) 00111601 E39 M52/B25 Special engine with cast iron crankcase (SA 961) 00111701 E31 E38 M73 US short circuit/short circuit to ground in Lambda probes 00111801 E36/7 E38 E39 E46 M52 LEV/EU3 Oil filter housing 00112001 E36 US M44 Short circuit to eartch/open circuit in oxygen sensors 00112101 E36 US M42 Routing of Lambda probe cable 00112201 E46 M43 Oil dipstick too long 00112301 E36 M52 B25 Retrofit special-purpose motor with GG crankcase (SA 961) 00112401 E46 Replace M47 power unit 00112501 E39 Coolant hose - hose spacers 00112601 E36 E38 E39 E46 M41 M47 M51 vacuum pump 00112701 E46 M 47 Cylinder head leakage tightness 00112801 E46 M47 Replacing piping system, EGR valve, support bracket for EGR cooler 00112901 E46 M47 Replacing EGR valve, piping system 00113001 E46 M52 (US+RHD) Vacuum line, secondary air valve 00113101 E36 E46 M43 Drive belt pulley for A/C compressor loose 00113201 E39 M52 RHD Engine cover 00113301 E36 E46 M41 M47 Incorrect installation of big-end bearings 00113401 E38 E46 M57 M47 Replacing cylinder head bolts 00113501 E36/7 (with SA 199) exhaust emission values incorrect 00113601 E36/3 E38 E39 M51 Cylinder head gasket leaking 00113701 E36 E46 M44 M43 Valve spring incorrectly fitted 00113801 E39 M5 S62 Fan clutch 00113901 E38 E39 M57 Retrofit acoustic cover edge protector 00114001 E39 M5 S62 Leak from lower section of oil pan 00114101 E31 E34 E38 M60 US MY95 NOx limits exceeded (oxygen sensor) 00114201 E36 E38 E39 M52 Control characteristics of double-plate thermostat 00114301 E31 E38 M73 US Crankcase breather 00114401 E39 M5 Ground strap at cylinder head 00114501 E36/7 M52 Incorrect installation of coolant hose 00114601 E53 Oil dipstick incorrect 00114801 E38 M62 Oil hose between oil filter and engine twisted - correction 00114901 E36/2/4/7/C ECE (S50 B32) VANOS cover threaded connection 00115001 E36 E39 M52 Nikasil engine conversion (CKD Vietnam) 00115101 E52 S62 Quick-release couplings for oil lines 00115201 E52 Tip of dipstick broken 00115401 E36/5 Support for intake manifold loose 00115501 E46 M54 Coolant hose without chafe guard 00115701 E46 S54 Crankshaft big-end bearing - engine replacement 00115801 E39 E52 S62 Replacing intake air duct of intake plenum 00115901 E38 M67 Replacing camshaft sprocket + drive gear for high pressure pump 00116001 E46 S54 Finger retaining clip 00116101 E36/7 E39 E46 M52TU Characteristic map thermostat 00116201 E36/7 E46 S54 Oil change 00116301 R50 R53 (MINI) Engine oil change - SIA 00116401 E46 S54 Intake camshaft oil lubricating channel 00116501 E46 S54 Crankcase oil hole 00116601 E36/7 E39 E46 M52 (US) Crankcase breather 00116701 E46 M47TU Replace turbocharger 00116801 E46/5 N42 (SA 842) Crankcase ventilation 00116901 R53 Replacing vibration damper 00117001 E46 N42 (CKD) Balancing shafts 00117101 E46 N42 Replacing banjo bolt in cylinder head 00117201 E38/3 Oil pump bolt connection 00117401 E53 M57 Reworking intake system 00117501 E46 M54 Checking oil duct supply (VPC Japan) 00117601 E46 S54 Big-end bearing 00117701 E46/4 M47/TU (ZA) Replacing exhaust turbocharger 00117801 E85 M54 Retightening threaded connection of belt tensioner for air conditioner drive 00117901 E46 M54 Replacing bracket for secondary air pump 00118001 E46 M47/TU Reworking threaded connection for vibration absorber 00118101 R50 W17 Check hose clip on pressure hose for intercooler 00118301 E46 M47/TU (ZA) Replacing exhaust turbocharger 00118401 E65 E53 E46 M57 Replacing crankcase breather line 00118501 E65 E66 Retightening oil drain plug 00118601 E60 E63 E65 E66 N62 Replacing intake manifold 00118701 E53 M54 Replacing belt tensioner 00118801 E60 N62 Adjusting minimum valve lift, Valvetronic 00118901 E65 E66 E67 N62 N73 Replacing check valve 00119101 E53 HP Removing tab on dipstick guide tube 00119201 E46 E60 E65 E83 M57/TU Piston coating defective 00119301 E46 M47/TU (SA 185 / 186) Replacing torsional vibration damper 00119401 E46 S54 Replacing connecting rod bearing shells and connecting rod bolts if necessary 00119501 E46 S54 Replacing big-end bearing shells (2. KDB) 00119701 E53 Replacing N62 B48 engine 00119801 E46 M57/TU Replacing dipstick 00119901 E46 E60 Replacing engine 00120111 E30/M20 Japan wearing protection for motor wiring harness 00120158 E38 M60 Oil level sensor 00120159 E38 M60 (with independent fuel burning heater) cold start 00120160 E36 M52 B20 Protective pipe on battery+ hose 00120161 E36 M52 B20/B28 DME-electronic control unit, final stage 00120163 E34 DME Fault storage 00120166 E31/E38 M73 Ignition unit priming plug 00120201 E36 M52B28 US Incorrect program status OBD2 00120301 E36 M52B28 US Incorrect poling of the secondary air pump 00120302 E85 M54 Retrofitting power supply for thermal oil level sensor (TÖNS) 00120501 E31 M73 Replace the pedal evaluator 00120601 E31 M73 Block up the electronic engine performance regulator bypass hose 00120701 E38 M73 Check the pedal evaluator 00120801 E38 M73 Check the electronic engine performance regulator wiring harness connection 00121001 E36 S52 Overspeed storage in the DME-electronic control unit 00121101 E31,E34/M60,M62 Porous oil level float switch 00121201 E38,E39 M51,M52,M62,M73 Failure of the safety module 00121301 E39 DME-electronic control unit - chassis number not programmed 00121401 E36/S52 DME Data status 00121501 E36/Z3 US with M52B28 - DME Data status 00121601 E36 E39 M52 B28 US (not including Z3) DME fault code entry, oxygen sensor 00121701 E36/M44 Engine wiring harness/line to injection valves 00121801 E46 M43, M52 Connector on crankshaft pulse generator not clipped in 00121901 E36/5 M43 B16 DME malfunctions/failure 00122001 E46 M43 M52 Camshaft pulse generator 00122101 E46 M43 Failure of oil-level sensor 00122301 E46 M52 B25 (Belgium) incorrect construction DME control unit 00122501 E38 E39 M62 B+ starter cable defective 00122601 E46 M43 Seal for plug connector of oil level sensor 00122701 E36 E39 M52 S52 US Crankshaft position/rpm sensor failure 00122801 E39 M5 S62 DME control unit + engine oil 00122901 E38 M73 LEV US Wiring harness fault at DME control unit 00123101 E38 E39 M62 M73 LEV Alternator regulator malfunction 00123201 E46 M52 US (with SA 205) Fault code memory check not possible with Scan Tool 00123301 E39 M5 Engine wiring harness chafing 00123401 E38 Threaded connection of battery negative lead loose 00123501 E46 E36/C Threaded connection of battery negative lead 00123601 E36/7 E39 E46 M52 US OBD Fault memory inquiry/readiness code 00123701 E39 E52 (preproduction) S62 DME main relay 00124001 E36/7 M52 Engine cooling - reprogramming DME 00124101 E39 M5 US Readiness Code cannot be read out 00124201 E38 M73 Increasing idle speed 00124301 E38 M73 Replacing drive belt and alternator 00124401 E39 E52 S62 DME control unit defective 00124501 E52 (ECE) E-OBD interface 00124601 E52 B+ battery lead installed incorrectly 00124701 E46/5 316ti A DME control unit program change 00124801 E46/16 M54 Reprogram DME control unit 00124901 E53 M54 US DME control unit: Thermostat diagnosis 00125001 R50 R53 (MINI) Battery positive lead chafes against coolant hose 00125101 E52 S62 B+ cable fitted incorrectly 00125201 E36/7 E46 M52B20 Reprogram DME (engine cuts out) 00125301 E46 N42 Alternator, faulty threaded connection 00125401 E36/7 E39 E46 E53 M54 DME ECU Program - (E-)OBD lamp activation 00125501 R50 US DME Program control unit - emission check 00125601 E46 Replace alternator 00125701 E36/7 E39 E46 E53 M54 Programming DME control unit 00125801 E65 E66 Replacing integrated supply module (IVM) 00125901 E39 E46 M54 - Wiring harness engine ignition module 00126001 E46 M56 Adapter terminal 30 H 00126101 E46 M54 M56 Replacing starter motor 00126201 E46 M56 Programming DME control unit 00126301 E53 M54 Programming DME control unit (A/C compressor) 00126401 E85 Programming DME control unit (oil level