Video Mercedes-AMG ONE: el F1 de calle
Tema en 'Foro General BMW' iniciado por cybermad, 11 Sep 2017.
  1. cybermad
    Siguiendo la estela del i8 :ANAL: un motorillo de juguete y 4 secadores de pelo :D
    Snatch, agc, ISFER y 5 otros les gusta esto.
  2. cybermad
    Mercedes AMG Debuts 1000HP Project One: The King Has Arrived
    After a long period of teasing and playing with shadows, the new Mercedes AMG Project One finally made its world debut as the world’s first road legal car with a Formula 1 powertrain.
    of the hybrid system found in the W08 F1 car, including the turbocharged 1.6-liter V6 engine and no less than four electric motors.
    The two front electric motors are state-of-the-art units, being capable of revving up to 50,000rpm when the current best motors in the market rev up to 20,000rpm. The third electric motor is integrated into the turbocharger while the fourth one is mounted directly on the combustion engine.
    Each one of the front motors are producing 160hp (120kW), with the electric motor on the engine making the same amount of power and the one mounted on the turbocharger being a 120hp (90kW) unit. Total power output is "over 1000hp".
    Mercedes AMG claims that turbo lag isn’t just eliminated with this setup but the response times are now even shorter than those of a naturally aspirated V8. All this was possible not just because of the torque-fill provided by the electric motors but also thanks to the electrically-assisted turbocharger which in turn features exhaust gas and compressor turbines that are separate from each other and mounted at an optimum position to the exhaust side and the intake side of the V6 unit, and connected to one another by a shaft powered by the 90kW unit.
    Just in case you haven’t realized it yet, this isn’t your normal boosted hybrid powertrain, this is some next level engineering that finds its way on public roads for the first time. But what does that mean for the acceleration figures? Mercedes AMG says that the Project One is capable of exceeding 217mph (350km/h) flat out but we already knew that. What we didn’t know is that the Project One is capable of a 0-124mph (200km/h) in less than six seconds. That’s right, six.
    Other things we’ve learned include a 15.5-mile all-electric range, a drive system that operates with 800 volts instead of the usual 400, a variable all-wheel drive system with torque vectoring and a sizeable lithium-ion battery pack that uses the same cells, arrangement and cell cooling system with -you guessed it- the Mercedes-AMG F1 car. The company also says that under normal driving conditions, the system recuperates up to 80 percent of the energy needed, which is then fed back to the battery.
    Power is transmitted to the rear wheels via an all-new automated eight-speed manual transmission developed specifically for the Project One. The gearbox is activated hydraulically and offers both auto and manual modes, with the latter operated via paddles unsurprisingly. A high-strength carbon-fiber monocoque body forms the basis for the car, with the integrated engine and transmission also having load-bearing functions, as both completely support the rear suspension.
    The interior gets a pair of 10-inch high-definition displays while the steering wheel with the flattened upper and lower sections hosts the controls for driving modes and suspension setup, the LED shift display and an airbag. There’s also air-conditioning, power windows and a rear-view camera, since there’s no back window.
    Mercedes AMG will make only 275 examples of the Project One in left-hand only configuration for a price of 2.27 million each ($2.7 million in current exchange rates). All build slots are sold-out at the moment but don’t expect to see the Project One on the streets anytime soon as the company has still 18 months of development ahead of delivering the first production examples.
    http://www.carscoops.com/2017/09/mercedes-amg-debuts-1000hp-project-one.html
    Snatch, Till, NaCl y 5 otros les gusta esto.
  3. Gon36
    Gon36 Forista
    22 Oct 2012
    E36 16i/F33 28i
    Hoy ha sido la presentación oficial del nuevo hypercar de Mercedes, el Project One, con el que la marca quiere trasladar su monoplaza de competición a la calle.
    Con un V6 de 1.6L de cilindrada y 750 caballos de potencia procedente del monoplaza de F1, acompañado de cuatro motores eléctricos que dejan el conjunto en la impresionante cifra de 1000 caballos, Mercedes asegura una velocidad punta superior a 350 km/h y un 0-200 que baja de los 6s.
    [​IMG][​IMG]
    Última edición: 11 Sep 2017
    BM3W, Snatch, kliver y 4 otros les gusta esto.
  4. Guancho
    Michigan
    Un chorro de baterías y un motor de 160 cv. No lo compro.
    A BM3W le gusta esto.
  5. Kalkbrenner
    Kalkbrenner Forista Senior
    17 Dic 2012
    Barcelona
    130i lse, 325i
    Como suene igual que los monoplazas, aburrirá hasta a las ovejas.
    A nebur, Kaiser-x y IGRES les gusta esto.
  6. Nacho Martinez
    Nacho Martinez Clan Leader Coordinador
    21 Abr 2002
    Valencia (de vez en cuando)
    Como ejercicio tecnologíco mola. Eso de llevar el tren rodante de un F1 no deja de ser atractivo.
    Me gusta más el Aston Martin (no recuerdo como se llama)
  7. IGRES
    IGRES Forista Senior
    17 Mar 2014
    Bcn / Sdr
    M5SmartOctavia
  8. Curro
    Curro Clan Leader
    30 Nov 2013
    Z3 Coupe 2.8
    No parece un Mercedes
  9. Kalkbrenner
    17 Dic 2012
    Barcelona
    130i lse, 325i
    Vulcan o Valkyrie, uno de los dos.
