Video Porsche 718 Cayman GT4 Clubsport
Tema en 'Foro General BMW' iniciado por cybermad, 4 Ene 2019.
  1. cybermad
    Stronger, faster and more sustainable on the racetrack
    New Porsche 718 Cayman GT4 Clubsport featuring natural-fibre body parts
    Stuttgart. Three years after the premiere of the first Cayman GT4 Clubsport, Porsche now unveils its successor: The new 718 Cayman GT4 Clubsport represents a consequent further development of the successful model from Weissach. For the first time, the near-standard mid-engine racer comes in two versions ex-works: the “Trackday” model for ambitious amateur racing drivers and the “Competition” variant for national and international motor racing.
    In developing the new 718 Cayman GT4 Clubsport, the focus was put not only on further improved driveability and faster lap times but also on the sustainable use of raw materials. The 718 Cayman GT4 Clubsport is the first ever production race car to feature body parts made of natural-fibre composite material. The driver and co-driver doors and the rear wing are made of an organic fibre mix, which are sourced primarily from agricultural by-products such as flax or hemp fibres and feature similar properties to carbon fibre in terms of weight and stiffness.
    Powering the 718 GT4 Clubsport is a 3.8-litre flat-six engine producing 313 kW (425 hp). Compared to its predecessor, this represents a 40-hp increase in performance. The power is transferred to the rear wheels via a Porsche dual-clutch gearbox with six gears and mechanical rear axle differential lock. The lightweight spring-strut front suspension is taken from its big 911 GT3 Cup brother. The impressive racing brake system features steel brake discs all round measuring 380 millimetres in diameter. Tipping the scales at 1,320 kilograms, the 718 Cayman GT4 Clubsport, delivered ex-works with a welded-in safety cage, a racing bucket seat as well as a six-point harness, is a real lightweight.
    The basis “Trackday” version is aimed at amateur drivers who want to take part in private track and clubsport events without major effort and outlay. The vehicle features a fixed shock absorber setup. The ABS, ESC and traction control assistance systems ensure forgiving handling at the limit and can be deactivated. Also delivered ex-works is the air-conditioning system, a rescue hatch in the roof, a handheld fire-extinguisher and an 80-litre FT3 safety fuel cell. The non-road-homologated vehicle can be serviced at all Porsche Centres. The 718 Cayman GT4 Clubsport “Trackday” costs 134,000 Euro plus country-specific VAT.
    The “Competition” model features a raft of details relevant for racing. The shock absorbers can be adjusted in three stages. The safety fuel tank with a capacity of 115 litres is suitable for long-distance events. Thanks to a brake balance system, the balance bias can be infinitely adjusted between the front and rear axle. An integrated air jack system guarantees fast pit stops. The quick-release racing steering wheel adopted from the 911 GT3 R ensures a range of adjustment options for the individual needs of the drivers. An automatic fire extinguishing system adds another safety feature for the racetrack. The 718 Cayman GT4 Clubsport “Competition” is priced at 157,000 Euro plus country-specific VAT.
    “The new Porsche 718 Cayman GT4 Clubsport possesses significantly more racing genes than its successful predecessor,” says Porsche’s head of motorsport Fritz Enzinger. “The power of the engine has increased considerably. At the same time, we were able to increase the downforce and the cockpit is now even better suited to drivers’ needs. I’m confident that we can build on the excellent sales figures of the predecessor, of which we have delivered 421 cars.”
    Both versions can be ordered immediately and will be delivered to teams and drivers around the world from February.