warning threshold) 00126501 R50 (CVT) Programming DME control unit 00126601 E85 Programming DME control unit (fan) 00126701 E46 M56 Programming DME (knock control) 00126801 E46 M56 Programming DME (idle speed stability) 00126901 E65 E66 N73 Programming DME control unit 00127001 E65 E66 N73 Changing vehicle order (retrofitting SA 858) 00127101 E46 N42 Replacing ignition coil 00127201 E65 E66 N62 Programming DME control unit 00127301 E65 E66 N62 Replacing ignition coil 00127401 E65 E66 N62 Programming DME control unit 00127501 E85 Programming DME control unit (fuel tank vent valve check) 00127601 E46 N42 Replacing alternator 00127801 E46 S54 CSL Replacing screws for throttle valve actuator 00128001 E46 N42 A Programming DME control unit 00128101 R50 R53 US Programming DME control unit 00128201 E83 Programming DME control unit (fan application) 00128301 E53 E60 E63 E65 E66 N62 Programming DME control unit 00128401 E83 M57/TU Retrofitting adapter lead for crankcase breather heating element 00128501 E60 M54 B30 US Programming DME control unit 00128601 E60 M54 B30 Programming DME control unit (catalytic converter heating) 00128701 E53 E65 E66 N62 N73 Programming control units (closed-loop lambda control diagnostics) 00128801 R50 R53 US Programming DME control unit 00128901 E60 M54 US Programming control units (DME control unit) 00129101 E53 M54 (manual gearbox) programming DME control unit (handling) 00129201 E87 N45 Replacing DME control unit (condenser) 00129301 N62 N73 Replacing DME control unit (condenser) 00129401 E46 N45 Replacing DME control unit (condenser) 00129501 E87 Retightening screw connection, battery ground point 00129601 E60 M54 B22 (Automatic) Programming DME control unit 00129701 E87 N46 Programming DME control unit (oxygen sensor) 00129801 E60 E63 E64 N62 US Programming DME control unit (diagnosis, lambda control) 00129901 E83 M47/TU Correcting routing of wiring harness to crankshaft speed sensor 00130142 E36 S50/B30 Throttle valve potentiometer 00130401 E31 E38 M73 Exchange the throttle valve protection 00130501 E31 E38 E39 M62 - Injection strip 00130601 E36/316G, E34/518G - CNG/DME electronic control unit file update 00130701 E36, E38, E39 with M52 - Coolant hose for throttle valve preheating 00130801 E36 US - 3/2-way valve on body floor assy 00130901 E39 M52 CKD mounting of injection rail on intake manifold 00131101 E38 E39 M57 DDE control unit, capacitor defect 00131401 E38 E39 M51 Converting engine breather hose 00131501 E34 E36 518g 316g Replacing pressure control unit 00131601 E39 M51 Seal for fuel feed line 00131701 E39 M5 Formed hose in idle system 00131801 E39 E46 M57 Engine stalls during warm-up phase 00131901 E38 M67 Fuel filter 00132001 E46 M54 B30 Fuel filter pressure loss 00132101 E46/4 M57 A DDE data status incorrect 00132201 R50 (Mini) Fuel rail 00132301 E38 M62 (with SA 823) Air cleaner element in intake silencer 00132401 E46/5 N42 Fuel line 00132501 E38 E39 E46 E53 M57 Transmission emergency program (DDE control unit) 00132601 E46 M47 (318d) Reprogram DDE control unit 00132701 E65 Rubber gaiter on throttle assembly 00132801 E46 M47/TU Program DDE (exhaust turbocharger) 00132901 E65 N62 Replacing throttle valve assembly 00133001 E65 M57/TU Reworking intake port 00133101 E65 M57/TU M67 Reworking threaded connection for charge air temperature sensor 00133201 E46 M47/TU Programming DDE control unit 00133301 E46 M47/TU (ZA) Programming DDE (exhaust turbocharger) - prior to delivery 00133401 E65 M57/TU RHD Programming DDE control unit (Tempomat) 00133501 R50 W17 Replacing DDE control unit 00133601 E65 E66 N73 Replacing fuel injectors 00133701 E65 E66 E67 N73 Fuel line, loose 00133801 E65 M57/TU M67 Checking injectors 00133901 E46 M47/TU Checking injectors 00134001 E46 M47TU Replacing presupply pump 00134101 E46 M47/TU Checking injectors 00134201 R50 W17 Programming engine control unit (DDE) 00134401 E46 M57/TU Replacing pre-supply pump 00134501 E83 M57/TU Replacing unfiltered air gaiter 00134701 E83 M57/TU Securing fuel lines 00134801 E60 M57/TU Reworking plug connection for crankcase breather heating 00134901 E60 E63 E64 N62 Retrofitting clip for quick-release coupling of fuel line 00135001 E83 M54 (SA 199) Retrofitting plug at fuel tank vent valve 00135101 E87 M47/TU Installing bypass plate in air cleaner housing 00135201 E60 E61 M57/TU Programming DDE control unit (diesel particle filter) 00135301 E60 E61 M57/TU Replacing hose for exhaust backpressure sensor 00135401 E87 N45 N46 Retrofitting clip on fuel line 00160102 E34 Preparation of the catalytic converter - assembly mistake during tank aeration 00160112 E36 M50 US Tank aeration line 00160114 E38 M60/62/73 Fuel pipe in the engine space 00160115 E38 - Fuel pipe in the engine space (without USA,Canada,Japan) 00160301 E36 M42 LA804 Closed active carbon filter drain hose 00160401 E36/Z3 Contaminated fuel tank 00160501 E36/4 US Incorrect fuel pipe 00160801 Z3 /M44, M52 - Fuel line makes contact with carbon canister 00160901 E36 without /5/7 Fuel supply line at delivery unit 00161201 E46 Fuel return line leaking 00161401 E46/C US Distributor (fuel system) incorrect 00161501 E46 Expansion tank hose clamps 00161601 E46 E52 Fuel tank leakage diagnosis module 00161701 E36/2/3/4/C Leak in fuel hose at in-tank pump 00161801 E53 Breather connection piece, fuel tank leak 00161901 E38 E39 Carbon canister 00162001 E53 Tank system fitted incorrectly 00162101 R50 Fuel feed line 00162201 E38 Hose clip, fuel line 00162301 R50 R53 MINI Fuel filler pipe 00162401 R50 R53 MINI fuel hose chafes against clip 00162601 R50 R53 Ground strap, fuel filler pipe 00162701 E53 Fuel suction jet pump O-ring 00162801 R50 R53 Replacing fuel filler pipe 00162901 E46 - Checking vent line to carbon canister 00163001 E60 Fuel tank mounting 00163101 E85 Replacing pressure regulator 00163201 E46 M56 Replacing carbon canister 00163301 E85 Replacing fuel tank screw cap 00163401 E39/2 Replacing suction jet pump 00163501 E85 Retrofitting resistor for fuel pump 00163601 E83 M57/TU Replacing fuel tank 00163701 E53 Reworking lock mechanism for suction jet pump 00163801 E87 Replacing fuel pump 00170114 E34,36 M42,43,44 Radiator (jammed) 00170401 E46 Cooling module, radiator adjusting screw 00170501 E31 E32 E34 E36 Replacement of radiator cap (USA) 00170601 E31 E32 E34 E36 Replacement of radiator cap (rest) 00170801 E38 M73 Ventilation line to expansion tank closed off 00170901 E38 E39 M62 LEV Coolant return hose chafes against metal gasket 00171001 E53 M62 Transmission oil cooler line 00171101 E46/5 Electric fan 00171201 E46 Electric (main) fan 00171301 E46 Electric (main) fan 00171401 E39 E46 E52 E53 Replace radiator cap 00171501 R53 Intercooler bolt connection (corrosion) 00171601 R50 (SA 823) Radiator hose rubs against alternator 00171701 E46 N42 Checking routing of coolant hose 00171901 E65 M57/TU M67 Replacing intercooler 00172001 E65 E66 N62 Retrofitting mounting bracket for transmission oil cooler pipe 00180104 E36/5 Heat shield plate 00180201 Z3 Exchange catalytic convertor 00180301 E36 M52 Catalytic convertor screw connection /secondary silencer 00180401 E36/7 Z3 M44 Exhaust system damper is missing 00180501 E36/5 M52 Exhaust system mounting bracket 00180701 E39 M52 LHD Retrofit additional exhaust support 00180801 E53 Exhaust pipe extension, sharp-edged 00180901 E36/4/7 M44 US Replacing catalytic converter 00181001 E46 N42 Upgrade to EU4 00181101 R53 Tailpipe trim 00210101 E36/M41 Clutch pipe is broken 00210301 E46 M47 clutch line leaking 00210401 E39 M57 RHD Incorrect installation of clutch slave cylinder 00210501 E36 E46 Clutch release bearing incorrect 00210601 E46 Clutch release bearing 00210701 R53 US/Japan Screw connection, clutch to two-mass flywheel 00210801 R50 Routing clutch pipe 00210901 E39 RHD Checking clutch slave cylinder 