Fotos Mercedes-AMG G63 4x4² (2022) V8 585 cv
Tema en 'Foro General BMW' iniciado por cybermad, 17 Jul 2020.
  1. cybermad
    Ya lo han cazado sin apenas camuflaje, brutal :pompous:
    Undisguised 2022 Mercedes-Benz G-Class 4x4 Squared Has One Portal Axle Left
    17 Jul 2020
    Quickly after its introduction as a limited-edition model on the previous-generation G-Class, the Mercedes-Benz G 500 (550 in the U.S.) 4x4 Squared got so much attention that the Germans decided to make it part of the Gelandewagen lineup in the long term.
    With the current G-Class having recently received a small update earlier this week, now it’s time for the second-generation G 500 4x4 Squared to show its might, with a pre-production prototype having been spotted completely camouflage-free on the road.
    We believe it may be the same car we caught back in May on a secret Mercedes-Benz test track, only this time we can get a better look at the technical bits that comprise its suspension.
    Since the previous G-Wagen had a solid axle suspension front and rear, it was easier to fit it with the remarkable-looking and ultra-effective portal axles, but that won’t happen on the new model for a very simple reason.
    The current G-Class comes as standard with an independent front suspension, which is a much better fit for road comfort and less so for hardcore off-roading. This why the 4x4 Squared in the spy photo gallery only seems to feature a portal axle on the rear, while the front-end has to manage with some oversized and rugged-looking control arms.
    The ground clearance seems to be similar to that of its predecessor, which could manage a fording depth of no less than a meter (39.4 inches) and rode higher than a Hummer H1.
    Oddly enough, there doesn’t seem to be any visible exhaust under the car, which could imply that the model may also receive a diesel powertrain, at least in Europe. Coincidentally, the only V8 model you can currently buy on the European is the G 63.
    This makes us think. There is a slim chance that the only 4x4 Squared available in the States after launch will also wear a Mercedes-AMG badge, while Europe will have a choice between the G 63 4x4 Squared and a G 400 d 4x4 Squared, with the G 500 being retired for good. Take al that with a grain of salt, though.
    Josué, Juankmen, SP_Kenny y 6 otros les gusta esto.
  2. Curro
    Curro Clan Leader
    30 Nov 2013
    Z3 Coupe 2.8
    Sigue igual que es lo mejor que se puede decir de él.
    chamadyco, Juankmen, TOMASIN5 y 4 otros les gusta esto.
  3. cybermad
    Ponerle camuflaje es tontería... a ver como pasa desapercibido esta bestia, para hacerse una idea así es junto a un G "normal" que no es ningún utilitario precisamente :pompous:
    Última edición: 17 Jul 2020
    agc, Josué, Juankmen y 4 otros les gusta esto.
  4. exploxivo
    exploxivo Forista
    27 Ene 2006
    sevilla
    Después de verlo en persona solo puedo decir que me compraría uno sin dudarlo si me sobrara la pasta.
    Vaya si impresiona en directo.
    A Juankmen le gusta esto.
  5. *NANO*
    *NANO* Clan Leader
    Así es. Un coche del que no te haces una idea hasta que lo ves en directo junto al resto del tráfico.
    Yo aluciné la primera vez que lo vi. Impresionante.
    A Juankmen y Snatch les gusta esto.
  6. Curro
    Curro Clan Leader
    30 Nov 2013
    Z3 Coupe 2.8
    Lo han hecho más grande?
  7. nebur
    la coruña
    Que tonteria es esa del 4 al cuadrado? Es por su forma de la carroceria? Tira a la rueda de repuesto? O cuentan tambien la marcha atrás?
  8. *NANO*
    *NANO* Clan Leader
    DAA287CA-C59D-4072-A661-A31022F2A780.jpeg 2ADFC7C2-9BA3-474F-B664-1AD158DCCA0F.jpeg
    agc, Josué, Juankmen y otra persona les gusta esto.
  9. Trackball
    Trackball Clan Leader
    26 Ene 2016
    www.lakdd.com
    El de la mujer
    Ejes portico. Pero me da que ese delante no lo lleva. O lo lleva modificado perdiendo parte de la gracias con esos tirantes.
    Ahora es mucho más coche. Se deja conducir, cosa que antes era una guerra :guiño:
    Última edición: 18 Jul 2020
    A Juankmen, TOMASIN5 y nebur les gusta esto.
  10. jonnyjar23
    jonnyjar23 Forista
    9 Ago 2012
    BMW M3 e92
    Menudo tanque!! Me encanta!!!
    Es un coche que o adoras o odias, a mi personalmente siempre me han gustado los clase G. Absolutamente todos sus modelos y variantes y al contrario que pasa con otros modelos, cada generación es mucho mejor que su predecesora en absolutamente todos los sentidos. Yo me uno al carro de “teniendo pasta tendría uno” por que simplemente es, el mejor todoterreno del mundo.
    A Juankmen, Yitzak y TOMASIN5 les gusta esto.
  11. nebur
    la coruña
    Que es ejes portico? Como los de los trastores? Con bambaneo hacia los lados tambien ?
    4x4 entiendo que puede traccionar cada una de las 4 ruedas por independiente . Ese cuadrado .. marketin a parte .. no se lo que es .
