M3 E30 Alpina B6 3.5S Catalizator
NOVA
Acabo de estar viendo uno, impresionante, color entre azul y morado, me ha gustado, lo ha importado para guardarlo y ni lo va a matricular por ahora. Teneis algun dato al respecto?? :ang:
NOVA
The Alpina B6 3.5S [Sources : /The Unofficial Alpina Web Site/, /Alpina Germany/]Many consider the first-generation BMW M3 to be the best drivers car ever built by BMW. But the M3 was built far more for competition and serious road use than for everyday transportation with it´s raw four-cylinder engine, which is not nearly as smooth as a straight six. The M3-based Alpina B6 3.5S, which is considered to be one of Alpina´s finest efforts ever, had the best of both worlds with the performance of the powerful and smooth 3.5 litre six-cylinder engine mixed with the handling capabilities of the M3. Unfortunately only 62 cars were produced between August 1986 and December 1990.
Engine/GearboxAlpina use their own version of BMW´s big 3.5 litre six in the small 3-series body. This makes the car 125kg heavier then the A/C equipped standard M3. Alpina has modified the cylinder head, the combustion chambers, fitted lighter, higher-compression Mahle pistons, a new camshaft and a new exhaust system to make the engine produce 254 hp @5900 rpm and 320 Nm @4000 rpm. A Getrag 5-speed unit with a “sportgetriebe” replaces the standard gearbox with the first gear down to the left; also called a dogleg gearbox.
Suspension/Brakes/Wheels
The B6S share the chassis with the standard M3, which is considered to have probably the best chassis ever built by BMW. The only difference is that the B6S is equipped with the front springs from the A/C-equipped M3´s. Those are a little bit stiffer to handle the extra-weight. The brakes are standard M3 brakes. The trademark Alpina-wheels are 20-spoke 16"x8" both at front and rear with 225/45 tires; 17" as an option.
Interior/Exterior
The seats have been replaced with Recaro items with blue and green stripes. The steering wheel is leather-covered. The speedo has been replaced and there are new digital-instruments. The exterior changes include a new front spoiler, rear spoiler, the wheels and the optional Alpina stripes.
Performance
Alpina claimed a 0-100 km/h time of 6,6 seconds (the same time as the E30 B6 3.5). But according to Sports Car International's test of the B6 3.5S it could accelerate from 0-100 km/h in only 6 seconds, 0-160 km/h in 14.6 seconds, 0-200 km/h in 26.2 and had a top speed of 253 km/h. That is 5 km/h faster than BMW's ultimate M3, the M3 Sport Evolution.
NOVA
NOVA
Era un color azul-morado, tengo una foto del movil, en cuanto pueda os la subo, sino ya tendre oportunidad de verlo otro dia.
URIEL
Efectivamente tengo conocimiento de dicha unidad.
En principio es un Alpina B6s (habria que mirar su numero de chasis para asegurarlo) y el color es el Alpinablau, color exclusivo de Alpina.
H
hrcteam
Guest
hola sobre el m3 e30 alpina que as dicho,que esta sin matricular,no estara cerca de ondarroa no?porque ya tube un pequeño pique jeje,es precioso y flipe como andaba,un saludo............
El Enfermo
hrcteam;4709981 dijo:
Estaba sin matricular.....biggrinbiggrin
Ahora, sabe Dios... menuda rescatada de los fondos del foro... el post es de Noviembre....:descojon::descojon:
POR CIERTO NOVA... TODAVIA NO HAS PUESTO LA FOTO DEL MOVIL, MAMONASSSOOOO...:finga::finga::finga:
birdhouse
Es impresionante!! :xray::xray::xray: Pero su precio de venta estara por las nubes, quiza mas que un EVO no?