00211001 E83 Replacing throttle valve, clutch hydraulics 00220201 E39 540iA US Bumper on the cross member transmission 00220301 E39 M52 Engine supporting arm torque is too low 00220401 E38 E39 Screw connection of engine mounting bracket 00220501 E52 Replacing left engine support arm 00220601 R50 (Mini) Engine mount tightening torque 00220701 R53 Gearbox mount threaded connection 00220801 E65 E66 Threaded connection, right engine mount on engine mounting bracket 00230104 Z3 M43/M44 Shift transmission oil change 00230301 E36 E39 E46 Transmission oil drain plug leaking 00230401 E36 M3 (for option SA 793) Connector gear detection potentiometer 00230501 E36 E46 gearbox securing bolt 00230601 E46 S54 (SMG) Replacing gear recognition switch 00230701 E46 S54 Replacing pipe clamp at SMG gearbox 00230801 E46 M54 Replacing SMG gearbox sensors 00230901 E46 M54 Replacing SMG clutch position sensor 00231001 E46 M54 Replacing manual gearbox 00231101 E60 SA 206 Replacing SMG control unit 00231201 E46 E85 SA 206 Replacing H-SMG control unit 00231301 E85 Programming H-SMG control unit 00231401 R50 R53 Checking transmission - engine threaded connection 00231501 E46 S54 SMG Changing pin assignments for relay 00231601 E46 US Programming SMG control unit 00231701 E46 S54 Programming SMG control unit 00231801 R50 R52 R53 Checking oil fill in manual transmission and topping-up if necessary 00231901 E60 E61 M54 SMG Reworking power supply for SMG control unit 00232001 R50 R52 R53 Checking oil fill in manual transmission and topping-up oil if necessary (KDB) 00240114 E31 M73 US Transmission wiring harness 00240120 E36/323iA LA Japan - Exchange electronic transmission control unit (Jatco transmission) 00240121 E36 323iA Electronic transmission control unit (Jatco) 00240122 E38 725tdsA Transmission control unit lockup clutch converter 00240201 E38,39 M52 Faulty transmission control unit 00240801 E38 M51 AGS control unit, data status faulty 00241101 E38 E39 Automatic transmission (5HP24), ring gear faulty (extension) 00241201 E46 M52 LHD US Drumming noise while coasting in 3rd gear (GM5) 00241301 E38 M62 B35 A-clutch casing 5HP24 00241401 E39 E46 M54 (with 5HP19) Replace transmission position switch 00241501 E36/7 E46 E53 M54 Programming/replacing EGS control unit 00241601 E53 M62 Transmission position switch 00241701 E39 E46 (5HP19) Replace oil screen on automatic gearbox 00241801 R50 Automatic transmission adaptation 00241901 E39 M54 Replacing transmission position switch GM5 00242001 E46 N42 Replacing cover plate for gearbox casing 00242101 E46 - Pressure regulator GM5 00242201 R50 CVT Replacing transmission oil 00242301 E46 M54 US Programming EGS control unit 00242401 E53 M57/TU Threaded connection, bracket for transmission oil cooler pipe 00242501 E60 Replacing automatic transmission 00242601 E53 N62 Retightening gearbox - engine screw connection 00250201 E36 - Incorrectly built in gear lever rod 00250301 E46 M47 Shift lever knob, vibration absorber ground loose 00250401 E46 M52 LHD US Steptronic shift block 00250601 E39 S62 Shift knob titanium line 00250701 R50 ECVT Check automatic selector lever catch 00250801 R53 US Replace transmission gearshift cable 00250901 R50 Gearshift cable on reversing lever 00251001 R50 Retaining bracket on gearshift cable 00251101 E87 Replacing selector arm 00260101 E36 Propeller shaft screw connection 00260201 735iA,523iA,528iA CKD - Propeller shaft screw connection seal on input flange/differential 00260501 E39 M52 M54 Threaded connection of flexible coupling on propeller shaft 00260601 E38 E39 E46 Threaded connection, propeller shaft with rear axle differential 00260701 E39 Threaded connection for propeller shaft at rear axle differential 00260801 E65 E66 Propeller shaft centring sleeve 00260901 E65 M57/TU Replacing flexible coupling 00261001 E46 M57 Retightening threaded connection for propeller shaft 00261101 E60 M57/TU Checking propeller shaft and replacing if necessary 00270101 E53 Checking oil filling for transfer box 00270201 E83 Replacing transfer box 00310113 E36/4 Spring strut 00310114 E36/5 Front axle wishbone screw connection 00310115 E34 Front axle cross beam 00310117 E36/4/5 Lower spring strut screw connection 00310201 E38 Front axle springs break 00310701 E36 Wishbone screw connection on engine mount 00311301 E39 Swivel bearing 00311401 E39 Screw fitting of tension strut on swivel bearing 00311601 E39 M5 Threaded connection for stabilizer link 00311701 E53 M62 Front axle differential O-ring, oil pan 00311801 E46/16 Front axle carrier, threaded insert 00311901 E53 M54 Front axle differential, oil change - Bremerhaven 00312001 E53 M54 Front axle drive oil change - 1500km 00312101 E53 M54 Front axle drive oil change - 1st engine oil service 00312201 E38 Replacing front axle spring and spring mount 00312301 R50 MINI Replace control arm 00312401 R50 R53 MINI Replace front axle carrier 00312501 E39 E46 Mount, front spring strut 00312601 E39 E46 Support bearing, spring strut front (without VPC) 00312701 E46 Bolt connection, spring strut front 00312801 R50 Replace output shaft 00312901 E66 Replacing spring strut, front 00313001 E60 Replacing coil spring, front axle 00313101 E53 Reworking threaded connections on engine 00313201 E65 E66 Replacing front stabilizer bar 00313301 E39 Retrofitting retaining clip on front strut tower 00313401 E46 (with SA 815) Retrofitting rough road package 00313601 E67 Replacing front axle springs 00313701 E65 E66 Checking EDC front axle shock absorber and replacing if necessary 00313801 E87 Reworking screw connections on front axle 00320122 E36 320i/4 325i/4 US Knee protector stiffening brace 00320123 E34 Wishbone tapered spigot 00320124 E34/E36 M50 Duroplast belt pulley 00320125 E36/5 Steering stop limit 00320126 E38/M62 RHD - Heat shield plate for track rod 00320127 E39 Track rod screw connection 00320201 E39 M62 LHD Power steering heat shield hose lies on the exhaust manifold 00320301 E31,32,34,36 Locking unit in the steering wheel in broken 00320401 E36 RHD Steering spindle corrosion 00320501 E36/5 RHD Steering spindle screw connection 00320601 E36 Z3/318i US Steering wheel screw connection 00320801 E36/7 Z3 Airbag module screw connection 00320901 E39 M52 Steering assistance pump mounting connection 00321001 E36 - Steering angle limiter is missing / incorrect tyre setting 00321501 E34/M50 Duroplast pulley for power steering pump 00321601 E39 M52 Power steering expansion hose 00321701 E36 M50 M52 Power steering pump pulley (ZJ only) 00321801 E36 Steering lock limiter not installed 00322101 E36/5 E46 Track rod threaded connection, front axle 00322301 E38 M73 LEV RHD Incorrect installation of steering expansion hose 00322401 E46 M52 Flexible coupling threaded connection 00322501 E39 M5 Power steering pump threaded connection 00322901 E53 Double joint at bottom of steering shaft scrapes against engine support 00323001 E36/5 E46 Track rod threaded connection 00323301 E53 (With SA 216) steering wheel return inadequate 00323401 E53 M54 US Steering column installed incorrectly 00323501 E46 Toe setting, front axle 00323601 E53 Track rod at steering gear, threaded connection, axial joint 00323701 E36 RHD Steering spindle corrosion 00323801 E53 Bottom of steering shaft at double joint 00323901 E52 Retrofitting electric steering lock ELV adapter lead 00324001 E53 Threaded connection, power steering pump pulley 00324101 E46 N42 Check routing of pressure hose for steering 00324201 R50 R53 US Steering angle sensor mounting 00324301 E39 E46 M54 Replacing power steering pump 00324401 E46 Tightening down steering wheel screw connection 00324501 E46 Threaded connection for track rods 00324601 E39 Threaded connection for power steering gear on front axle carrier 00324701 E46 Adjusting toe-in 00324801 E46 Checking track rod threaded connection (scope II) 