¿Es un avion, un yate, un cabrio, una fregoneta? No, es Decoliner by Blastolene
Impresionante vehiculo de artesania, menuda currada :xray: :xray: :xray: :xray:
pd. curiosa la cazadora del presentador, con la bandera de españa por la america profunda biggrin
[YT]L-bkq0CSzjQ[/YT]
YKpower
Baneado
Baneado
22 Mar 2006
Sirve para ir mas alto sobre los demas, no?
sansan
330d e90
30 Mar 2011
Jjajajjaja haz esto aquí y vete a pasar la itv.
Nichiii
17 Ene 2011
Imagínate mirar por el restrovisor y ver eso... Paro en el arcen y llamo a un psiquiatra
Refloto el hilo 8 años y 4 días después... porque está a la venta el Decoliner por medio kilo :chulo:
No se porqué no se ve el vídeo del primer post, es este :pompous:
Decoliner Is A $500,000 Double-Decker Driven From The Roof
FEB 22, 2020
Talk about open-roof driving.
No matter how impractical two-seater convertibles are, one can't deny the bliss open-top driving brings to the person behind the wheel. The feeling of the wind blowing through your hair, the unlimited headroom, and the blue sky serving as a blanket to your leisurely drive brings a certain degree of freedom.
However, as mentioned, most convertibles are impractical, mainly because of limited space. But what if there's a vehicle out there that you can drive without the roof all while having the capability to ferry a family with you?
Enter the Decoliner from Oregon by Randy Grubb. The Decoliner is a double-decker, specifically a motorhome. It has living space in its immense cabin, while the bus-like appearance is complemented by its heft. The design, according to Grubb, is inspired by the 1980s science fiction space traveller, Flash Gordon. It also fits the art deco architectural styling, thus the name, we reckon.
But what makes this motorhome special isn't just because of its eccentric styling – you have the option to drive the Decoliner from the roof. I specifically mentioned option because by default, the Decoliner can be driven from the cabin away from the sunlight. But in cases you want to feel the breeze from the outside, you can remove the steering wheel and then bring it with you on the roof with you. It's that cool.
The Decoliner isn't a cheap thrill, mind you. The whole project costed Grubb 6,000 man hours in 18 months, while shelling out $100,000 for spare parts. The project was built from the ground up, with a 1973 GMC motorhome serving as its chassis.
After all the hard work, Grubb was able to sell the Decoliner for $500,000. Was it all worth the cash? The new owner thought so.
Hostia, con esa Chupa eres hombre muerto, entre varios y por la espalda, aquí.
De peluca va frito.
Yo le cambio mis pelos por el Lambo biggrin
Josué
MiniYo & 49Maxi
5 Jul 2002
Justo pensé eso... lo que chirría la banderita en algunos sitios. (eso si, raro es que no aparezca la yankee por ningún lado) :cuniao:
Jay Leno tiene varias "cosas" de esas, no? :duda:
