Pues estaba leyendo y he dicho, voy a postear para ver que dicen al respecto. Suspension: TC Kline Trackline Kit TC Kline Single Adjustable Front & Double Adjustable Rear Koni Shocks TC Kline H&R Sport Springs TC Kline Solid Monoball Rear Mounts with TurnerMotorsport Reinforcing Plate TurnerMotorsport Adjustable SwayBar Link X Chasis Brace Greatest upgrade done yet, especially for $150. simple install on 96 & newer cars. Reduces understeer in less than a half hour. E30 ALuminum Control Arms Powerflex Bushings Centered Front Control Arm Bushing Rear Trailing Arm Bushings (Welded RTAB Carrier) Engine/Powertrain: Fluidyne Radiator Stock Style - Great Fit&Finish - easy install UUC Transmission Mount Enforcers & Bushings Worth it UUC Clutch Pedal Bushing P.I.T.A. - ... and it still squeaks Brakes: Front Rotors - Crygenically Frozen Euro Floating Rear Rotors - Crygenically Frozen Brembo Pads - Hawke HP + I have been using these pad since 8.2002 - work well at all levels from novice to C.R. Expect tons of dust Maintenance: TIRES: TRACK Tires & Wheels: 17x8 BBS RC 225/40/17 Kumho Victoracers - good 225/40/17 Kumho Ecsta V700 expired shelf life compound - good for th $40/corner SUMMER Tires & Wheels: Bridgestone Potenza S-03 Pole Positions - Great Wet & Dry Traction Potenza RE 730 - Loud tire, but great wet and ok dry traction WINTER Tires & Wheels: 16x7 Borbet Type "T" Bridgestone Blizzaks MZ-02 - only mount during storage - were Great SPARK PLUGS: Bosch Super 2 P/N- ??? They Stunk, I will never buy again. FLUIDS: Engine Oil: Mobil One Synthetic 20W50 Differential Fluid Redline 75W90 Transmission Fluid Synthetic ATF D4 fluid - which is Dexron III approved Brake Fluid: ATE Super Blue & or the Gold Stuff WAX: Zymol Carbon HD Cleanse
Yo añadiria en el campo motor, los inyectores de mas capacidad, bomba de gasofa de mas capacidad, colectores mas ligeros y supresor, bobinas de plasma, volante de motor ligero, admision directa de carbono (aire fresquito ), radiador de aceite de mas capacidad y bomba de aceite tambien, manguitos de silicona nuevos y ya que abres, pues valvulas nuevas con muelles y todo lo mejorable etc..... un autoblocante tarado al menos al 50% un tubo de transmision mas ligeroP) quitar asientos y "decoracion", poner barras y parriba!!!!!!!!!!P) P) P) P) P)
Casi naaa Jimmy, juassss voy a mirar mas por este mundillo de internesss si encuentro alguna interesante.
Tu coche ya lleva esto: X Chasis Brace Greatest upgrade done yet, especially for $150. simple install on 96 & newer cars. Reduces understeer in less than a half hour.
Una cosa mejorar un ///M3 E36 .....para que?...hombre si me dices unas mejoras para un E46, un AMG otomatico...o un Multipla,lo entenderia ! pero un genuino representante de ///MotorSport!!..............de verdad y como amigo tuyo k sabes que soy y que te aprecia en el Alma para siempre ....no se...Hala Besitos para los que estan dando puñetazos en el teclado..k alguno habra!! -. . . . . . . . . . . . . . . . . . . . . . . . .. REKETE///MEGALO JUASSSSSsssssssssssssssssssssssssssssssssssssss
Calla mariscon!!! oye habra que preparar una cenita antes de navidad y unos :drinkers por beasain no, le avisamos a gaintza y alguno mas o has dejado estos asuntoes desde que estas casado???
Mucho ///Marikita junto.... no puede ser... Ya hablaremos, que ahora.. entre cumple... cenas de curro y cuadrilla.... tengo la agenda un pelin saturada.....:drinkers:drinkers:drinkers:drinkers P.D. Se aceptan donaciones de Higado.. razon aqui...
Por si alguien quiere hacer pruebas!!!! Vendo mi bmw m3 modelo e36 321cv finales del 97 Tiene averia de motor, todo lo demas estado impecable 8000euros negociables para cualquier pregunta llamar al 616702360 bittor
Vendo M3 E30 año 1991,rojo,160000 km,techo solar,buen estado,sin golpes.11000€,605709904. http://www.coches.net/ocasion/ficha.cfm?id=8232405&orden=foto PD: este pone beasain y no lo he visto en mi vida!!!
Suspension Bilstein PSS9 (Regulable presion 9 posiciones y altura) Full equipe Julio 98 10500 km 650403569 No contesto en el foro llamar por telefono o por correo electronico a pablopardo26@hotmail.com
Se vende m3 e36 286 , Año 96,amarillo,doble airbag, climatizador bizona. , con llantas del serie limitada (mas bonitas y ligeras del m3 1995 gt) , Alarma original con cierre de ventanas, interior en prfecto estado y ADEMÁS lleva electronica modificada hace 2 meses (320 cv aprox), escape de acero inoxidable supersprint, y SUSPENSION ROSCADA BISLTEIN DE MUELLE ESTRECHO EIBACH. La ventea me urge muxisimo asi que si os interesa: 660 200 723