00324901 E65 E66 Checking power steering 00325001 E65 E66 Checking breakaway torque of power steering pump pulley (VPC) 00325101 E65 E66 Power steering pump pulley 00325201 E60 Active steering - replacing wiring harness and control unit 00325301 E60 Active steering - replacing wiring harness 00325401 E60 M54 Checking hose clip for return line of power steering system 00325501 E83 Retrofitting Pentosin sticker on expansion tank 00325601 E60 M54 (SA 217) Replacing radiator return line 00325701 E60 E63 E64 N62 (SA 217) Replacing radiator return line 00325801 E46 318i Correcting position of lines (power steering) 00325901 E60 E63 E64 Replacing cover for engine position sensor (active steering) 00326001 E46 Checking screw connection of steering shaft 00326101 E46 M54 RHD Correcting routing of expandable hose for power steering 00326201 E83 M57/TU Checking high-pressure line for power steering 00326301 R50 R53 (with SA 508 and SA 895) Changing pin assignments for relay of auxiliary fan 00326401 E60 E61 M57 (with SA 229) Replacing ARS line 00330111 E36 M3 Rear axle bearing 00330113 E38 Rear axle wheel mount 00330116 E34 Rear axle screw connection 00330118 E38 Rear axle carrier 00330401 E39 - Check rear axle shaft wheel fastening 00330601 E39 Deviation of rear left bearing from ideal tolerance 00330701 E39 Deviation of rear right bearing from ideal tolerance 00330901 E39/2 - Rear axle beam 00331301 E39 - Swinging arm screw connection at front of rear axle carrier 00331801 E46 M47 Weld, vibration absorber support bracket 00332101 E38 E39 E46 M47 M52 M62 Threaded connection of crown gear in rear axle differential 00332201 E39 M5 Rear axle bracket replacement 00332301 E36 E46 Eccentric screw, control arm 00332401 E46 Wheel bearing threaded connection 00332501 E39 540iA Output shaft not hardened 00332801 E39 M5 Diameter of stabilizer bar at rear axle 00332901 E46 M57 A Rear axle vibration absorber not fitted 00333001 E38/3 Rear axle control arm 00333101 E38 E39 Threaded connection of output shaft to flange of rear axle differential 00333201 E39 Rear axle threaded connection 00333301 R50 (MINI) Semi-trailing arm, rear axle 00333401 R50 MINI Threaded connection of semi-trailing arm to body 00333501 E65 (HEA) Check position of output flange on rear axle differential 00333601 E65 Check integral link 00333701 E65 Replace eccentric screw guide control arm 00333801 E65 E66 Replace cover on rear axle differential 00333901 E65 E66 Checking output shaft 00334001 E66 Threaded connection for vibration absorber, rear axle differential 00334101 E66 Threaded connection for vibration absorber (VPC) 00334201 E39 Checking rear axle carrier 00334301 R50 R53 Threaded connection, spring strut (VPC) 00334401 E39 Checking RA stabilizer bar 00334501 E39 Checking and if necessary replacing rear axle stabilizer bar 00334601 R50 R53 Threaded connection, semitrailing arm, rear 00334701 E60 Threaded connection, output shaft to final drive flange 00334801 E53 Checking threaded connection of final drive 00334901 E46 Retrofitting rear adapter and damper for rough road package 00335001 E87 Retrofitting plug on final drive unit 00335101 E87 Retrofitting plug in final drive unit (188L) 00335201 E87 Checking rear control arm and traction strut 00335301 E87 Checking position of rear control arm and traction strut 00340112 E36 Japan Break fluid return pipe 00340113 E36 RHD ABS electronic control unit 00340114 E36 Brake boost 00340115 E36 ABS-Sensor 00340116 E38/E39 M52 - Induction manifold bracket 00340301 E31 - Leaky master brake cylinder 00340401 E31,38,39 Leaky hydraulic-unit discharge damper membrane 00340501 E38 Brake pipe rubs on the rear axle carrier 00340601 E36 M52 S50 Incorrect vacuum hose 00340801 E36 - Rubber bushing ABS Mark 20 00340901 E38/750i/L Replace DSC 3 (dynamic stability control) 00341001 E36 - Replace ABS Mark 20 electronic control unit 00341101 E36 US/Compact, Z3 with M44 - ASC spare wheel recognition 00341201 E36 - Brake boost/master brake cylinder 00341401 E39 540iA Steering angle sensor matching DSC 3 00341501 E38 RHD - 750i/L/L7/3 - Vacuum hose brake booster 00341601 E39 Rear ABS sensor 00341701 E36/7 ABS hydraulic modulator connection 00341801 E39/2 Brake hose connection 00341901 E46 RHD vacuum hose brake booster scuffing on earthing point 00342101 E38 M62 M73 Software change ABS 5.7 00342201 E39 M52 RHD Brake booster, incorrect vacuum hose 00342301 E36/7 Vacuum hose clip 00342401 E38 M67 DSC 3 Improved control function 00342601 E39 Hydraulic unit, hole 00342701 E52 Brake caliper bolt connection on front axle 00342901 E38 E39 M57 E46 RHD M47 Vacuum hose, brake system 00343001 E46 (330xiA ECE) DSC variant coding data incorrect 00343101 E53 Mounting, pedal assembly - brake booster 00343201 E46 S54 Parking brake threaded connection 00343301 E46/16 Brake/fuel line spacer 00343401 E53 Threaded connection, brake hose to brake caliper 00343501 E46 Replace brake booster 00343601 R50 R53 Parking brake pushbutton cap 00343701 E46 (325ix) Replace rear brake discs 00343801 R50 R53 Replacing handbrake lever 00343901 E65 E66 Bending cable bracket for brake pad wear indicator 00344001 E65 E66 US Correcting brake pad wear indicator 00344101 R50 R53 RHD (GB, Japan) Replacing handbrake lever 00344201 E53 Retrofitting brake hose retaining clip, front axle 00344401 E39 E46 Brake fluid, CKD Indonesia 00344501 E53 LHD Reworking brake line 00344601 R50 R53 Checking rear brake lines 00344701 E67 Replacing front brake caliper 00344801 E60 E63 E64 E65 E66 E67 E83 Replacing rotation rate sensor 00344901 E46/4 318d Replacing brake discs, brake calliper and stabilizer bar on rear axle 00345001 E60 E63 E64 E65 E66 E67 DSC Replacing rotation rate sensor 00350301 E36 / Z3 Accelerator pedal mounting 00350501 E31, E32, E34, E36, E38 - Cruise control/bowden accelerator cable assy 00350601 E36 / Z3 - Bowden accelerator cable assy fitted incorrectly 00350701 E39 RHD Thrust-rod bolt, clutch pedal (prod. 01/96-08/97) 00350801 E39 RHD Thrust-rod bolt, clutch pedal with bracket for clutch switch (prod. 009/97- 00350901 E46 USA/CAN Brake pedal retaining clip 00351001 E46/2 RHD Replacing accelerator cable assy 00351101 E46 Accelerator pedal module ASCI defective 00351201 E52 Incorrect installation of accelerator pedal module 00351301 E53 Fixing bearing shaft in pedal assembly 00351401 E39 M57 M62 S62 Replacing clutch pedal 00360113 E36/5 SA337 Tyre setup 00360114 E36 M3 Size of rims in the automobile papers 00360115 E39 Damage to tyres 00360401 E39 Damage to front right tyre 00360901 E36/5 - Check wheel nuts 00361001 E38, E39 - Adapter for wheel nuts is missing 00361101 E39/2 Tyres, incorrect speed class installed 00361201 E39 M5 Threaded connection for rear wheel 00361401 E53 Tyre damage 00361601 E46/C Spare wheel (space saver spare wheel) incorrect 00361701 E46 Wheel stud adapter incorrect 00361801 E46 US B25 (with SA 203) Tyres incorrect 00361901 E46/4 (ZA) Check wheel stud tightening torque 00362001 E46/3 Incorrect tyre data in vehicle documents 00362101 E46 Rims damaged during assembly 00362201 E38 (SA 780) Tyre damaged on inside 00362301 E38 E39 E46 (18" tyres) checking tyres 00362401 E38 "Run-flat" safety tyres 00362501 E53 Wheel stud lock adapter incorrect 00362601 E46 E39 Check outer side of tyre 00362701 E46/4 ZA Wheel bolt lock 00362801 R50 R53 Check tyres 00362901 E53 Electronic wheel module RDC failure 00363001 R50 R53 Checking left tyre 00363101 E65 E66 Recoding RDC 00363201 E65 E66 Changing RDC vehicle order (removing SE 876) 00363401 E85 Replacing tyre 00363501 E39 Checking tyres 00363601 E46 Replacing adapter for wheel stud bolt 00363701 E46 Checking wheel studs and replacing rim if necessary 00363801 E83 Checking code - wheel stud 00370301 E53 Two-axle air suspension retrofit 00370401 E38/3 Replacing pressure line for ride-height