Info: BMW Technical Acronyms
Tema en 'Serie 5 (E34) (1987-1996)' iniciado por The Skerpia, 13 Abr 2009.
  1. The Skerpia
    The Skerpia Forista Legendario
    8 Dic 2007
    Málaga
    e38 e39 e34 e46
    A
    A - processed vehicle speed signal
    A - "out" (Aus)
    AB - Airbag
    ABL - Brake system warning Lamp (2 color)
    ABS - Anti-lock Braking System
    AC - Air Conditioning (from ETK)
    ACC - Active Cruise Control
    ACS - Active Comfort Seats
    ADB(X) - Automatic Differential Braking
    ADS - engine intake air control
    ADV - windshield wiper pressure control
    AEGS - Automatic Electronic Gearbox Control (also EGS)
    AFM - Air Flow Meter
    AGD - suction silencer (from ETK)
    AGR - emission reduction
    AGS - Adaptive transmission control
    AG - Automatic Gearbox (transmission)
    AHK - Active rear-axle Kinematics
    AHK - trailer hitch (from ETK)
    AHM - trailer Module (not for US models)
    AHPS - Advanced HPS
    AIC - Automatic Interval Control (rain sensor)
    AKF - activated carbon canister (from ETK)
    AKS - Active head restraint
    AKS - pressure regulating device (from ETK)
    ALC - Automatic Light Control
    ALR - Automatic Lamp Range Adjustment
    AMM - Air Mass Meter
    AMP - radio system AMPlifier
    ARI - car radio information system (from ETK)
    ARS - Active Roll Stabilization
    ASC - All Season traction
    ASC-EZA - ASC w/ engine timing and injection intervention
    ASC+T - ASC+ Traction control
    ASK - Audio System controller (Kontroller)
    ASR - self starter block relay (from ETK)
    AST - Automatic Slip control (marketing term)
    AT - remanufactured part (from ETK)
    AT - Antenna (from ETK)
    ATF - Automatic Transmission Fluid (from ETK)
    ATL - exhaust gas turbo charger (from ETK)
    AUC - Automatic air recirculation
    AUT - AUTomatic transmission (from ETK)
    AVT - Antenna amplifier Tuner
    AZD - tightening torque specifications (in TIS)
    A/D – Analog/Digital
    B
    B - Benzene (gasoline)
    BAT - BATtery (from ETK)
    BC - Board Computer
    BC1 - Body Controller 1
    BL - Brake Light (from ETK)
    BLS - Brake Light Switch
    BMBT - Board Monitor
    BS - Block diagram
    BST - Battery Safety Terminal
    BVA - Brake pad wear indicator (from ETK)
    BZM - center console control center
    BZMF - center console control center, rear
    C
    CAN – Controller Area Network (Multiple ECU Controller)
    CAN-Bus - Controller Area Network (bus)
    CANH-Bus - CAN bus, High
    CANL-Bus - CAN bus, Low
    CANP - fuel tank ventilation valve
    CAS - Car Access System
    CBC - Corner Braking Control
    CBS - Condition Based Service
    CCM - Check Control Module
    CD - Control Display
    CDC - Compact Disk Changer
    CDS - CD player (from ETK)
    CEL - CELsius (from ETK)
    CIM - Chassis Integration Module
    CO - Carbon monOxide (from ETK)
    COMBI – Electronic Instrument Cluster
    CON - CONtroller
    CU - Copper (from ETK)
    CVM - Convertible top Module
    CVT - Constantly Variable Transmission
    CW - drag coefficient (from ETK)
    D
    D1 - Xenon light/ gas discharge (from ETK)
    D-Bus - Diagnosis bus (same as TXD)
    DBC - Dynamic Brake Control
    DBS - Dynamic Braking System
    DCS - Dealer Communication System
    DE – Diagnostic Unit
    DD - Dynamic motor Drive
    DDE - Digital Diesel Electronics
    DIN - German industrial standards
    DIS - Diagnosis and Information System
    DISA - Differential air intake control
    DIVA - continuously variable length intake runners
    DK - throttle housing/valve
    DKB - throttle w/ brake intervention
    DKE – Throttle Increase
    DKI - throttle position
    DKR - throttle reduction
    DKT - throttle position signal
    DKV - preset throttle position value
    DME - Digital Motor Electronics
    DM-TL - Diagnostic Module Tank Leakage
    DOHC - Double Over Head Camshafts (from ETK)
    DS - gasket set (from ETK)
    DSC - Dynamic Stability Control
    DSP - Digital Sound Processing
    DTC - Diagnostic Trouble Code (SAE)
    DTC - Dynamic Traction Control
    DWA - theft deterrent system
    DWS - tire pressure Warning System
    DZM - revolution counter (from ETK)
    E
