Video Nurburgring 2019: más webcam, terminando asfaltado... y abierto
Buena estrategia comercial. Como si la necesitasen.
mansiman
5 May 2016
A esa velocidad de refresco poca chicha se va a ver...
Pásate a la fibra hooooooombre!
RS01
2 Jul 2007
Pero no son en vivo y en directo, vaya bajon :(
Christian.arg
15 Nov 2015
Una pena porque con cámara en vivo y demás sería la ostia,el gran hermano del ring,sobre todo los talegazos
Ya lo abren el més que viene, aquí se ven las nuevas reformas del trazado :)
2019 Nurburgring Layout Changes Explained in Live Video, The Tarmac Is Fresh
The fresh piece of footage we have here shows the current state of the track, with Nurburgring settler Misha Charoudin delivering plenty of live impressions - note that we're talking about the Nordschleife here, with the GP track having briefly welcomed cars earlier this month thanks to the brilliant weather.
We're looking at the most serious construction work performed in many years, with multiple sections of the track having received fresh asphalt (it's not just that top layer, with the changes going deep).
Once again, the bump before the Schwedenkreuz entry has been ironed out. And while this takes away a bit of the excitement, it doesn't just come with the advantage of making things safer - the Sx, as those in the know call this corner, with its high-velocity aura, is arguably the most dangerous one across the 20.8 km track.
For instance, the whole width of the track in now available for overtaking, which will be especially useful during VLN races (the first testing session kicks off on March 16th).
The famous German track has also been gifted with extra protection fences and, for instance, the clip allows us to check out this through the Hatzenbach section of the track.
As explained in the clip, it will take a few days of full "traffic" for the fresh asphalt to deliver its full grip, but the transition sections are smooth and obviously don't cover braking areas.
Nevertheless, fans will probably start writing across the fresh asphalt again, even though officials have asked them to refrain from doing so in order to minimize grip-related risks.
While we usually mention the hot points for videos longer than five minutes, we have to tell you that the one below is worthy of your undivided attention.
SP_Kenny
8 Ago 2007
Este año, nuevos records a tutiplen?
Dani_330Cabrio
9 Ene 2008
Seguro, este ya tiene el record del primer piñazo del año :devil:
Creo que el primero grabado ha sido un BMW e36. Que penita de Fiesta ST, es muy parecido al mío :lloro:
-ENRI-
30 Jul 2006
Con esto de los eléctricos, se les va a fastidiar el negocio, porque conducir un electrodoméstico de esos por ahí no debe resultar nada gratificante...