    De hecho solo va en el segundo 4 .
  12. Trackball
    26 Ene 2016
    www.lakdd.com
    El de la mujer
    liberar espacio entre los bajos y el suelo.
    Lo que convertía conducir ese bicho, con ese motor, en una locura. YA con la dirección del viejo era “curioso”, pues con esa configuración ni digamos. :floor:
    Josué, Manguan, Juankmen y 2 otros les gusta esto.
  13. nebur
    la coruña
    Como los trastores zancudos de antaño
    A Manguan, chamadyco y Juankmen les gusta esto.
  14. cybermad
    A nebur y hpgomez les gusta esto.
  15. hpgomez
    hpgomez Forista Miembro del Club
    26 Jul 2011
    F30
    La verdad es que me encanta!!!
  16. cybermad
    Solo lo lleva detrás en esta versión, lo dice en el artículo, que llevará suspensión delantera independiente como el clase G para mejorar la conducción por carretera.
    "Since the previous G-Wagen had a solid axle suspension front and rear, it was easier to fit it with the remarkable-looking and ultra-effective portal axles, but that won’t happen on the new model for a very simple reason.
    The current G-Class comes as standard with an independent front suspension, which is a much better fit for road comfort and less so for hardcore off-roading. This why the 4x4 Squared in the spy photo gallery only seems to feature a portal axle on the rear, while the front-end has to manage with some oversized and rugged-looking control arms."
  17. Trackball
    26 Ene 2016
    www.lakdd.com
    El de la mujer
    Es que en carretera eso es “muy divertido” y más con un motor como el que lleva :floor::floor::floor:.
    Un locuron de sensaciones :dead:
  18. Yitzak
    Yitzak Forista Senior
    21 Sep 2012
    El clase G es un fósil viviente del pasado, una reliquia, una rara avis. Espero que Mercedes lo siga fabricando muchos años. Demos gracias a que en mercados exóticos se vende bien porque lo que es en España y Europa occidental, poquísimos.
  19. Llorens
    Llorens Forista Legendario
    27 Ago 2010
    Barcelona
    X3
    Cuesta una barbaridad, ponte a configurar uno y enseguida te plantas en 160k.
    Nadie duda de sus capacidades off-Road, pero siendo realistas no creo que la mayoría de sus propietarios lo metan en barrizales para ponerlo a prueba.
    El Cayenne en ese nivel de precios arrasa en calidades y en todo, aunque no tenga la misma capacidad de vadeo o ángulo de ataque. :guiño:
    A pUllastre le gusta esto.
  20. BLUEBIRD
    BLUEBIRD Forista Senior
    5 Ene 2008
    Sevilla
    Es para las milfs rusas de San Petersburgo y lo sabeis.
    Josué, AMM5, chamadyco y 4 otros les gusta esto.
  21. Yitzak
    21 Sep 2012
    Permítame que dude lo de las calidades.
  22. Llorens
    27 Ago 2010
    Barcelona
    X3
    Si no percibes las calidades que ofrece un Cayenne no hay más que hablar.
    Agur.
    A fu_103 le gusta esto.
  23. Yitzak
    21 Sep 2012
    Me gustaría ver esos acabados despues de usarlo en offroad intensivamente, no sólo para ir al Carrefour.
  24. jonnyjar23
    jonnyjar23 Forista
    9 Ago 2012
    BMW M3 e92
    Lo del precio es cierto, son coches muy caros de comprar y también de mantener.
    Que poca gente se compre uno para meterlo en montaña con uso intensivo también es cierto ya que al final se usa más como coche de lujo que como off-Road.
    Sin embargo en el apartado de que un Cayenne arrasa en calidades discrepo y mucho además. Si bien es cierto que la calidad de ensamblado de Porsche es de lo mejor que hay, el clase G no se queda atrás para nada. Yo creo que ahí ya entran más los gustos personales de cada uno y en mi caso, dame la estética exterior y el interior del G antes que el de un Cayenne por muy equipado que esté. Ambos tienen lo mejor lo mejor en cuanto a acabados por tanto no comparto que un Cayenne esté por delante de un G en ese aspecto.
    A AMM5 y *NANO* les gusta esto.
  25. Llorens
    27 Ago 2010
    Barcelona
    X3
    Vale, acepto que en calidades estén a la par, pero esa línea tan cuadrada echa para atrás a más de una.....cuando el interesado lo propone en casa biggrin
  26. nebur
    la coruña
    Como el Lada Niva
    A Yitzak y TOMASIN5 les gusta esto.
  27. TOMASIN5
    TOMASIN5 Forista
    11 Nov 2015
    Zaragoza
    BMW 520 e 34
    Te referirás al motor 1721cc Renault que ya montaban en el Supercinco.
    Igualico que el Amg. Neburciño
    A nebur le gusta esto.
  28. nebur
    la coruña
    El diseño eterno .. me referia al diseño eterno de carroceria .
    A TOMASIN5 le gusta esto.
  29. TOMASIN5
    TOMASIN5 Forista
    11 Nov 2015
    Zaragoza
    BMW 520 e 34
    Tú sí que eres Eterno
  30. Yitzak
    21 Sep 2012
    Exacto, otro clásico atemporal.