    Technical description Porsche 718 Cayman GT4 Clubsport (Type 982)
    Concept
    • Single-seater, near-standard production-based race car, not road homologated
    Engine
    • Aluminium six-cylinder mid-positioned boxer engine with rigid mounting
    • 3,800 cc; stroke 77.5 mm, bore 102 mm
    • Max. power: 313 kW (425 hp) at 7,500 rpm
    • Max. rpm: 7,800 rpm
    • Max. torque: 425 Nm at 6,600 rpm
    • Compression ratio: 12.5:1
    • Racing optimised water cooling with thermal management for engine and gearbox
    • Four-valve technology with adjustable camshaft phasing and variable valve timing VarioCam Plus
    • Fuel quality: Super Plus unleaded, minimum 98 octane
    • Racing optimised electronic engine management (Continental SDI 9)
    • Integrated dry sump lubrication
    • 100-cell metal catalytic converter complying with DMSB specifications
    Transmission
    • Rear wheel drive
    • 6-speed PDK gearbox with rigid suspension and electronic control unit optimised for racing
    • Reinforced dual mass flywheel
    • Internal pressure oil lubrication with active oil cooling
    • Differential lock optimised for racing
    Bodywork
    • Lightweight body in aluminium-steel composite construction
    • Welded-in roll cage, certified according to FIA Art. 277
    • Front bonnet with quick release fasteners
    • Rear hood with quick release fasteners
    • Fixed rear wing with “swan neck” mount made of natural-fibre composite materials, including the sideblades, black aluminium wing supports with integrated carbon fibre Gurney flap
    • Driver and co-driver doors of natural-fibre composite materials
    • Roof including escape hatch, certified according to FIA Art. 275a
    • Recaro race bucket seat with longitudinal adjustment and padding system, adjustable to the individual needs of the drivers (in accordance with FIA Standard 8862/2009 – the latest FIA requirements)
    • Three-piston air jack system (“Competition”)
    • Pre-installed mounting points for three-piston air jack system (“Trackday”)
    • Provision for safety net
    • FIA-certified towing loops, front and rear
    • Motorsport centre console with enhanced functionality and adapted usability
    • Six-point safety harness
    • 115-litre FT3 safety fuel cell with “Fuel Cut Off” safety valve complying with FIA regulations (“Competition”)
    • 80-litre FT3 safety fuel cell with “Fuel Cut Off” safety valve complying with FIA regulations (“Trackday”)
    Suspension
    Front axle:
    • MacPherson suspension strut, adjustable in height, camber and track
    • Forged suspension links: optimised stiffness, double shear mounting, high-performance spherical bearings
    • 5-bolt wheel hubs
    • Racing 3-way shock absorbers with rebound and 2-stage compression adjustment, high and low speed (“Competition”)
    • Fixed shock absorbers (“Trackday”)
    • Electromechanical power steering with variable steering ratio
    • Anti-roll bar, 3-hole design
    Rear axle:
    • 5-bolt wheel hubs
    • Adjustable blade-type anti-roll bar
    Brake system
    Front axle:
    • Aluminium, mono-bloc six-piston racing callipers with “Anti Knock Back” piston springs
    • Steel brake discs, multi-piece, ventilated and grooved, 380 mm diameter
    • Racing brake pads
    • Brake balance adjustment via a balance bar system (“Competition”)
    • Brake booster (“Trackday”)
    Rear axle:
    • Aluminium, mono-bloc four-piston racing callipers with “Anti Knock Back” piston springs
    • Racing brake pads
    Electrics
    • COSWORTH instrument cluster ICD with integrated data logger
    • Upgraded fault diagnosis with PIWIS motorsport tester
    • Porsche Track Precision Race App
    • Integrated lap trigger via GPS signal
    • Electronic throttle system
