Preparación de Z4.... de carbono!!!!
Tema en 'BMW Serie Z (1987 - Presente)' iniciado por pacix, 17 Nov 2005.
  1. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    BMW Tuner and Sport Car Racing Team, TC Kline Racing Inc. is proud to introduce the Carbon Roadster, the first complete car offered by the company. The Carbon Roadster is a focused ultra high performance sports car based on the already excellent dynamics of the BMW Z4. TC Kline’s passionate adherence to the fundamental principals of light weight and dynamic performance has resulted is a true sports car.
    The Carbon Roadster weights 2,680 lbs., has 346 hp and corners with 1.06G grip. Take a minute to soak that in. The CR weighs 150 lbs. less than a Honda S2000, has the HP of a Porsche 911, and has wider wheels and tires than a Ferrari F430. Incredibly, the CR weighs 700 lbs. less than a BMW M3 while maintaining the same power.
    The Body; The entire skin of the CR is manufactured from Carbon Fiber Composites. The changes to the Z4 bodywork are a direct result of the application of the principals of "form follows function". Walk around the CR and you will not find any body lines which do not serve as an extension of function. The Carbon Roadster body work incorporates aerodynamic performance enhancements with a front air dam, front wheel house vents, side skirts, and rear diffusers. The body also has all four fenders flared I" to accommodate wider wheels and tires. The use of carbon composites to make the body reduces the weight of the CR tremendously while maintaining a strong durable skin.
    Interior: TC Kline has contracted with Recaro to produce a one piece shell performance seat specifically for the CR upholstered in Alcantera and Leather. These light weight performance seats feature cutouts for a driver harness and will have exceptional support while maintaining excellent driver comfort. These Recaro/TC Kline seats are similar to those found in the E46 BMW M3 CSL or the Porsche Carrera GT.
    The Drive Train: On the 25th of October, 2005, BMW AG introduced the Z4 M Roadster. The Z4 M Roadster incorporates the E46 M3 Drive train. The TC Kline CR is based on that car and shares its 3.2 liter motor, 6 Speed Transmission and M Lock Differential. TC Kline upgrades the drive train with an Aluminum flywheel for quicker throttle response, improved acceleration and lighter weight. TC Kline has also developed a thin wall stainless steel exhaust system for the CR. This exhaust system is significantly lighter than the stock system, improves horse power by 13 and has the outlet in the center of the rear bumper between the two Carbon Fiber Diffusers.
    The Suspension: KONI Double Adjustable Coil-Over struts and rear shocks valved to TC Kline Specifications are already accepted by the BMW enthusiast as the standard for street and track performance and directly contribute to the 1.06G cornering grip the CR develops. The suspension springs for the CR are made in Germany from a light weight alloy steel and TC Kline has a variety of spring rates available which allow the owner to tune the CR to their personal taste. The CR front struts are topped off with TC Kline designed front Camber Plates for quicker turn-in and steering feel and Delrin bushings replace the standard rubber bushings in the front lower arms and rear trailing arms for quicker response and markedly improved feel. These TC Kline components significantly reduce the unsprung weight resulting in a more responsive suspension.
    Brakes: Performance Friction Corp. has created extremely rigid and light weight aluminum MonoBloc calipers for use on the CR. The front caliper is a four piston design with four brake pads for superior modulation and high brake torque and the rear caliper is a two piston design sharing the same pads. The large floating rotors have aluminum hats for light weight. The front rotor diameter in 345 mm, and 328mm rotors are on the rear. The PFC Carbon Metallic Brake Pads offer exceptional brake loads for extremely short stopping distances. These ultra performance brakes also contribute significantly to reducing the unsprung weight of the Carbon Roadster.
    Wheels and Tires: The final design for the wheels has not been determined, however, the specifications have. As on this prototype, all four wheels will be a one piece forged aluminum design for the lightest weight and strength. The CR standard front wheels are 19x9.5" and the rears are 19x10.5". Optional wheels in 18x9.5" and 18x10.5" will be available in forged aluminum as well for those drivers who want to take advantage of a larger selection of ‘R’ Compound tires and/or are interested in a more comfortable street ride. Magnesium forged wheels will be offered in 18x10" front, 18x11" rear for optimum track performance. The Michelin Pilot Sport Cup is currently the highest performance tire available for the street. The standard sizes for the CR are 265/30x19 front and 295/25x19 rear, (Not yet available). These Sport Cup tires produced 1.06 G cornering in a Car and Driver test driving a TC Kline Z4 using the same suspension as supplied on the CR. The Michelin PS2 Ultra high performance tire will be available in both 18 and 19" as a no charge option. The PS2 tires offer extended wear with less grip than the Sport Cup tires.
    With some detail changes, the CR prototype you see here will be offered for sale in the late spring or early summer of 2006. The TC Kline Carbon Roadster will be assembled in the TC Kline Racing Shop in Columbus, Ohio. The CR will be available in all of the BMW Z4 M Roadster colors, and any special color can be accommodated for a small extra charge. The CR will be limited by production capability to 100 cars. The final price of the Carbon Roadster is not set. However, expect the price to be in the mid $90,000. range.
    There will be two option packages for the CR.
    Soft ride package. This package will use the new self adjusting KONI FSD (frequency sensitive damping), technology dampers for a softer ride with minimal sacrifice in grip, softer spring rates, 18" wheels, Recaro Sport Seats and Michelin PS2 tires. This suspension will maintain the factory rubber bushings in the suspension. This is a no cost option.
    Track Attack Package: This package offers 18x10" front, 18X11" rear forged Magnesium Wheels shod with 265/35x18 front and 295/30x18 rear Michelin Pilot Sport Cup Tires, Competition rate springs, PFC Slotted Rotors, High Temp. SRF Brake fluid, Recaro Racer SPG Driver Seat, Driver and passenger racing harnesses, and TC Kline Spherical Ball Joint Suspension. The cost for this option package has not been set at this date.
    For further information you can go tcklineracing.com, or call TC Kline Racing at 614-771-7744.
    TC Kline Racing
    "Uncompromising BMW Performance"
    Specifications
    Body: TC Kline Carbon Fiber Composite skin over steel unibody
    Dimensions Length 161.5"
    Width 70.1"
    Height 50.2"
    Wheel Base 98.3"
    Track Front 60.2"
    Rear 61.4"
    Weight 2,680 lbs (unladen)
    Interior: Recaro/TC Kline Custom light weight one piece shell seat w/ Alcantera and Leather upholstery
    Optional – Recaro Sport Seats of Recaro Racer SPG Racing Seats
    Engine
    BMW 3.2 L inline Double overhead cam 6 Cylinder w/Iron Block and Aluminum Head - 346 hp @ 7900 rpm - 232 lb/ft torque at @4900 rpm
    Exhaust: TC Kline Thin Wall Stainless w/center outlet
    Flywheel : TC Kline 11.2 lbs Aluminum
    Transmission: BMW 6 Speed Manual
    Gear Ratios 1)4.35 2)2.496 3)1.665 4)1.23 5)1.00 6)0.851
    Differential: BMW M Lock Limited Slip
    Final Drive Ratio 3.62
    Suspension: Front TC Kline/KONI Dbl Adj Struts
    TC Kline light weight 60mm ID Coil Over Springs
    TC Kline Adjustable Camber Plates
    TC Kline Delrin Lower arm Bushings
    Rear: Multi-Link Trailing Arm
    TC Kline Dbl Adj Shocks
    TC Kline Light Weight Coil Springs w/Adjustable Spring Lands
    TC Kline Delrin Trailing Arm Bushings (Spherical Ball Joint or BMW Rubber Optional)
    Brakes: Front
    Performance Friction 4 piston MonoBloc Aluminum Calipers
    345mm Floating rotor w/aluminum hats
    Rear
    Performance Friction 2 Piston Aluminum Calipers
    328mm Floating rotor w/aluminum hats
    PFC Carbon Metallic brake pads
    Wheels and Tires
    Light Weight One Piece Forged Aluminum w/Michelin Pilot Sport Cup Tires
    Front – 19x9.5" wheel with 265/30x19" tire
    Rear - 19x10.5 wheel with 295/25x19" tire (not yet available)
    Optional
    18x9.5 front and 18x10.5 rear Forged Aluminum
    18x10 front and 18x11 rear Forged Magnesium
  2. jrubio
    jrubio Forista Legendario
    30 May 2005
    este coche es nuevo??????