control system 00370501 E67 Checking rear shock absorber 00370601 E53 Replacing rear air spring 00370801 E67 Replacing shock absorber and mount, rear 00370901 E61 Checking rear air spring and replacing if necessary 00410110 E34 Metal padding in the boot/trunk 00410114 E38 Front end screw connection 00410201 E36 with SA 786 - Flanging for 17" tyres 00410401 E32/3 Mounting of rear-axle bracket tears 00410501 E38 Water ingress body engine compartment 00410601 E38 LHD Automatic, water ingressing through bulkhead 00410701 E46 Spring strut dome seal, rear left 00410801 E39 Adjust boot-lid gap dimension 00411001 E36/7 Coupe Crack in B-pillar 00411101 E39/2 Cracking in tailgate 00411201 E53 Seat belt anchorage, rear 00411401 E46/3 Mounting, bracket for net partition 00411501 E52 Water drain, sill 00411601 E53 Crack in area of shock absorber mounting 00411701 E53 Screw missing in tailgate 00411801 E46/5 Front door corrosion 00411901 E46/5 Fold corrosion on inside/outside of front doors 00412001 E46/5 Corrosion on outside of front doors 00412101 E46 (ZA) Retrofit A-pillar sealing plug 00412301 E65 Check tailgate for cracks 00412401 E39 Checking front spring strut support 00412501 R50 R53 Screw connection, door hinge 00412601 E36/7 S50 Checking bracket for final drive unit 00412701 E46 Side panel, front right 00412801 E67 Retrofitting auxiliary bracket for rear head airbag 00412901 E63 Sealing boot lid 00413001 R52 Checking welds on sill panel 00413101 E53 Checking ground pin for negative battery negative lead 00413201 E87 Reworking ground pin for negative battery lead 00510132 E36/5 Sticker for tyre inflation pressure 00510137 E36/4 318tds Covering for cooling air intake 00510138 E34 with electrical seat adjustment safety ring 00510139 E36 Convertible cover flap covering 00510140 E36 convertible US Tyre pressure information plate 00510141 E36/3 Gas filled spring holder for boot/trunk 00510142 E31 A Noise insulation 00510143 E36 CAB Front reinforcement cross 00510144 E36/4 Seat fastenings 00510145 E36 Compact - Rear side window is not tight 00510146 E38 Door handle holder for Bowden cable 00510201 E39 540iA Raising the total weight when fully equipped 00510301 Z3 Incorrect/missing colour indicator shield 00510401 E38 SA357 Side window burglarproof glass 00510701 E38US E39US Rear electrical window lifter does not function 00510801 E39 US/CAN Broken glove compartment opening handle 00511001 E38, E39, E31 - Observation of the paint 00511401 E36/Z3 - Pin for door arrester strap 00511501 E36/5 - Bearing mount on rear bench seat 00511601 E38 Damper elements safety glass 00511901 E36/7 Guide plate catch hook (USA only) 00512001 E38/3 Windscreen leaking 00512101 E31 E36 E38 E39 Mechanical key code incorrectly documented 00512201 E46 ACT airbag, A-pillar 00512401 E39/3 Side window corrosion 00512501 E38 (With SA 316) Rubber grommet of hydraulic unit 00512601 E46 Jacking point loose 00512701 E36/7 Tyre pressure information plate 00512901 E39 M52 M62 Incorrect installation of heat insulator for rear silencer 00513001 E39 M5 Adhesive joint of rear spoiler 00513201 E36/7 Bonnet (hood) lock pin, lock nut 00513301 E46/2 Tailgate grip handle 00513401 E39 S62 Bottom cover of rear bumper 00513501 E53 Correction of roof load specification 00513601 E53 Replacing window frame finisher on rear doors 00513701 E46/2 Door will not open 00513901 E46/C Air conditioning, front screen - no GPS reception 00514001 E46/3 Tailgate window does not open via pushbutton 00514101 E52 Replace rear lid/tailgate damper 00514201 E53 M62 Oil filter line chafes against brake line (units carrier) 00514301 E38 Incorrect installation of rear door stop 00514401 E46 Underride guard 00514501 E46 No US airbag warning sign on instrument carrier 00514601 E46 Expanding rivet, rear bumper 00514701 E46/5 Spring package, boot lid/tailgate 00514801 E46/3/4 Door sound insulation (front left) not tight 00514901 E46/5 Space saver spare wheel retaining fixture broken 00515001 E53 Bonding of outside mirror glass 00515101 E46/C US Bowden cable, luggage compartment emergency release 00515201 E46/4 (Korea) Replace outside mirror 00515301 E46/5 M47 Replace fuel tank filler pot 00515401 E46 S54 Bumper, towing eye 00515601 E46/5 Tailgate prop 00515701 E53 Replace tailgate handle trim 00516101 E46/5 Under tank panelling 00516201 E65 Retrofit emergency release for tailgate 00516501 E65 E66 Rotary latch lock 00516601 E46 Retrofit heat shield 00516701 R53 Replace rear spoiler 00516801 R50 R53 Threaded connection of battery support bracket 00516901 R50 A-pillar clip (water inlet) 00517001 R50 Wiring harness, body control unit (water inlet) 00517101 R50 Protective cover, body control unit (water inlet) 00517201 E39/2 Replacing rear rubbing strip 00517301 E53 Checking boot lid stop 00517401 E65 E66 US Crash pad inlay 00517501 R50 R53 - Bonnet insulation mat 00517601 E46 LHD Replacing rotary tumbler lock 00517701 E46/4 Replacing rear door window 00517801 E65 E66 Replacing hydraulic lines for automatic boot lid 00517901 E60 Replacing tension spring for boot lid 00518001 E85 Reworking engine compartment shielding 00518101 E46/4 US Replacing impact damper, front left 00518201 E53 Retrofitting splash guard, rear 00518301 E60 Replacing screw plug, luggage compartment 00518401 R50 R53 Replacing sound insulation, bonnet 00518501 E60 US Replacing information sticker for passenger airbag 00518601 E85 (Canada) Replacing both sun visors 00518701 E53 Checking boot lid servo lock, top 00518801 E83 Replacing combination roller blind rod 00518901 E63 E64 US Replacing sun visors (airbag information sticker) 00519001 E83 Reworking undercoating 00519101 R50 R53 US Retrofitting plug in wheel arch 00519201 R52 Replacing trim strips for cross brace 00519301 E87 Reworking cowl panel cover 00519401 E87 Replacing instrument panel trim 00519501 E87 Reworking cowl panel cover 00519601 E87 Checking fit if cowl panel cover 00519701 E46 S54 Checking cavity protection for rear axle support 00519801 E46 E53 E60 E61 E63 E64 E65 E66 E67 E83 E85 (LA Japan) Retrofit. clip for ETC inter. 00519901 E46/3 Replacing luggage compartment net partition 00520401 E36 M3 US Replace head restraints 00520501 E46 Checking threaded connection of seat backrest 00520701 E46/2/4 (with SA 464/465) Backrest frame, left (through-load facility with ski bag) 00520801 E46/C Fastening of seat wiring harness 00520901 E46/C Microswitch for backrest lock indicator 00521001 R50 (MINI) Front seat backrest adjustment 00521101 R50 Mounting, child seat 00521201 R50 R53 (US, Can) Mounting point, child seat 00521301 E65 E66 Replacing head restraint, front 00521401 E85 (with SA 711) Replacing seat padding on both seats 00521501 E83 Reworking threaded connection for backrest mount, rear seat 00521601 E46/2 Checking backrest cover, front seat 00521701 R50 R53 Replacing Isofix covers 00521801 E60 E65 E66 E67 (with SA 494) Reworking backrest heating for front seats 00521901 E61 Checking latch for rear seat backrest and replacing if necessary 00540201 E36/5 Open air - Folding roof sealing junction 00540301 E36/7 Z3 M-roadster arrester strap of tonneau cover 00540401 E52 Tonneau / wind deflector 00540501 E52 Hardtop mount contact ring 00540601 E85 Hall sensor, convertible top position 00540701 E64 Re-securing cord for convertible top 00540801 E64 Reworking convertible top 00540901 R52 Adjusting convertible top (buffer) 00541101 R52 US Retrofitting sleeves and protective caps on convertible top 00541201 R52 (Japan) Retrofitting sleeves and protective caps on convertible top 00610131 E36/4 E36/5 Light relay 00610132 E36/5 (without SA 530) Rear window heating switch 00610134 E36 SA314 Door lock heating relay base 00610135 E36 convertible US Battery 00610136 E36/3 Rear window washer 00610139 E38 Fuel pump electrical connection 00610141 E38 M62/740i