Video Lavadora offroad... pinta que habrá G(eländewagen) EQ en no mucho
Till
Pionero lavadoril
iX1 30M+F850GS
9 Dic 2011
También está este video pero me molesta el exceso de mamadas verbales, el uso excesivo de drones, y la musiquita chumbachumba... pero las subidas sobre el minuto 14 que hacen son aconjonantes
Time to arandeling? :descojon:
Jokin
535d GT/A4 3.0/
12 Abr 2006
Till, no compartes estos temas del EQC en mbfaq porque la edad media de los usuarios es de 84 años, tipo sechs, lo ven como un invento del demonio y lo sabes biggrin
El merchi G 4x4² que mola es este, con su V8, ejes pórtico y demás mandanga :chulo:
https://www.bmwfaq.org/threads/mercedes-benz-g-4x4-2022.998416
Ya lo han cazado sin apenas camuflaje, brutal :pompous:
Undisguised 2022 Mercedes-Benz G-Class 4x4 Squared Has One Portal Axle Left
17 Jul 2020
Quickly after its introduction as a limited-edition model on the previous-generation G-Class, the Mercedes-Benz G 500 (550 in the U.S.) 4x4 Squared got so much attention that the Germans decided to make it part of the Gelandewagen lineup in the long term.
With the current G-Class having recently received a small update earlier this week, now it’s time for the second-generation G 500 4x4 Squared to show its might, with a pre-production prototype having been spotted completely camouflage-free on the road.
We believe it may be the same car we caught back in May on a secret Mercedes-Benz test track, only this time we can get a better look at the technical bits that comprise its suspension.
Since the previous G-Wagen had a solid axle suspension front and rear, it was easier to fit it with the remarkable-looking and ultra-effective portal axles, but that won’t happen on the new model for a very simple reason.
The current G-Class comes as standard with an independent front suspension, which is a much better fit for road comfort and less so for hardcore off-roading. This why the 4x4 Squared in the spy photo gallery only seems to feature a portal axle on the rear, while the front-end has to manage with some oversized and rugged-looking control arms.
The ground clearance seems to be similar to that of its predecessor, which could manage a fording depth of no less than a meter (39.4 inches) and rode higher than a Hummer H1.
Oddly enough, there doesn’t seem to be any visible exhaust under the car, which could imply that the model may also receive a diesel powertrain, at least in Europe. Coincidentally, the only V8 model you can currently buy on the European is the G 63.
This makes us think. There is a slim chance that the only 4x4 Squared available in the States after launch will also wear a Mercedes-AMG badge, while Europe will have a choice between the G 63 4x4 Squared and a G 400 d 4x4 Squared, with the G 500 being retired for good. Take al that with a grain of salt, though.
WIRZON
330Ci_25e_18d
18 Oct 2006
Ta tó inventaoo, al campo sa dicho!
:troll:
jsagar
e81 - g20
27 Ago 2007
en función de la autonomía puede ser una buena opción electrificar los 4x4 para uso extremo en campo.
con un motor por rueda se puede gestionar la tracción sin la necesidad de bloqueos de diferencial y se hacen desaparecer los ejes y palieres, dando mucha mayor libertad y posibilidades de recorrido a los esquemas de suspensiones. además, al no haber elementos de transmisión ni escape ya tienes el fondo plano hecho.
lo que no se es que tal le irá la refrigeración de los motores y baterias a tan baja velocidad.
Till
Pionero lavadoril
iX1 30M+F850GS
9 Dic 2011
Y en el primer video especulan si el EQC Offroad lo han hecho como para ver si tiene sentido convertir un G en eléctrico...
Es más fácil elevar un EQC, ensancharlo, meterle el software de un GLC y poco más, que montarle batería y motor del EQC o similar a un G... y aún así el EQC se maneja muy bien offroad con esas modificaciones.
Me venía a preguntar justamente eso: si para uso realmente off road hasta no será más adecuado (porque hasta permite mucha más milimétrica entrega y reparto de potencia...)