    que modelo es ?
    se ve muy moderno no?:descojon: :descojon: :descojon:
  3. Factoni
    Factoni Clan Leader
    9 Oct 2005
    Esta chulo el taxi este. Ya lo podrian haber pintado de otro color o mejor aun, dejarlo con el carbono a la vista. Muy bonito con buen peso (1215 kgs segun el conversor nokia:) ) para semejante motor.
  4. govillard
    govillard Forista Legendario
    3 Dic 2003
    SS.
    Z3 coupé
    SI no saben que inventar para que el Z4 llame la atención.
    Mirad, cogemos un Z3 Coupé M, lo dejamos en chirlas, fabricamos puertas, capó y maletero en carbono, lo alijeramos hasta el esfinter de todo lo no necesario,Elevalunas, cristales fijos, radio y pijadas de todo tipo. Unos frenos del desfase,, lo potenciamos a 400 cv, lo bajamos 10 cm, lo anchamos 6 u 8cm, Suspensiones, brazos, barras, triangulos en titanio, aligerar motor, poleas, volantes, fuera el AC, Fuera ventiladores y todo lo que se nos ocurra.
    Y temos una Z-barqueta que te cagas. Habia pensado en ruedas de clavos, por aquello de que agarre algo.
    Porqué nadie hace un tuning de esos radicales en este aspecto?
    Limando y gastando muchos euros, igual lo dejamos en 1000 kgs?
  5. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    Imagino que porque para hacerlo tienes que estar forrao, ser un poco tontín (porque por lo que gastas compras un coche que ande y tenga un chasis en condiciones) y porque no habrá ya componentes. así a bote pronto.
  6. Sunner
    Sunner Forista Senior
    7 Abr 2003
    Burgos - Madrid
    Paciz, que hablamos del Coupe, es un buen chasis, por eso hay muchas preparaciones de alta gama para competicion en USA. Yo no lo veo totalmente descabellado, aunque efectivamente si tuviese los cuartos seguramente los invertiria en otra cosa.
  7. jrubio
    30 May 2005
    en un z4?????
  8. Sunner
    7 Abr 2003
    Burgos - Madrid
    Una imagen vale mas que mil palabras:
  9. twenty
    twenty Guest
    A mi me parecer una de las creaciones automovilisticas mas bellas que se han fabricado.....pero para circuito, no.
    A por cierto venden el 996 que ha ganado este año el campeonato español de GT por 90.000 Euros.
  10. Sunner
    7 Abr 2003
    Burgos - Madrid
    No, si yo no lo quiero para circuito, lo quiero para ver si ligo algo de una vez.
  11. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    Por mucho coupe que sea, es un diseño de hace 15 años.
    Pásate por el general, que tenemos un post muy interesante de una comparativa en Autopista (creo??) entre un alfa 159 moderno y el Mercedes Sl35 24v (todo una maquinón de 11 millones del 97)... el 159 (y el 320d y tal) se lo pulen..
    Jijijiiji, aquí escribe uno que el otro día probó un 997...... y lastima de que estuviese húmedo que sino hubiera sacado más el cuchillo.....
  12. CARLOSZ3
    CARLOSZ3 Clan Leader
    15 Abr 2004
    León
    Pero de que alijeramiento en peso estamos hablando con el carbono? que es lo interesante.
  13. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    pues lo deja en 1200 y pico con el motor del m3 e46
  14. Sunner
    7 Abr 2003
    Burgos - Madrid
    Cierto pero si miras los tiempos en el ring....
