nabego
- Modelo
- X3 30d M G01
- Registrado
- 12 Sep 2007
- Mensajes
- 1.921
- Reacciones
- 730
Hola, bueno por si alguno no lo sabe os dejo esta codificacion que he rescatado de un colega del foro internacional, no lo he traducido porque @ObiWan me echa la bronca, jejeje:
F10s come with a wide arrangement of seats. They can be either Comfort or Standard, Front Heated seats, Rear Heated seats, and Ventilated seats. The codes below apply directly to those with Comfort / heated and ventilated front seats and with heated rear seats. I suspect they also apply to other configurations (see notes below).
As far as I am concerned, the seat heating in my car works quite well and it is fast. On the other hand, the ventilation (cooling) leaves a lot to be desired, especially if you live in a hot climate. Both the heating and ventilation of the seats can be adjusted to your specifications by changing the codes below.
Front seat heating
To switching on seat heating you press the button shown below once for each temperature level.
The maximum temperature is reached when three LEDs are lit.
The default temperatures are:
Seat Heater position 1 cushion Werte=20 (32° C)
Seat Heater position 2 cushion Werte=24 (36° C)
Seat Heater position 3 cushion Werte=2D (45° C)
Seat Heater position 1 back seat Werte=1D (29° C)
Seat Heater position 2 back seat Werte=21 (33° C)
Seat Heater position 3 back seat Werte=2B (43° C)
The settings can be adjusted by changing the werte values in the following codes. Remember the werte values are in hexadecimal.
Front driver seat cushions:
SM [6d]->3007 SITZHEIZUNG, 1C->SHZ_TEMP_SOLL_ST1_KI
SM [6d]->3007 SITZHEIZUNG, 1C->SHZ_TEMP_SOLL_ST2_KI
SM [6d]->3007 SITZHEIZUNG, 1C->SHZ_TEMP_SOLL_ST3_KI
Front driver seat back:
SM [6d] ->3007 SITZHEIZUNG, 1C->SHZ_TEMP_SOLL_ST1_LE
SM [6d]->3007 SITZHEIZUNG, 1C->SHZ_TEMP_SOLL_ST2_LE
SM [6d]->3007 SITZHEIZUNG, 1C->SHZ_TEMP_SOLL_ST3_LE
Corresponding values can be found for the front passenger seat in the SM [6e] ECU
Front active seat ventilation
The seat cushion and backrest surfaces are cooled by means of integrated fans.
To switching on press the button shown below once for each ventilation level. The highest level (coolest) is active when three LEDs are lit.
Seat cooler position 1 cushion Werte=23 (35° C)
Seat cooler position 2 cushion Werte=21 (33° C)
Seat cooler position 3 cushion Werte=1E (30° C)
Seat cooler position 1 back Werte=23 (35° C)
Seat cooler position 2 back Werte=21 (33° C)
Seat cooler position 3 back Werte=1E (30° C)
SM [6d]->3008 SITZKLIMA, 13->SKL_TEMP_SOLL_ST1_KI
SM [6d]->3008 SITZKLIMA, 13->SKL_TEMP_SOLL_ST2_KI
SM [6d]->3008 SITZKLIMA, 13->SKL_TEMP_SOLL_ST3_KI
SM [6d]->3008 SITZKLIMA, 13->SKL_TEMP_SOLL_ST1_LE
SM [6d]->3008 SITZKLIMA, 13->SKL_TEMP_SOLL_ST2_LE
SM [6d]->3008 SITZKLIMA, 13->SKL_TEMP_SOLL_ST3_LE
I selected 25° C (werte=19) for my position 3 ventilation setting and it works great.
The rear seat adjustment are a bit less flexible. The settings correspond to both seats in the back. The defaults there are as follows:
Seat Heater position 1 seat back 32° C
Seat Heater position 2 seat back 36° C
Seat Heater position 3 seat back 45° C
Seat Heater position 1 cushion 32° C
Seat Heater position 2 cushion 36° C
Seat Heater position 3 cushion 45° C
The settings can be changed by changing the values (just a few choices with those) in the following codes:
Rear seat back:
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C->TEMP_LEHNE_STUFE_1_FOND
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C->TEMP_LEHNE_STUFE_2_FOND
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C->TEMP_LEHNE_STUFE_3_FOND
Rear seat cushions:
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C ->TEMP_SITZ_STUFE_1_FOND
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C ->TEMP_SITZ_STUFE_2_FOND
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C ->TEMP_SITZ_STUFE_3_FOND
Note:
For some of you, the heating of your seats may not be controlled by the settings in the SM ECU or your car may not have the SM [6d] and SM [6e] ECUs. I would suggest you look the codes below to adjust the heating of your front seats.
Front seat back:
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C-> TEMP_LEHNE_STUFE_1_FRONT
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C-> TEMP_LEHNE_STUFE_2_FRONT
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C-> TEMP_LEHNE_STUFE_3_FRONT
Front seat cushions:
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C -> TEMP_SITZ_STUFE_1_FRONT
JBBFE->3050 SeatHeating_AdditionalSeatFunctions, 1C -> TEMP_SITZ_STUFE_2_FRONT
JBBFE->3050SeatHeating_AdditionalSeatFunctions, 1C -> TEMP_SITZ_STUFE_3_FRONT
While the codes above are present in all cars, at least in my car, the front seat heating and ventilation is controlled in the SM [6d] and SM [6e] ECUs.
Front seat heating
Rear seat back:
Rear seat cushions:
Note:
Front seat back:
