los que no sepan ubicar la perfida albion que imaginen un pais idiopatico donde hablan raro y comen peor tal fue asi que un habitante de aquel pais un dia de septiembre (no era aun navidad, pero hasta el cuento de navidad de Dickens da comienzo un poco antes) comentó sus tribulaciones en los siguientes terminos, “My Coupe’s engine has been completely rebuilt and the time came to rebuild the original Zeniths, so they were stripped down to their component parts, cleaned up and gone right through with all parts from the more comprehensive of the two types of rebuild kits replaced with new. In terms of credentials, the workshop is a well-known (in classic car racing circles) tuning firm who specialise in carb rebuilds and tuning - however they are not experienced with this exact type of carb: So I consulted a second carb specialist who is, based again here in the UK and came recommended- They said the same: That these carbs aren’t worth bothering with and can be impossible to setup even if following the official Zenith manual. During this process, it was noted that there was some minor pitting and scoring in the venturi but it was deemed minor enough to continue, this may or may not be relevant to the issue I know have: The workshop performing the work cannot get the carbs to supply the correct amount of fuel, they have spent many hours checking and re-checking their work and are at a loss as to what the issue is. They are now suggesting we swap them out with a Weber conversion kit, which I am loathed to do, especially as I cannot recall ever having heard of such an issue (and that the carbs are a poor design, as they suggest - and cannot be made to work). So I’m running up a SOS here for advice.”
es decir, me he gastado una fortuna en un taller de prestigio especialistas en carburadores, han renovado todo todito todo con recambios maravillosos, y a parte de unas poquitas de rozaduras y raspones en los venturis no han encontrado nada malo pero, pero despues de decenas de horas de intentar que la cosa funcione, decenas de horas que me han cobrado a precio desorbitante a pesar de no haber conseguido nada, pues eso que no han conseguido nada y como son mu buenos en esto han deducido que los carburadores estos son una eme, y me van a poner unos webers por un pico, ademas de todo lo que me han cobrado hasta la fecha y, vengo aqui porque despues de ponerme un monton de vaselina, pues que ni por esas consigo que pase la cosa , asi que voy a preguntar por aqui por si alguno tiene alguna idea
...y la gente pregunta... ...y el cuento de navidad? cuando sale scrooge? ...a su debido tiempo...a su debido tiempo
En este tipo de cuentos es bastante importante conocer la versión de la otra parte.... lo cual no quiere decir que se desvele el misterio necesariamente...
es interesante comprobar como en esta situacion, y como si de un secuestro se tratara la psique se desenvuelve en un estocolmo de manual, y el propietario mas curtido comienza a empatizar con sus carniceros... ...y revela: “The car starts, runs and idles - it just doesn’t run particularly well and is impossible to tune. “ o sea que es un puro desastre, pero algo hace,... como se vera es especialmente relevante anotar que los carburadores renovados han sido montados, y puestos en funcionamiento sobre el pobre motor, que ajeno a la trama, ha intentado hacer lo posible...
decia billy wilder, creo o tal vez fue su primo, quiza, que mas da,...decia que una pelicula consta de tres fases: poner al protagonista en un arbol pegarle fuego al arbol rescatar al protagonista ...nosotros estamos aun en la primera
como dicen los financieros, veamos el “business case” del taller renovacion de carburadores, 700 ajustes en motor (fallidos), 300 nuevos carburadores weber, 1200 ajustes en motor de los weber, 300 —————————————————— total ganancias 2500 suena bien, riesgo cero,... ...me estan entrando ganas...
