MULF Módulo Combox Bluetooth R60
  • Iniciador del tema Metralleto
  • Fecha de inicio
M
Metralleto
Hola!
Tengo un R60 y el manos libres integrado se ha ido (por lo visto es algo relativamente frecuente). Lo quiero cambiar pero no hay manera de saber dónde está, ya que el catálogo no es excesivamente claro.
Seguro que alguno de vosotros lo ha cambiado ya, para evitar desmontar entero el coche...
imgres
Gracias!!!!!
elrinconoriginal
318D
28 May 2007
Home / MINI R60 Cooper SAV / Repair Manuals and Technical Data / 84 Communication systems / 84 10 Combox, TCB, USB hub, telephone /
84 10 800Removing and installing/replacing Combobox
1R6h4m3
Important!
Read and comply with notes on protection against electrostatic discharge (ESD protection).
1Jvu2xy
Note:
Comply with notes and notes on handling optical fibres.
1Ly5z2h
Necessary preliminary tasks:
Dxqns3gZ
Release screws.
Remove trim (1) upwards.
EpCepafu
Cut carpet (1) to size in area (2) and raise up in direction of arrow.
EpLMAUGb
Important!
The holes must be opposite from each other!
Punch the carpet (1) with hole punch pliers (2).
EpEQhayW
Installation note:
Fasten the carpet (1) with cable straps (2).
EpEoosx0
Release screws (1).
Remove the holder for the Combox (2) upwards. Unlock plug connections behind and disconnect.
Installation note:
Observe colour coding of aerial connectors.
Make sure the holder for the Compox (2) is correctly seated.
EpNaAmsY
Release screws (1).
Remove the Combox (2) from the holder (3).
Installation note:
Make sure the Combox (2) is correctly seated.
Mini Countryman
8 Feb 2020
c**o que te he contestado en ingles!!
Muchas gracias. Me viene muy bien la info.
Mañana mismo me lio con ello.
Perdona por tardar tanto en contestarte pero no me ha sido posible...