US Thermal oil level sensor 00610142 E32/E34/E36 325i US Brake light switch 00610202 E83 Encoding control unit for panoramic glass roof (MDS) 00610301 M3 convertible - Battery+ line rubs in the foot space 00610302 E65 E66 E67 Programming control units (E065-03-12-501) 00610402 E64 (VPC) Programming control units to I-04-03-500 00610501 E36 US Centerlock sensor 00610502 E63 E64 Programming control units (interior protection) 00610602 E65 E66 E67 Programming control units (airbag warning lamp) 00610701 E39 RHD Driver's seat lumbar setting 00610702 E83 (SA 822) Changing vehicle order and encoding instrument cluster 00610802 E64 (SA 6UB) Programming control units (activate SVS) 00610901 E38 740iA US Garage door opener not built in 00610902 E64 Programming control units (CVM coding data) 00611001 Z3 Loose spare battery+ cable 00611002 E83 (SA 494) Encoding control unit for centre console switch cluster (SZM) 00611101 E36, E39 or touring - Exchange vehicle immobilization control unit with SW 03 (vehicle does 00611102 E65 E66 (LA Japan) Programming control unit (seat belt indicator lamp) 00611201 E36/4 - Loose connecting cable to battery in the boot (in part SA 832) 00611202 E60 Replacing light module 00611301 E38/E39 - Multifunctional steering wheel illumination flickers/attach dimmer 00611302 E60 E61 E65 E66 E67 Programming control units (seat occupancy detection) 00611401 E39 with SA 581 - Check taxi set 00611402 E87 Japan Programming control units (reversing gong) 00611501 E39 US - Ignition key warning signal 00611502 E87 RHD Correcting pin assignments at connector for boot lid button 00611601 E39 A - Vehicle immobilization III-electronic control unit 00611602 E60 E61 E63 E64 (SA 6UB) Activating voice recognition system (SVS) 00611701 E38 - Undervoltage protection (cool box) 00611702 E60 (SA 6UC) Activating TV function 00611801 E36 convertible with SA 395 - rollover sensor 00611802 E60 EU E61 EU E65 E66 E67 Performing complete encoding (seat occupancy recognition) 00611901 E38 Rain sensor not encoded 00611902 R50 R52 R53 Replacing airbag indicator lamp 00612001 E36 316i LHD Idle current distributor 00612002 E39 Encoding light check module (LCM) 00612101 E46 Replace left wiper blade 00612102 E87 Checking steering column switch cluster and replacing if necessary 00612201 E39 (With SA 810) Change central coding code 00612202 E53 E85 US Encoding telematics control unit (TCU) 00612302 E60 E61 M57 Programming control units (battery discharged) 00612401 E38/3 Central locking unlocking/locking independently 00612601 E36/7 S50 Throttle operation remaining suspended (relay support) 00612701 E46 Recode US general module 00612801 E38 E39 (with SA 677 and 625) Retrofit of adapter lead, DSP amplifier 00612901 E36/7 M44 S50 S52 Short-circuit on B+ cable 00613001 E36/7 M Roadster/coupe US ASC switch/indicator lamp 00613101 E36/7 B+ lead loose at battery terminal 00613201 E36/7 Retrofitting adapter lead for CD changer-radio 00613301 E36/7 M43 LHD Retrofitting set of cables for speedometer signal 00613401 E38 E39 (not including E38/3 and E39/2) Encode general module 00613501 E39/3 Retrofitting ground lead 00613601 E36/7 US Replacing clutch switch and support bracket for B+ distributor 00613701 E36/7 US Replacing clutch switch for starter inhibit 00613801 E36/7 M43 (without SA 530) Retrofitting double temperature switch 00613901 E46 M47 (with SA 520) Outside mirror heating defective (incorrect door wiring harness) 00614001 E38/3 Vehicle battery discharges 00614101 E39 Reconnecting line for tailgate lock 00614201 E38 E39 E46 Replacing brake light switch 00614301 E46/4 One-touch function, rear door window 00614401 E46 Crimping of seat wiring harness faulty 00614501 E38 M73 Replacing system battery 00614601 E38 M73 Replacing disconnecting switch 00614701 E36/7 M43 RHD Electrical connection, secondary air pump 00614801 E39 M54 Re-encode LCM (VPC only) 00614901 E39 Retrofitting wire in telephone wiring harness 00615001 E53 A RHD Wiring harness installation, gear indicator 00615101 E53 RHD Button for upper tailgate lock 00615201 E38/3 (with SA 182) Replace temperature switch 00615301 R50 R53 MINI Encode key transponder 00615401 E65 Program control units 00615501 E65 Program control units (VPC) 00615601 E46 Replace housing, OBD connector 00615701 E65 Program control units (wiper module) 00615901 E65 Program control units / emergency call switch 00616001 E65 Encode high beam 00616101 E46 Retrofit wiring harness module 00616301 E65 Replace tailgate button 00616401 E65 Program control units (integration stage 6.70) 00616501 E65 US Replace aerial/antenna amplifier + key - program ECU 00616601 E65 Program control units (I 6.54, I 6.55) 00616701 E46 S54 (JPN) Retrofitting gong line (reverse) 00616801 E65 E66 Programming control units (I 6.60, I 6.70) 00616901 E53 RHD Securing wiring harness, steering column 00617001 E65 E66 Encoding light module 00617101 E65 E66 Programming control units (I 6.6x) 00617201 E38/3 Hydraulic window regulator (relay) 00617301 E46/C Encoding IHKA/IHKR and CVM 00617401 E39 Replacing general module 3 00617501 E46 Replacing general module (pressure-sensitive finger guard system) 00617601 E46 Retrofitting electric cable (mirror heating) 00617701 E46/C US Retrofitting electric cable (parking aid) 00617801 R50 R53 Retrofitting adapter cable with diode for auxiliary fan 00617901 E65 E66 Programming control units (lower than I 6.113) 00618001 E65 E66 Replacing battery 00618101 E38/3 SA 182 Sealing temperature switch 00618201 E60 Replacing CAS control unit 00618301 E60 KNG Replacing steering column trim 00618401 E60 US Programming control units (SGM) - VPC 00618501 E60 US Checking rear power distribution box 00618601 E46 Encoding LSZ (light switch centre) 00618801 E60 US Retrofitting felt 00618901 E60 HEA (national version Japan) Programming control units (CCC) 00619001 E60 Programming control units (on-board monitor) 00619101 E65 E66 US Encoding control display (CD) 00619301 E83 Replacing general module (power window) 00619401 E63 Programming control units (E060-03-12-527) 00620201 E39 Engine oil level control light does not function 00620301 E39/2 - Pictogram display in the combi 00620601 E38 E39 With SA 536 replacement instrument cluster 00620801 E46 Japan version, instrument cluster software 00620901 E36/7 US (not including M-models) Re-encoding instrument cluster 00621001 E38 E39 - Changing central encoding code (large-scale test brake light switch SA 037) 00621101 E38/3 Tank characteristic curve coded incorrectly 00621201 E39 Re-coding central encoding code 00621301 E52 (ECE) Replace integrated body electronics module (IKE) 00621401 E65 Replace instrument cluster - speedo dial face 00621501 R50 Belt warning - recoding instrument cluster 00621601 E65 E66 Clock in instrument cluster 00621701 E46 Replacing instrument cluster 00621801 E53 N62 Replacing instrument cluster 00621901 R50 R53 Encoding instrument cluster (RPA) 00630301 E31 Low beam headlights and fog light 00630401 E36/5 Replace rear lamp 00630501 E46 LHD Replacement of front headlights and turn indicators 00630601 E38 Failure of xenon headlight 00630701 E38/3 (With SA 144) retrofit lever, rotating beacon 00630801 E46 RHD Incorrect installation of headlight 00630901 E46/2/C Direction indicator light loose 00631001 E85 Replacing headlight 00640117 E36 (without /5) Ventilation flap touches 00640118 E34 M50 Air-conditioning compressor screw connection 00640121 E38 Independent heater blower 00640122 E38 Independent heater holder 00640123 E38/M73 - Induction pipe to air-conditioner - USA,Japan,Canada 00640124 E36 328i Air-conditioning compressor 00640125 E38 - Induction pipe to air-conditioner (without USA,Canada,Japan) 00640201 E39 SA538 Function failure of latent heat storage 00640301 E38 Leaky air-conditioning condenser 00640501 E31 