bueno, pues como el taller sigue cobrando, quince dias despues hay noticias ! que bien ! "Update: The issue has been narrowed down to the accelerator pump pistons being scored and the seals being bad (there was not any replacement seals in the rebuild kit). I therefore need new seals and replacement pistons - Any leads on who I could source these from?" asi que lo han encontrado ! eran imposibles de carburar, los zeniths son una eme, pero con un poquito de presion, ya tenemos veredicto ! ....nota marginal, cualquier conocedor de los carburadores sabe que la pequeña bombita de inyeccion de gasolina no tiene ninguna felacion con el ajuste de carburacion ni el sincronismo, pues solo proporciona un chorrito de gasolina cuando pegas un pisoton al acelerador (sirve para evitar esos segundos de duda hasta que entra el venturi a arrastrar gasolina en serio) ... pero en pleno estocolmo, cuando te llega una noticia asi: "solo es cambiar una pieza", te pones estupendo en cero coma dos ...que pena que no fuera verdad !, pero,...y lo que nos hemos divertido, que ?
Pero lo que sucedió superó las expectativas y abrió un escenario completamente nuevo. Tal vez fue el buen samaritano al principio, pero luego trasmutó en ángel vengador... ...y dijo el profeta: "...under the grace of God, may he always be blessed and praised, and protected from the lack of love of men, I write these chronicles of dismay with the desire to share my unfortunate experiences and raise the mystery in the light of knowledge. With the acquiescence of my benefactor and friend, may almighty God watch over his soul and take care of his body, I will reveal what happened in a few days to this part We could only say that what was found was very different from what was expected, but nothing prepared us for ignominy, scam and fraud as, in the blessed name of god our lord, how is it possible that men have misled their destinies and soiled their souls with lies ? How is it possible that a simple man has entrusted his goods to his fellow men, with promises of good times and abundant satisfaction, and has received contempt and misery? Lord give us hope, that the avenging angel will rush upon them from on high, that they succumb to the weight of their many sins, and that our brother may continue on his way on the back of his speedy steed. May our lord be blessed. Amen" es decir... "... bajo la gracia de Dios, que sea siempre bendecido y alabado, y protegido del desamor de los hombres, escribo estas crónicas de consternación con el deseo de compartir mis experiencias desafortunadas y plantear el misterio a la luz de conocimiento. Con la aquiescencia de mi benefactor y amigo, que Dios todopoderoso vele por su alma y cuide su cuerpo, revelaré lo sucedido en unos días a esta parte. Solo pudimos decir que lo encontrado fue muy diferente de lo esperado, pero nada nos preparó para la ignominia, la estafa y el fraude. como, en el bendito nombre de dios nuestro señor, ¿cómo es posible que los hombres hayan descarriado sus destinos y manchado sus almas con mentiras? ¿Cómo es posible que un hombre sencillo haya confiado sus bienes a sus semejantes, con promesas de buenos tiempos y abundantes satisfacciones, y haya recibido desprecio y miseria? Señor, danos esperanza, que el ángel vengador se abalanzará sobre ellos desde lo alto, que sucumbirán al peso de sus muchos pecados, y que nuestro hermano pueda continuar su camino a lomos de su veloz corcel. Bendito sea nuestro señor. Amén"
Pues dado que nadie le daba apoyo al Britton, se ablandó el corazón del sujeto y le propuso un negocio ventajoso Si le enviaba los causantes y no los remediaba, nada Si obraba arreglo, entonces lo convenido y asi devino el cuento en leyenda, como se vera
asi entonces el correo llego una mañana,... menos mal que hicimos un unboxing video taping, que si no,... esto debiera ser un angulo recto, nivel de ostion para doblarlo no es moco de pavo, la cuestion es que de esta guisa tropezaba y no se podia desplazar mas que un tercio de su recorrido total,... mucho plastico y mucho carton, pero mal puesto,...mal el trasero, jamas vi algo asi, tambien ostion nivel premier league, esta desalineacion no permite que la palanca del primario deslice, y lo peor es que aparenta una doblez radical de piezas que no parece que se dejen desdoblar era evidente que teniamos una situacion comprometida, el envio fue un desastre, hasta el punto de deslavar los hechos no sabiendo realmente que fue causa y que efecto, por lo que no sabemos si estos defectos estaban ya antes durante las pruebas en el coche o se produjeron en el envio