    • Lightweight lithium-ion (LiFePo) battery, 60 Ah, leak-proof, mounted in passenger footwell (“Competition”)
    • Battery 12 V, 70 Ah (AGM), leak-proof, mounted in passenger footwell (“Trackday”)
    • Emergency cut-off switch in cockpit and outside left of the windscreen
    • Driving stability system PSM (Porsche Stability Management) with ABS, traction Control (TC) and Electronic Stability Control (ESC), able to be completely deactivated
    • Tyre pressure monitoring system (TPMS)
    • Central fire extinguishing system in accordance with FIA regulations (“Competition”)
    • Handheld fire extinguisher (“Trackday”)
    • Air conditioning
    • Electric wing mirror adjustment
    • Multifunctional CFRP motorsport steering wheel with pit speed limiter and quick release coupling (“Competition”)
    • Multifunctional motorsport steering wheel with pit speed limiter (“Trackday”)
    • Centre console with map switch to adjust the ABS, ESC, TC and switch between preset tyre circumferences
    Weight/dimensions
    • Total weight: 1,320 kg
    • Total length: 4,456 mm
    • Total width: 1,778 mm
    • Total height: 1,238 mm
    • Wheelbase: 2,456 mm
    Rims/Tyres
    Front axle:
    • One-piece light-alloy forged wheels in new weight-optimised rim design, 9J x 18 offset 28 with 5-bolt mounting
    • Delivered with Michelin transportation tyres, dimension: 25/64-18
    • Michelin slick/wet tyres, dimension: 25/64-18
    Rear axle:
    • One-piece light-alloy forged wheel in new weight-optimised rim design, 10.5J x 18.5 offset 53 with 5-bolt mounting
    • Delivered with Michelin transportation tyres, dimension: 27/68-18
    • Michelin slick/wet tyres, dimension: 27/68-18
    Colours
    • Water-based paint
    • Exterior: white C9A
    • Interior: white filler-coat, without lacquer
    Delivery
    Starting in February 2019
    MiniFER, escopeta, romeodj y 4 otros les gusta esto.
  2. Guancho
    Michigan
    6 cilindros. Nos entendemos. El único Porsche no 911 que me gusta.
    A chamadyco le gusta esto.
  3. inthenight
    inthenight Clan Leader
    19 Feb 2005
    425 cv y con esa preparación... bufff...
  4. inthenight
    19 Feb 2005
    Supongo que te referirás a los que están a la venta ¿o le harías ascos a un 981 GTS?
    A M-Power le gusta esto.
  5. Guancho
    Michigan
    Claro que no.
    A inthenight le gusta esto.
  6. Guancho
    Michigan
    Ahora me contáis el peliculón d´Antena 3 del 4 cilindros turbo. No Dani, tú no te metas, que ya me conozco la matraca.
    A dani2 le gusta esto.
  7. romeodj
    romeodj Forista Senior
    18 May 2006
    La Coruña
    Impresionante! Estoy deseando que presenten el modelo de calle que lo más probable es que sea en el salón de Ginebra.
  8. hector8
    hector8 Forista Senior
    25 Nov 2009
    gijon
    335d E91
    buff que pepino...cuanto costará...
  9. cybermad
    H6 3.8 425 cv 1.320 kg, hay 2 versiones y ninguna homologada para calle: trackday 134.000 € + impuestos y competition 157.000 € + impuestos, lo curioso es que lleva puertas y alerón hechos de un composite de fibras naturales, lino y cáñamo, muy ligeras y tan resistente como la fibra de carbono :)
    Última edición: 5 Ene 2019
    A inthenight y romeodj les gusta esto.
  10. *NANO*
    *NANO* Clan Leader
    Parece que la versión de calle mantendrá el H6 atmosférico. Qué ganas de verlo.
  11. romeodj
    18 May 2006
    La Coruña
    Efectivamente, además tengo curiosidad en si el filtro de partículas le permitirá sonar de forma similar al anterior.
    A *NANO* le gusta esto.
  12. Nacho_C
    Nacho_C Forista
    6 May 2010
    Santander
    Uffff,.. que juguete más guapo!!!
  13. Guancho
    Michigan
    Nohpérate, le van a poner 4...ja!!!
  14. *NANO*
    *NANO* Clan Leader
    No lo creo. Sería una muy mala noticia.
  15. Guancho
    Michigan
    Por eso te digo!!!
  16. dani2
    dani2 Clan Leader
    30 May 2002
    San Juan City(Zarago
    Juasss!! En un coche como el Boxter(y los de su calaña) que son pasionales 100% y encima descapotables es en los únicos que no me cuadra un 4 cilindros.....vamos que no me lo compraría. Y mantengo el discurso desde el 2002 que llevo por aquí.....
    Otra cosa es en un compacto, o una berlina como las que gastamos los pobres....
  17. Guancho
    Michigan
    Eeeessoè
  18. cybermad
    A luxo46 le gusta esto.
  19. cybermad
  20. Guancho
    Michigan
    Bonito GT4 amarillo esta mañana en el Jarama. Sería un coche perfecto para mí.
  21. Carlos
    Carlos Clan Leader
    20 Jul 2005
    Por los Mares
    6 cilindros 425 cv 100 y muchos mil euros , se nota q ninguno os planteáis comprarlo y aunque un 10 pct tuviera ese dinero para comprarlo , no con el dinero del Monopoly, no se lo compraría.
    Dicho esto ,me recuerda hace años antes del primer RS me decía Gus a mi consulta si en lugar de ese coche V8 elegiríais un Panamera V6 una edición especial muy equipado , me decía 100 y pico mil por 300 y poco cv .... no .
    Pues a eso lo mismo , no , ni con el dinero del monopoly .
  22. romeodj
    18 May 2006
    La Coruña
    Este coche está orientado para lo que es. En principio en el salón de Ginebra veremos la versión de calle y su homologo en boxster.
    Yo actualmente tengo el último Boxster Spyder y valoro cambiarlo si merece la pena.
    A GOLDAR le gusta esto.
  23. Pabloo86
    Pabloo86 Forista Senior
    10 Ene 2016
    Serie 1 y 987
    Es verdad que la capota es manual? Y super ruidoso debido a menos capas de revestimiento de capota? Yo tengo un 981 normal y nunca he visto un spyder en vivo, me gustaria, si es como te digo, preferiria algo mas de comodidad y confortabilidad, imagino que esta destinado para circuito, es ese el uso que le das?
  24. *NANO*
    *NANO* Clan Leader
    El que mejor sonaba de todos los que estaban en pista.
    A Guancho le gusta esto.
  25. romeodj
    18 May 2006
    La Coruña
    Si, la capota es manual salvo el enclaje final que es eléctrico.
    Efectivamente, está menos insonorizada la capota debido a que tiene menos capas aislantes, incluso tiene parte de los mecanismos visibles en el interior.
    Pues si vienes por Galicia lo ves cuando quieras.
    Para mi todas las incomodidades son parte de su atractivo, el sonido que hemite es increible al igual que su comportamiento, yo estoy encantadisimo con el mío, anteriormente tuve un 981 GTS y para mi no hay color.
    No, nunca ha piso circuito y dudo que lo haga, pero cada vez que lo saco me saca una sonrisa y eso no tiene precio.
    A GOLDAR y Pabloo86 les gusta esto.
  26. cybermad
    Tu Spyder es mi sueño más húmedo de los roadster, enhorabuena por disfrutarlo y tener la opción de cambiarlo por este nuevo :guiño:
    A romeodj y escopeta les gusta esto.
  27. cybermad
    No suena mal...
    A escopeta le gusta esto.
  28. cybermad
    A chamadyco, MiniFER y inthenight les gusta esto.
  29. chamadyco
    chamadyco "Volantista pofesioná!" Miembro del Club
    4 Feb 2008
    Bizkaino exiliado en territorio enemigo XD
    328i E36,ZXR750
    No había visto esto. Me alegro de que lo sigan sacando H6 y atmosférico. Entiebdo que la versión de calle seguirá saliendo con cambio manual opcionalmente al menos no? Por si me toca el euromillón digo más que nada :floor:
  30. Guancho
    Michigan
    Amarillo, pinza verde, llanta titanio para mí. Soy así yhtoymuloco!!