    //M Coupe: 8.22 min
    //M roadster: 8.32 min
    Z3 Coupe 3.0: 8.34 min
    Z4 3.0: 8.32 min
    Asi que el Z4, 15 años mas moderno apenas le saca 2s (y eso que es uno de los mejores chasis de roadster fabricados). El chasis de Z3Coupe es muy buen chasis, y el del M no digamos (ya veremos los tiempos del Z4M y estoy deseando ver el Z4MC). A mi me parece el //MCoupe un claro candidato para hacer una preparacion racing.
    Si miras un poco aun se hacen muchisimas preparaciones sobre los E30, es una base excelente.
  15. CARLOSZ3
    15 Abr 2004
    León
    Pues no esta mal, claro que la compensacion en pasta igual no esta tan justificada......8-[
  16. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    Pero es no puedes comparar el tiempo de un roadster con el de un coupe tio... hay el chasis ya ha dejado de ser "LA" diferencia... c**o, uno tiene pilares y techo y el otro no.
    Mira como el z4 y Z3M roadsteras ambos, andan a la par, claro que con 231 cvs el primero y 312 el segundo (90 de diferencia). Así si se pueden comparar cosas.
  17. govillard
    3 Dic 2003
    SS.
    Z3 coupé
    A ver.... yo con lo que costaria esa bestialidad que he comentado antes, seguramente compraria otra cosa.
    A lo que voy, es que andan por ahí metiendo 5, 6 7 y más millones, en tunings para un put*** tdi. Y porqué? Pues porque cada uno, hace con su pasta lo que quiera.
    Y el Z3Coupé me parece algo precioso, para gastar dinero y tener algo exclusivo de verdad. Yo no lo haria, repito, pero dejaba volar mi imaginación...,. mucha pasta, artesania y quitarle 400-500 kg a un Z3M.
    Quizás no sea posible, pero con dinero....
    Y tendrías la piedra más gorda que te puedes echar a la cara...:drivingsk
    AH, se me ha olvidado decir que me gusta ese taxi Z4 blanco. Ha mejorado las lineas en general... pero esa trasera, esque no llegarça a convencerme.
  18. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    Pues en un foro porsche hay uno que ha hecho lo contrario. se ha comprado un 996 turbo y ahora le va a meter una plancha de 50kg de plomo en el morro. ¿ein?
  19. govillard
    3 Dic 2003
    SS.
    Z3 coupé
    Y el weissman, increible. Pero la trasera del Z3 coupe, salvando las distancias, es mas armoniosa, redondita y gooorda.
    El Weiss parece un poco, una traqueotomia, o el tubo de un aspirador de campos de futbol...
  20. govillard
    3 Dic 2003
    SS.
    Z3 coupé
    Fçijate que calceta.., tener que meter 50 kgs de plomete...[-X
    No se lo puede currar para quitar 50 de atras?:)
  21. govillard
    3 Dic 2003
    SS.
    Z3 coupé
    Oye PAcix, como te enteras tan rápido de que hay un nuevo respuesta en el post? A mi ya no me llegan los avisos de "han respondido al post....."
  22. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    A mi tampoco me llega ningún aviso.
  23. jrubio
    30 May 2005
    una traqueotomia???????????
    j*der menuda imaginacion!!!
  24. m a p
    m a p Guest
    Ejque estás a la que salta, eso es la eficiencia de un profesional forero!
  25. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    Hombre, a ver si te crees que llevo los post que llevo por nada ;-):):):)
    Govi, f5 tio, f5.
  26. CARLOSZ3
    15 Abr 2004
    León
    Yo crei que el f5 valia para otra cosa que rima...... :ANAL: :descojon:
  27. pacix
    pacix Clan Leader
    9 May 2004
    Koblenz, Alemania
    981GTS/1200RT
    Conoces esta web? http://www.orangizer.com/
  28. CARLOSZ3
    15 Abr 2004
    León
  29. govillard
    3 Dic 2003
    SS.
    Z3 coupé
    Pues yo le doy a F5 y no pasa nada
  30. CARLOSZ3
    15 Abr 2004
    León
    Pues te deberia actualizar la peich al instante. :razz:
