650 CV. No ta mal Water Cooled-Flat-6 w/Dry Sump Lubrication position Rear Longitudinal aspiration Twin KKK turbochargers w/Integrated Wastegates valvetrain DOHC, 4 Valves per Cyl w/Varible Valve Timing fuel feed Electronic Bosch fuel injection power 484.7 kw / 650 bhp @ Not Available rpm drive wheels Rear wheel drive body / frame Unit Steel front brakes Cross-Drilled & Inner Vented Discs w/ABS, Monobloc Calipers rear brakes Cross-Drilled & Inner Vented Discs w/ABS, Monobloc Calipers front wheels F 48.3 x 22.9 cm / 19.0 x 9 in rear wheels R 50.8 x 31.8 cm / 20 x 12.5 in front tire size 255/35 ZR 19 Pirelli rear tire size 345/25 ZR 20 Pirelli tyres f suspension RUF Sports Suspension, Adjustable in Ride Height and Stiffness r suspension RUF Sports Suspension, Adjustable in Ride Height and Stiffness transmission Six-speed manual with customer-specified gear ratios top speed 354.1 kph / 220.0 mph 0 - 60 mph 3.7 seconds
y este el 997 cabrio techart : le sacan 375 al carrera s i 345 al carrera. bastante discretos, me gusta
A mí los de Tech Art me gustan, P) ese descapotable negro... P)P) ... parecen más comedidos con el atuneamiento