    E - "in" (Ein)
    EBA - installation instructions (from ETK)
    EBV - Electronic Brake force proportioning
    ECE - European market version (from ETK)
    ECM - Engine Control Module (SAE term)
    ECU - Electronic Control Unit
    EDC - Electronic Damper Control (from ETK)
    EDR - Electronic throttle control
    E-KAT - Electrically heated catalytic converter
    EZA - see ASC-EZA
    ECO - Controller for I-Drive system
    EDC - Electronic Dampening Control
    EDC-K - Electronic Dampening Control - Continuous
    EDK - Electronic throttle valve
    EDS - pressure regulator
    EFH - Electric window lifter (from ETK)
    EGS - Electronic transmission control
    EH - Electronic-Hydraulic
    EHC - Electronic Height Control
    EKM - Electronic body Module
    EKP - Electric fuel Pump
    ELV - Electronic steering lock
    EM - Electro-Mechanical
    EMF - Electro-Mechanical parking brake
    EML - Electronic Motor Load regulation
    EMV - Electro-Magnetic sensitivity (from ETK)
    EO - component location
    EPC - Electronic Parts Catalog (also ETK)
    EPROM - Erasable/ Programmable chip Memory (from ETK)
    ETK - Electronic parts catalog (also EPC)
    ETM - Electrical Troubleshooting Manual
    ESS - Electronic anti-theft device
    EV - injection Valve
    EWS - Electronic drive-away protection
    F
    FB - Function description
    FBC - Fading Brake Control
    FBD - remote control services
    FBZV - radio frequency locking system
    FGR – Vehicle Speed Control (Cruise Control)
    FH - window lifter
    FHK - rear Heater/ air conditioner
    FLC - automatic Light Control
    FRU - Flat Rate Unit
    FS – Crash Sensor
    FZV - central lock receiver
    G
    GAL - speed dependent sound volume
    GM - General Module
    GMR - yaw moment control
    GPS - Global Positioning System
    GRII - cruise control
    GRS - rotation Rate Sensor
    GS – Belt Tensioner
    GWK - torque converter lock-up control
    H
    H - "rear" (Hinten)
    H2 - Xenon headlights
    HA - rear Axle (from ETK)
    HC – Hydro Carbon
    HD - Heavy Duty (from ETK)
    HDC - Hill Decent Control
    HFM - Hot Film air mass Meter
    HG - manual Gearbox (transmission)
    HKL - Hydraulic trunk lid Lift
    HLM – Hot Wire Air Mass Meter
    HPS - Head Protection System
    HR - Heater control (from ETK)
    HVA - Hydraulic Valve Adjuster (from ETK)
    Hz – Hertz (Cycle)
    I
    I-Bus - Information bus
    IB - Interior lighting control signal
    IHKA - automatic Heating and A/C
    IHKAF - IHKA w/ micro filter
    IHKR - regulated Heating and A/C
    IHKRF - IHKR w/ micro filter
    IHKS - standard Heating and A/C
    IHPD - Internal High Pressure Deformation
    IHR - Integrated Heater control (from ETK)
    IKE - Instrument cluster Electronics
    ILH - Interior Lighting, rear
    ILV - Interior Lighting, front
    IMS - Instant Mobility System (from ETK)
    IR – Infrared
    IRS – Infrared Locking System
    ISC – Idle Speed Control
    ISIS - Intelligent Safety Integration System
    ISN - Individual Serial Number
    ISOFIX - standardized mounts for child restraints
    ITS - head airbag assembly/ Inflatable Tubular Structure
    IVM - Integrated power supply Module
    K
    K-Bus - body bus (Karosserie)
    KAT - catalytic converter
    KATON - converter creating (signal)
    KD - Kick-Down
    KHI - interface for headphones
    KL - terminal designation
    KL15 - run bus (ignition switch run position)
    KL30 - battery bus (hot at all times)
    KL31 - ground bus (chassis ground)
    KL50 - start bus (ignition start position)
    KLR - accessory bus
    KO - compressor "on" signal
    KOMBI - instrument cluster
    KOREL - compressor relay signal
    KR – Contact Ring
    KSK - Knock Sensor
    KVA - fuel consumption signal/value
    KW - crankshaft
    KW - KiloWatt (from ETK)
    L
    LCM - Lamp Check Module
    LDP - Leak Diagnosis Pump
    LEV - Low Emissions Vehicle
    LEW - Lateral acceleration sensor
    LHD - Left-Hand Drive (from ETK)
    LKM - Lamp control Module
    LL - closed throttle
    LM - Light Module
    LMM - air flow meter/sensor
    LMR - Light alloy wheel
    LRA - vertical headlight aiming
    LSM - steering column memory
    LSZ - Lamp Switching center
    LVA - air supply system (for EHC system)
    LWR - vertical headlight aim control
    LWS-5 - steering angle sensor
    M
    M-Bus - IHKA/IHKR stepper motor bus
    MAL - center armrest
    MBC - Maximum Brake Control
    MDK - Motorized throttle valve/system
    MFL - Multi-Function steering wheel
    MFC - Multi-Function Controller
    MFU - Multi-Function Clock
    MID - Multi-Information Display
    MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp
    MIR - Multi-Information Radio
    MMC - Multi-Media Changer
    MoDiC - Mobile Diagnostic Computer
    MOST-Bus - Media Oriented System Transport bus
    MRS - Multiple Restraint System
    MSR - engine drag torque Regulation
    MV - Magnetic Valve (solenoid Valve)
    N
    n-ab - rotational speed, transmission (rpm)
    n-mot - rotational speed, engine (rpm)
    NAVI - Navigation module
    NG - New Generation (as in N73 engine)
    NG - tilt sensor
    NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
    NSD - rear muffler (from ETK)
    NSL - rear fog Lamp (from ETK)
    NSW - fog lamp (from ETK)
    NTC - Negative Temperature Coefficient
    NW - camshaft (from ETK)
    O
    OBC - On-Board Computer
    OBD - On-Board Diagnosis (SAE)
    P
    P/N – Park/Neutral position
    P-Bus - Periphery bus
    PB - Pin assignments
    PBS - Parts Bulletin System (in TIS)
    PDC - Park Distance Control
    PGS - Passive Go System
    PM - Power Module
    PP – Impact Pad
    PTC - Positive Temperature Coefficient
    PWG - Pedal position sensor/ potentiometer
    R
    RA - Repair instructions (in TIS)
    RAM – Random Access Memory
    RAL - Aluminum wheels (from ETK)
    RAL - standard color (from ETK)
    RDC - tire pressure Control
    RDS - Radio Data-broadcast System
    RDW - tire pressure Warning
    RHD - Right-Hand Drive (from ETK)
    RLS - Rain-Light Sensor
    RM - Relay Module
    ROZ - Research Octane rating/ fuel grade (from ETK)
    RPA - tire puncture warning (from ETK)
    RPS - Rollover Protection System
    RS - Repair kit (from ETK)
    RSW - back-up lamp (from ETK)
    RXD - wake-up Diagnosis line
    RZV - direct stationary ignition
    S
    SASL - Satellite, A-pillar left
    SASR - Satellite, A-pillar right
    SAV - Sport ACTIVITY Vehicle
    SB - fuse assignments
    SBE - Seat occupancy detector/sensor
    SBFH - Seat module, passenger-side rear
    SBSL - Satellite, B-pillar left
    SBSR - Satellite, B-pillar right
    SBT - SI techniques/ tech reference information (in TIS)
    SCA - Soft Close Automatic/Actuator
    SD - sliding roof (from ETK)
    SD - silencer/ muffler (from ETK)
    SE - Special Equipment (from ETK)
    SES - voice recognition System
    SFAH - Seat module, driver's side rear
    SFZ - Satellite, vehicle center
    SG - control unit
    SGS - Seat integrated belt System
    SHD - sliding/ lifting roof (from ETK)
    SHD - Sunroof module (also SHDM)
    SI - Service Information (in TIS)
    SIA - Service Interval system (ver. I, II, III, IV, etc.)
    SII - Service Interval Indicator
    SIL - SILicon (from ETK)
    SIM - Safety Information Module
    SINE - Siren/tilt sensor
    SKD - Steel sliding roof (from ETK)
    SKHD - Steel sliding/ lifting roof (from ETK)
    SM - Seat Module
    SM/SPM - Seat/Mirror Memory
    SMBF - Seat Module, passenger side
    SMFA - Seat Module, driver's side
    SMG - Sequential Manual Gearbox
    SP - Schematic
    SRA - headlight/fog light cleaning
    SRS - Supplementary Restraint System
    SSD - Steel sliding roof (from ETK)
    SSH - Seat Satellite, rear seat
    ST - connector views
    Steptronic - transmission shift control
    STVL - Satellite, left front door
    STVR - Satellite, right front door
    SVS - Speech processing System
    SWR - headlamp cleaning system (from ETK)
    SWZ - Special tool listings (in TIS)
    SZL - Switch center, steering column
    SZM - central switch center Module
    T
    TAGE - door handle Electronics
    TCM - Transmission Control Module
    TD - engine speed signal (ignition pulse)
    TD - Technical Data (in TIS)
    TE - fuel evaporation control
    TEL - TELephone control unit
    TEV - evaporative purge control
    THZ - Tandem master cylinder (from ETK)
    ti - Injector "on" Time (duration)
    TIS - Technical Information System
    TL - part throttle / load signal
    TLEV - Transitional Low Emission Vehicle
    TMBFT - door Module, passenger side
    TMBFTH - door Module, passenger side rear
    TMFAT - door Module, driver's side
    TMFATH - door Module, driver's side rear
    TP - Tandem Pump (from ETK)
    TPS - Throttle Position Switch/Sensor
    TR - engine speed signal (rpm)
    TR - TRansistor (from ETK)
    TRG - fuel level sensor (from ETK)
    TRI - Technical Reference Information (also SBT)
    TRS - battery isolation Switch
    TSD - Torsional vibration dampener (from ETK)
    TSH - door lock Heating
    TSZI - Transistorized coil Ignition system (from ETK)
    TU - Technical Update (as in M50tu)
    TXD - Transmitting Diagnosis line
    U
    U-batt - Battery voltage
    U-vers - supply voltage
    UERSS - rollover bar (from ETK)
    URS - rollover protection System
    USIS - Ultrasonic passenger compartment Sensor
    V
    V - "front" (Vorn)
    V - vehicle road speed
    VA - front Axle (from ETK)
    VAT - front axle support (from ETK)
    VANOS - Variable camshaft timing
    VEP - distributor-type injection Pump (from ETK)
    VID - VIDeo module
    VL - full load (wide open throttle)
    VSD - front muffler (from ETK)
    VVT – Valve tronic
    W
    WBG - hazard warning switch (from ETK)
    WDS - Wiring Diagram System
    WIM - Wiper control Module
    WK - torque converter lock-up clutch
    WSS – Wind Shield (from ETK)
    WT – Valve tronic control unit
    Z
    Z - "central" (Zentrum)
    ZAB - ignition fade-out (reduction)
    ZAE - central Airbag Electronics
    ZAS - ignition starter switch (from ETK)
    ZGM - central Gateway Module
    ZK - cylinder head (from ETK)
    ZKE - central body Electronics
    ZKH - cylinder head cover (from ETK)
    ZMS - dual-Mass flywheel (from ETK)
    ZV - central locking system
    ZS - central lock (from ETK)
    ZSD - center muffler (from ETK)
    ZV - central locking system (from ETK)
    ZVM - central locking Module
    ZWD - idle control valve
    A smash y Karryl les gusta esto.
  2. Sebring
    Sebring Forista
    3 Sep 2004
    Clio RS Trophy
    A la saca ;-)
    Muchas gracias Skerpia ;-)
  3. Manol
    Manol ▒▒▒▒▒▒ Miembro del Club
    1 Oct 2006
    Cádiz
    E46 M43B19
    Esto es información, lo demás son tonterías. :descojon::dan:
  4. The Skerpia
    8 Dic 2007
    Málaga
    e38 e39 e34 e46
    :descojon::-({|=
  5. trastornado
    trastornado Forista Senior
    30 Mar 2007
    la coruña/aviles
    muy buena info si señor.....anotate tres puntos colega...........[​IMG]
  6. Neron6
    Neron6 Forista
    31 Jul 2004
    Gandesa
    Muchas gracias por la info.Copiado y guardado.
  7. Gustavo Santander
    Gustavo Santander Forista
    6 Ene 2009
    santander
    Eres la ostia Skerpia!!!=D=
  8. Bribonazo
    Bribonazo Forista
    10 Feb 2008
    Tenerife
    Grandisima informacion, muchas gracias!!
  9. Carlos525TDS
    Carlos525TDS En Practicas
    16 Abr 2008
    ARGENTINA
    Gracias muy buena info...
  10. Gavira
    (∀ꟽ) sn̗uɐꓭ oʇɹǝnԀ
  11. javi.tds
    javi.tds Forista Legendario
    27 Jul 2006
    Me parece indignante que no aprezca el significado de "TDS" [-(
    :descojon::descojon:
  12. gmc
    gmc Forista
    20 Jun 2002
    Bilbao
    E39 528i
    Concreto y conciso. Eres un artista de la informacion.:dan:
  13. Addictive Sound
    Addictive Sound Pon un kratzer en tu vida Miembro del Club
    5 Dic 2007
    salamanca
    muuuuuuy buena info
  14. manuelm5
    manuelm5 Guest
    fantastic si señor
  15. ivanisevich
    ivanisevich Forista
    23 Sep 2007
    talavera de la reina
    530d ///M
    buena informacion guardado queda un saludo
  16. Compact 2002
    Compact 2002 Guest
    mu buenos datos................!!!
  17. Viya
    Viya Forista
    7 Feb 2009
    e46 330d 204cv
    que maravilla!!
    gracias tio, eso merece un premio,
    informacion superimportante,
    voto por que se ponga fijo en el archivo,
    enhorabuena compañero,
    gracias
  18. kalambrety
    kalambrety Forista
    24 Mar 2006
    V.Tietar/Madrid
    Copiado y guardado. Gracias por la info.