Leaky air-conditioning condenser 00641001 E38/M52 Garbled integrated heating and air-conditioning display indicator 00641101 E38, E39 with SA 536 Independent heater automatically active 00641201 E31 - Leaky heat exchanger 00641301 E46 M47 LHD Hose clips, coolant hoses 00641401 E46 M47 Starting problems with supplementary heater 00641501 E46 SA 534 Pressure line leaking 00641601 E46 M47 Bracket for supplementary heater 00641701 E39 (for option SA 538) Replace latent heat storage device 00642001 E39 M52 Leak in intake line for air conditioning 00642101 E39 540iA (CKD Mexico) Replacing engine supply and return hoses 00642201 E38 M57 Replacing control panel for automatic air conditioning (IHKA) 00642301 E38 M52 Auxiliary water pump, connector pin assignments 00642401 E39 M57 Control panel for heating/air conditioning - auxiliary heater function 00642501 E39 M57 Replacing IHKR / IHKA control panel 00642601 E46 M47 Auxiliary water pump 00642701 E46 M47 without SA 530, 534 cut-off relay for heating/fuse assignments 00642801 E46 M47 M57 Correct fuse assignments for auxiliary water pump 00642901 E46 (With SA 530) adapter lead pressure sensor, air conditioning system 00643101 E36/7 M54 Intake line, A/C compressor 00643201 E38 E46 E52 E53 Electric (auxiliary) fan 00643301 E39 E53 Electric auxiliary fan 00643401 R50 (MINI) Seat heating 00643501 E39 Electric fan (Kuwait police) 00643601 E38 E39 E46 E52 E53 Electric fan - USA, Canada, Japan 00643701 E38 E39 E52 E53 Electric auxiliary fan 00643801 E39 M47 M57 LHD Electric auxiliary fan 00643901 E46 M47 LHD Re-encode air conditioning operating unit 00644001 E39 M54 Electric auxiliary fan 00644101 R50 Attach pressure line air conditioner scuff protection 00644201 E65 E66 N73 Replacing electric fan (pressure fan) 00644301 E53 Filling air conditioning system 00650112 E38 SA609 Navigation positioning 00650113 E38 SA609 Navigation selection 00650114 E38 SA609 Navigation CD-Software 00650115 E31 Antitheft warning system 00650116 E38 Jap Radio speed-dependent volume control 00650121 E31,34,36 US Airbag-electronic control unit 00650122 E38/US and ECE with SA-806, or SA-352 Radio receiver 00650301 E38 Faulty side airbag electronic control unit 00650401 E38 E39 Ocean radio onboard monitor fails 00650501 E38 CD-Road map is stuck 00650701 E39 - Amplifier for DSP (incorrectly built in) 00650801 E39/2 Amplifier connection for FM is incorrectly poled 00650901 E32/3, E38/3 - Pressure switch for fresh air system 00651101 E36 RHD with SA 260 - Side airbag 00651201 E38US E39US Fault in navigation system SW 7.0 00651301 E36/4 Side airbag module 00651401 E38 E39 Front side airbag 00651501 E36/Convertible with SA 674 sound volume faulty 00651601 E38 L7 Video recorder securing parts loose 00651701 E36/C Harmon Kardon hi-fi system 00651801 E46 GPS receiver defective 00651901 E38/3 Fire extinguishing system/air system trips 00652001 E46 Radio navigation operating software 00652101 E36, E39 Replacement radio Business CD RDS 00652301 E46/4 Subwoofer connection 00652401 E38 (for option SA 302) Replace microwave interior motion sensor(FIS) 00652501 E46 ITS, fit of inflator assembly 00652601 E38 E39 Japan, video module software error 00652701 E38 E39 (mit SA 677) Replacing DSP amplifier 00652801 E38 E39 Replacing DSP amplifier + retrofitting adapter lead 00652901 E46 Navigation Alpine software error 00653001 E36/7 coupe retrofit DWA interior space protection 00653101 E46 Airbag central triggering unit 00653201 E36/7 Replacing side airbag sensors 00653301 E46 Side airbag plus retaining clip 00653401 E36/7 Retrofitting power supply line for daytime running lights module 00653601 E46/2/3/C RHD Alpine on-board monitor 00653701 E36 M3 US Re-encoding airbag control unit 00653801 E53 Total failure of navigation computer 00653901 E46 CKD Mexico impact sensor/re-encoding airbag control unit 00654001 E46 CKD Mexico re-encoding airbag control unit 00654101 E38 (without M73) E39 E46 navigation computer adapter lead 00654201 E38 M73 Navigation computer adapter lead 00654301 E52 US Radar passenger compartment protection SDR 00654401 E39 Radio, sound distortion 00654601 E39 US Reprogram/replace radio (ALPINE) 00654701 E39 US Reprogram radio (VDO) 00654801 E53 Antenna amplifier, voltage supply 00654901 R50 R53 (MINI) Side airbag 00655101 E39 E46 US Program radio receiver (VPC) 00655201 E39 US Re-encode radio 00655301 R50 MINI Driver's airbag - PIN assignments 00655401 R50 R53 MINI Replace Boost CD53 radio 00655601 E39 E46 E53 Replace ALPINE MD53/CD53 radio 00655701 R50 MINI Replace Boost MD53/CD53 radio 00655801 E39 E46 E53 Program ALPINE CD53 radio 00655901 E65 Code sensor B-pillar right (SBSR) 00656001 E65 Replace airbag control unit/satellites 00656101 E65 Replace (Japan) aerial/antenna amplifier 00656201 R50 R53 (SA 650) Program CD53 radio 00656301 R50 R53 Radio CD 53 - remove Y-cable 00656401 E65 E66 Replacing central gateway module (ZGM) 00656501 E46 Recoding airbag control unit 00656601 E65 E66 Replacing Central Gateway Module (scope 2) 00656701 E46 - Reprogramming navigation computer 00656801 E46/5 - Replacing TV amplifier 00656901 E39 E53 US Retrofitting RC filter for on-board monitor radio 00657001 E39 E46 Navigation software update 00657101 E65 US (SA 603) Re-encoding control display 00657201 E39 E53 Encoding DSP amplifier (USA only) 00657301 E39 E53 Encoding DSP amplifier / replacing RC filter 00657401 E85 Replacing video module 00657501 E65 E66 Replacing seat occupancy detection mat, front seats 00657601 E60 (VPC Japan) Programming CCC - Siemens 00657701 E39 Replacing airbag control unit 00657801 E60 Replacing on-board monitor and programming control units 00657901 E85 US Encoding airbag control unit 00658001 E85 Encoding airbag control unit (SIM) 00658101 E83 Replacing front airbag sensors 00658301 E85 Checking airbag components and replacing if necessary 00658401 E63 E64 Replacing interior motion sensors 00658501 E87 Replacing radio 00658601 E87 Replacing antenna amplifier 00658701 E60 Retrofitting language version Chinese (SA 866) 00658801 E60 Retrofitting language version Korean I (SA 867) 00658901 E60 Retrofitting language version Korean II (SA 867) 00659001 E83 E85 (with SA 609) Loading navigation software 00660104 E36 AUS Radio remote control 315Mhz 00660301 E46 PDC Ultrasonic transducer incorrectly fitted 00660401 E60 E61 E65 E66 Replacing ACC sensor 00670201 E87 Checking pressure-sensitive finger guard system and replacing power window drive if 00710111 E36 M44 US Exhaust instruction plate 00710201 E36/5 316i Incorrectly filled in vehicle registration documents 00710301 E36/7 S52 Exhaust emission information plate incorrect 00710401 E36/7 E39 S50 S52 S62 M-Mobility system hose routing 00710501 E53 Jack mounted incorrectly 00710601 E46/C Tyre inflation pressure sticker incorrect 00710701 E36/7 Tyre inflation pressure sticker incorrect 00710801 E46 US emission label fitted incorrectly in engine compartment 00710901 E46 Replace tyre inflation pressure sticker 00711001 E65 Retrofit exhaust emission sticker 00711101 E53 (4.6is) Retrofit tyre inflation pressure information plate 00711201 R50 R53 US Replace barcode sticker 00711301 R50 US Replacing tyre inflation pressure information plate 00711401 E39 US - Tyre inflation pressure sticker 00711501 E65 E66 Retrofitting information sign, vehicle jack 00711601 E60 US Replacing Compliance sticker 00711701 E60 Replacing type identification plate 00711801 E60 US Retrofitting GRAV information sticker 00711901 R50 R53 Checking ECE type identification plate and replacing if necessary 00712001 E83 (with SA 838) Replacing information sticker 00712101 E83 (SA 838) Replacing information sticker 00712201 E67 Replacing tyre inflation pressure sticker 00712301 E83 Checking labelling on cover of OBD socket and retrofitting if necessary 00712401 