un apunte sobre el envio, casi todos consideran procedente proteger lo que esta dentro de lo de fuera, por ello se coloca plastico de burbuja, carton y una caja rigida de plástico , pero pocos se preocupan de proteger lo que esta dentro de lo de dentro y dejan espacio entre ellos, asi cuando la caja es agitada y golpeada los dos objetos chocan entre si y se rompen en este caso las fotos lo revelan con claridad aunque se nos privo de saber si las roturas, deformaciones y desalineaciones estaban presentes cuando fueron probados en el coche, en cuyo caso nadie dudaria de que el mal funcionamiento estaba asegurado
bueno pues como no hay modo de probar un melon sin abrir un melon, abrimos entonces una pareja de carburadores, imaginalo, un par de carburadores recientemente renovados por un taller experto, renovados en profundidad, con juntas, piezas nuevas, que maravilla debiera ser como un sueño,... ...veamos a ver que nos deparan,... tienen buen aspecto por fuera, no? una membrana perforada no va a ser de mucha ayuda no se yo si esto lo han abierto y limpiado,... vaya, igual no han renovado todo, todo que curioso esta escarcha blanquecina por todas partes es tambien curioso que falten cosas como este chicle en uno de los carbus, y que la junta (agujero ovalado) no coincida con el agujero redondo, mala eleccion no se porque pero el tornillo no salia uyyy, ya se porque, curioso ver que el flotador este atascado asi, por que ? lo normal es que pivote libremente, que pasara aqui ?
mas piezas dobladas, rotas o defectuosas, contrapuestas a piezas usadas de mi stock de dinosaurios fallecidos nos encontramos jets cambiados de primario a secundario, como iban a funcionar los pobres !
bueno, no tiene muy buena pinta, pero, aun hay mas para algo recien renovado,... estas toberas estan recien pulidas, vamos que muestro aqui como debieran estar , no como las encontramos aqui la de arriba esta tal cual vino, la de abajo pulida ahora, para haber sido renovados, mucha renovacion....eso es porqueria de años, pero claro el pulido es a mano con lana de acero y pasta de pulir, y eso es muuucho curro ...ya casi tenemos al protagonista subido al arbol, ...vamos a pegarle fuego...
venga, el arbol en llamas... y esto que es y de donde sale ? esta por todas partes, pegado a las paredes, en los conductos, en los huecos,...?
Estimado Dequincey, mis conocimientos mecánicos son entre nulos y escasos, pero como ciego no estoy, no puedo por menos que exclamar macagüenlahostia!!!
Edad y uso del equipamiento, y mala fe del supuesto renovador. En cuanto al material en concreto no me atrevo a especular, más allá de mierda en sentido genérico, ya que entiendo que puede depender en gran medida del ambiente de utilización del zarrio. Como anécdota, hace ya varios años en un rally de regularidad organizado por mi Club en Velilla del Rio Carrión, hacíamos un tramo a triple pasada en la variante conocida como "a sectores" (conocida para mí ahora, entonces desconocida y así de mal me salió), que tenía lugar en la cantera situada entre el citado pueblo y el vecino de Guardo. ¿De qué era la cantera? Ni idea, pero había polvo fino blanco para aburrir. El tramo resultó divertido (más allá de su penosa ejecución por mi parte)... pero puedo prometer y prometo que vehículos y tripulaciones salieron de allí más blancos que el conductor del volvo azul en Airbag. Mucho tiempo después, aún me sorprendía a mí mismo limpiando "miellllda blanca" de rincones que desconocía. Incluido el motor, que un par de meses después me lo encontré con el filtro de gasolina totalmente obstruido (incluso solidificado se podría decir). Eso yo con mi modesto y tirando a moderno golfito con inyección k-jetronic. No quiero ni pensar lo que sufrirían los más clasicotes presentes allí, de carburación...