    A Nacho Martinez le gusta esto.
  10. *NANO*
    *NANO* Clan Leader
    Creo que el motor térmico no tiene esos cv. Debe tener unos 700.
  11. Lu Rivaya
    Lu Rivaya Forista Legendario
    29 Jun 2010
    Madrid/Asturias
    Que canteo de fotos, son tan perfectas que me han hecho dudar de si eran reales o creaciones digitales.
    En cuanto al motor, no le veo al I8 de rival, ya que este tiene 1000 cv y el I8 350. Ademas ese pequeño motor es un V6 frente al L3 del BMW.
    Se me hace raro que solo tenga 120 ese V6 turbo, aunque sea un 1600... Lo suyo es que rondase al menos los 200 para hacerlo mas atractivo. Aunque esta claro que ellos saben bien lo que hacen.
  12. Dimitri30
    Dimitri30 En Practicas
    11 Sep 2017
    DATSUN
    Para poner ese motorcillo que lo hagan termico 100%
  13. *NANO*
    *NANO* Clan Leader
    Menos de 200.000 euros frente a más de 2 millones de euros... :whistle:
    A AMM5 le gusta esto.
  14. Lu Rivaya
    29 Jun 2010
    Madrid/Asturias
    Aunque igual esos 120 cv son suficientes, junto con la energia de la frenada para mantener cargadas las baterias. Seria como Mclaren P1 mas eficiente, manteniendo las distancias.
  15. *NANO*
    *NANO* Clan Leader
    Hombre, más bien al contrario. Si fuese térmico, mejor que tuviese un motor en condiciones, V8, V10 o V12.
    A naviblue le gusta esto.
  16. Lu Rivaya
    29 Jun 2010
    Madrid/Asturias
    Esta claro. Lo decia por el enunciado
    "Siguiendo la estela del i8", yo creo que mas bien son distintas categorias de coches.
    A *NANO* le gusta esto.
  17. *NANO*
    *NANO* Clan Leader
    No creo que sean 120. Como ya he dicho, serán más bien 700.
  18. Lu Rivaya
    29 Jun 2010
    Madrid/Asturias
    Hombre, 700 los veo demasiados para un 1.6. Yo creo que Mercedes no quiere unirse al carro del P1, La Ferrari, 918 sino hacer algo diferente. Es que sino todo lo que pone estaria mal.
  19. Lu Rivaya
    29 Jun 2010
    Madrid/Asturias
    Menos de 6 segundos en alcanzar los 200 :whistle:
  20. *NANO*
    *NANO* Clan Leader
    ¿Por qué todo? Yo creo que solo está mal puesto ese dato.
  21. Dimitri30
    11 Sep 2017
    DATSUN
    Logico pero no lo van hacer.
  22. *NANO*
    *NANO* Clan Leader
    Entonces no entiendo que prefieras que mantenga únicamente ese V6 1.6 turbo.
  23. Lu Rivaya
    29 Jun 2010
    Madrid/Asturias
  24. Josué
    Josué Clan Leader Miembro del Club
    5 Jul 2002
    Lanzarote
    MiniYo & 49Maxi
    Este es el de los 2 millones y pico... :duda:
    Está claro que es lo más cercano a la F1 que habrá en la calle, con todo lo bueno y lo malo que ello conlleva (la peor F1 de la historia, para mi gusto, por muchas innovaciones que se hayan implantado).
    El morro me recuerda mucho al McLaren F1 de los 90, y en líneas generales no está mal, quitando ciertos "excesos" que son los que lo acercan tanto a los coches de carreras.
    ¿Nadie se apuntó a la preselección de hace unos meses? (justificando la capacidad para desembolsar los 2 "kilos") :sneaky:
    A chamadyco y Lu Rivaya les gusta esto.
  25. Tiniki
    Tiniki Forista
    Guipuzcoa
    120cv son los que tiene el motor eléctrico que hace girar el turbo...
    A *NANO* y Lu Rivaya les gusta esto.
  26. Lu Rivaya
    29 Jun 2010
    Madrid/Asturias
    No se que le ves de malo a un V6 de esas caracteristicas. Es como un formula 1 actual o uno de los 80. Apretado y con turbo. Eso si, no creo que sea para grandes kilometradas :D
  27. *NANO*
    *NANO* Clan Leader
  28. *NANO*
    *NANO* Clan Leader
    Yo me iba a apuntar, pero ese 1.6 V6 turbo me echó atrás.
    A Josué le gusta esto.
  29. *NANO*
    *NANO* Clan Leader
    Pues que no hay color con un buen V10 o V12 de alta cilindrada. A mí me dan ganas de llorar cada vez que escucho los F1 V10 y V12 y a continuación escucho los V6 turbo de ahora.
    De hecho, las críticas a los actuales motores de la F1 son a nivel mundial.
    A chamadyco le gusta esto.
  30. Dimitri30
    11 Sep 2017
    DATSUN
    He dicho que para tener ese v6,mas vale que sea electrico al 100%