E87 Replacing screw connection of towing hitch 00712501 E83 M54 US Checking emission information label MY05 00720114 E36 Compact Child's safety belt 00720115 E36/2, 4 with SA 465 - Rear safety belt 00720201 E38 Loose passenger airbag 00720501 E36/7C Upper belt retractor rests on B-pillar 00720601 E38 Replacing head airbag, rear (C-bag) 00720701 E32/3 Checking emergency exit 00720901 E53 Roof rack threaded connection 00721001 E53 Seat belt threaded connection, front 00721101 E53 Seat belt anchorage, rear 00721201 E46/2/4 US Upper belt, child safety lock, rear 00721301 E39 E46 E52 Checking belt buckles 00721401 E46/2/C Screw connection, airbag module, door, left 00721501 E53 E85 Checking date of manufacture of seat belt tensioner 00721601 E63 Replacing both rear seat belts 00721701 E61 Checking screw connection for rear centre seat belt 00721801 E65 E66 Checking airbag module at front door and replacing if necessary 00721901 E60 US (without SA 465) checking rear centre upper belt 00820101 E36 E46 E39 E38 Replace baby seat 00840201 E39 touring - Telephone-data-fax interface 00840301 E38 with SA 622 - Tandem telephone system 00840401 E38 E39 Incorrect installation of interface telephone (Arabian countries only 00840501 E38 E39 (with SA 629 and 677) - Voice input control unit 00840601 E38 E39 With SA 620 without SA 677 - Voice input control unit with cooling plate 00840901 E39 E53 ECE Cordless handset adapter lead 00841001 E38 E39 E46 (SA 632) Replacing interface + electronic charger for hands-free system 00841201 E65 Replace transceiver 00841301 E39 Retrofitting adapter lead for cordless telephone handset 00841401 E65 E66 US Programming transceiver 00841501 E39 Replacing electronic charger/hands-free module 00841601 E65 E66 (Japan) Encoding flexible BUS interface (FBI) 00841701 E39 E46 Replacing universal charger and telephone hands-free facility 00841801 E60 US (VPC) Replacing TCU (telematics control unit) 00841901 E46 E60 US (VPC) Replacing TCU (telematics control unit) II 00842001 E46 E60 US Replacing TCU (telematics control unit) II 00842101 E83 E60 E65 E66 US (VPC) Replacing telematics control unit TCU 00842201 E46 E53 E83 E85 Replacing or retrofitting telematics control unit TCU 00842301 E46 E83 Retrofitting telematics control unit (TCU) 00990301 E36/7 M54 B30 Owner's Handbook missing/incorrect 00990401 E36/7 M54 B30 Mistake in Owner's Handbook 00990601 E65 Replace Owner's Handbook 00990701 E65 US Operating instructions (automatic emergency call) 00990801 R50 R53 Supplementary Owner's Handbook, Australia 00990901 E65 E66 Owner's handbook (automatic emergency call) 00991001 E60 (KNG, PMT) Working through defect list 00991101 E60 PMT Replacing windscreen drip moulding (work through defect list) 00991201 E60 PMT Replacing cowl panel retaining clips (work through defect list) 00991301 E60 PMT Replacing rear window bottom cover (work through defect list) 00991401 E60 PMT Replacing drink holder (work through defect list) 00991501 E60 PMT Replacing sun visor (work through defect list) 00991601 E60 PMT Replacing B-pillar trim (work through defect list) 00991701 E60 PMT Checking rear bench seat centre armrest, reworking if necessary (work through defect 00991801 E60 PMT Replacing safety-gateway module (work through defect list) 00991901 E60 PMT Replacing fuse for micropower module (work through defect list) 00992001 E60 PMT Replacing rain-light sensor (work through defect list) 00992101 E60 PMT Retrofitting corrugat. tubing for wiring harness in bonnet hinge area (work thr. 00992201 E60 PMT Retrofitting corrugated tubing for Servotronic line (work through defect list) 00992301 E60 PMT Retrofitting foam mater. strips + absorber at intake, right/left (work through defect 00992401 E60 PMT Replacing wiper arm (work through defect list) 00992501 E60 PMT Retrofitting raised brake light with felt strips (work through defect list) 00992601 E60 PMT Programming all control units (work through defect list) 00992701 E60 PMT Replacing ARS/AFS return line (work through defect list) 00992801 E60 PMT Replacing expansion hose for power steering (work through defect list) 00992901 E60 PMT Checking power steering pump and replacing if necessary (work through defect list) 00993001 E60 PMT Replacing bottom steering shaft (work through defect list) 00993101 E60 PMT Replacing Owner's Handbook (work through defect list) 00993201 E63 PMT Fixing wiring harness DSC 00993301 E63 PMT Replacing towing eye 00993401 E63 PMT Replacing radiator mounting screws 00993501 E64 PMT Reworking threaded connection for convertible top main bearing 00993601 E64 PMT Retrofitting cable strap on convertible top 00993701 E64 PMT Replacing clip for A-pillar cover 00993801 E64 PMT Replacing fuel tank ventilation line (engine side) 00993901 R50 R53 Enclosing supplement in Owner's Handbook (RPA) 00994001 R50 R53 US Enclosing RPA supplement in Owner's Handbook 00994101 R52 PMT Replacing roof cassette and retrofitting protective cap 00994201 R52 PMT Reworking convertible top 00994301 R52 PMT Convertible top optimisation measures 01120139 Noise/vibration when starting engine Unpleasant noises 01120157 Noise/vibration when starting engine Vibration / oscillation 011201XX Noise/vibration when starting engine 0112XXXX Noise/vibration when starting engine 01130139 Noise/vibration when stationary with engine running Unpleasant noises 01130157 Noise/vibration when stationary with engine running Vibration / oscillation 011301XX Noise/vibration when stationary with engine running 01131139 Without engaged gear/drive range Unpleasant noises 01131157 Without engaged gear/drive range Vibration / oscillation 011311XX Without engaged gear/drive range 01131239 With engaged gear/drive range Unpleasant noises 01131257 With engaged gear/drive range Vibration / oscillation 011312XX With engaged gear/drive range 01131339 With air-conditioning unit on Unpleasant noises 01131357 With air-conditioning unit on Vibration / oscillation 011313XX With air-conditioning unit on 01131439 With electrical consumers on Unpleasant noises 01131457 With electrical consumers on Vibration / oscillation 011314XX With electrical consumers on 01131539 At full steering lock Unpleasant noises 01131557 At full steering lock Vibration / oscillation 011315XX At full steering lock 0113XXXX Noise/vibration when stationary with engine running 01148739 Acceleration in forward gears/stages Unpleasant noises 01148757 Acceleration in forward gears/stages Vibration / oscillation 011487XX Acceleration in forward gears/stages 01148839 Accelerating in reverse gear Unpleasant noises 01148857 Accelerating in reverse gear Vibration / oscillation 011488XX Accelerating in reverse gear 0114XXXX Noise/vibration when accelerating 01168739 Constant driving speed in forward gears/stages Unpleasant noises 01168757 Constant driving speed in forward gears/stages Vibration / oscillation 011687XX Constant driving speed in forward gears/stages 01168839 Constant driving in reverse gear Unpleasant noises 01168857 Constant driving in reverse gear Vibration / oscillation 011688XX Constant driving in reverse gear 0116XXXX Noise/vibration at Constant driving 01178739 Deceleration in forward gears/stages Unpleasant noises 01178757 Deceleration in forward gears/stages Vibration / oscillation 011787XX Deceleration in forward gears/stages 01178839 Decelerating in reverse gear Unpleasant noises 01178857 Decelerating in reverse gear Vibration / oscillation 011788XX Decelerating in reverse gear 0117XXXX Noise/vibration when decelerating (coasting) 01180139 Noise/vibration when turning off engine Unpleasant noises 01180157 Noise/vibration when turning off engine Vibration / oscillation 011801XX Noise/vibration when turning off engine 0118XXXX Noise/vibration when turning off engine 01XXXXXX Complete vehicle (symptom defect codes)
