12 12 011Remove and install / replace all spark plugs (B48)
Special tools required:
Necessary preliminary tasks:
Important!
Wear safety goggles.
Oil and dirt particles may get into your eyes!
Clean spark plug slot with compressed air.
- Remove dirt contamination from the spark plug shaft. The plug shaft must be cleaned with compressed air after the ignition coils have been removed but before the spark plugs have been dismounted. After removing the spark plugs, check the sealing surface again for dirt contamination and if necessary, clean with a damp cloth or again with compressed air.
Note: Deposits that are not removed according to instructions may enter the combustion chamber and lead to uncontrolled combustion. Remaining deposits in the area of the spark plug seal can lead to leaks and to the spark plugs coming loose during engine operation.
- Do not grease/oil thread or use any graphite or copper grease. Adhere to the torque values of the packaging information or regulation.
Note: If these instructions are not followed, especially with regard to greasing, this may result in mechanical damage to the spark plug housing/thread. Spark plugs that are not tightened sufficiently lead to leaks and to the spark plugs coming loose during engine operation.
Removal:
Unscrew spark plugs with special tool
12 1 220 and with an extension of at least 8° kink.
Flexible ratchet extensions must always be used. If rigid mounting tools are used, there is a risk of insulator breakages.
Note: Also do not use a variable plug connection with locking capability as this also poses a risk of insulator breakages.
12 1 220 and an extension with joint.
Installation:
Insert spark plug (1) into the special tool
12 1 230