Es una buena anesdotan pero en este caso no puede ser. Como info adicional, los Carbus no tenían el eso blanco de antes y luego fueron “renovados”, y los intentos de ajustes se hicieron en parado en taller, y luego viajaron a Bilbo, y aunque este la mala fama por Airbag de ahí no viene la cosa,... que será ?
bueno, pues ni lo uno ni lo otro ni lo otroro, el polvo blanco eran, micro-bolitas de fibra de vidrio ! porque sabemos ahora que mr. scrooge decidio mandar limpiar los carbus por fuera en una arenadora con dos copelas ! asi, a pelo, en vivo y en directo, y el pequeño tim lloraba y se retorcia, pero scrooge era malo malisimo y le dio igual, areno los carbus, les puso las peores juntas del mercado, los monto como le vino y los entrego al taller para probar y ajustar..... y bien, si alguien se puede imaginar el peor escenario posible ese era el que paso, los carburadores son por definicion unos trastos llenos de agujeros, pasadizos, tubos, y huecos, por los que pasaron, se asentaron y se depositaron las microbolitas de fibra de vidrio taponandolo todo, embotandolo todo, y haciendo inutiles los magnificos zeniths, y a 700 libras la jugada.... como te quedas? alguien quiere la version del contrario? que posible version alternativa hay a la estafa, el engaño, el delito? he visto cosas feas y chungas, por ejemplo limpiar carburadores en baño de ultrasonidos y ver como se oxidan en horas, muestro aqui un ejemplo para que se sepa de lo que se habla... y para que no lo haga nadie (observese la linea del nivel del baño que coincide con la oxidacion) pero arenarlos ? como es posible que ademas hagas algo asi sobre un elemento que se va a encargar de gestionar la mezcla y de introducirla en un motor recien hecho, con sus pistones nuevos, sus segmentos impolutos y sus cilindros recien mecanizados ? un minuto de silencio por los gatitos que sufren, las hojas muertas y los pasos perdidos....
ahora viene cuando rescatan al protagonista, ...pues el inglés armado con la información y fotos se presento en el taller, reclamó y consiguió la devolucion de todo lo pagado sobre este particular, consiguió ademas una revision integra del motor, limpieza interna, y reposicion de segmentos y guias de valvulas sin coste, y dio luz verde a la renovacion de los carbus esta vez a alguien que sabia lo que hacia aunque no fuese british de pura cepa, y sobre todo alguien que no disponia de una arenadora, extremo este de vital importancia tal y como ha sido demostrado ...dentro fotos...
bueno es una pena que esten desordenadas, pero se capta la idea mas o menos ajustes de banco para presettings pulido de toberas creo que fueron unos 15 litros de gasolina y 5 de gasoil para sucesivos baños y poder quitar toda la porqueria esa blanca NOS de 1979 para las bombas de piston ajuste de fast iddle para arranque en frio automatico estos si pasaron por ultrasonidos, pero despues se neutralizaron en gasolina/gasoil mucha brocha y mucho trapo el chicle perdido y la junta correcta con agujero redondo y no ovalado valvula y flotador NOS membranas nuevas NOS ...
y una ultima idea sobre como embalarlos, normalmente se han enviado sin esparragos, pero esta vez cierto temor a que la liaran aconsejo fijarlos con loctite por ell se decidio amarrar los dos carbus como si fueran uno solo, y encajonarlos sin holguras
...llegaron ya, se montaron y sorprendieron con su funcionamiento y prestaciones y el pequeño tim sonrio por fin dispuesto a pasar una feliz navidad con su coupe no sabemos si scrooge pasara unas navidades felices, pero tal vez se lo piense dos veces antes de volver a hacer algo malo en honor a la verdad no han salido los fantasmas de las navidades pasadas, pero bueno era una adaptación libre... feliz navidad
