Video Record Nurburgring FWD: 7:44" en Mini JCW 290cv 1.005kg de Schirra
Tema en 'Foro General BMW' iniciado por cybermad, 19 Oct 2014.
  1. cybermad
    10 segundos menos que el Renolo, pero al ser un coche modificado el record no es oficial, aunque es un coche homologado para la calle.
    Lo conduce Christian Gebhardt de Sport Auto :)
    Modified MINI JCW sets unofficial front-wheel drive record on Nurburgring
    7:44 lap time
    A modified MINI JCW has set a new record for a front-wheel drive car around the Nürburgring.
    Our friend Christian Gebhardt from Sport Auto took a MINI John Cooper Works tuned by Schirra Motoring and lapped the Nordschleife in 7 minutes and 44 seconds which makes it 10s quicker than the Renault Megane RS 275 Trophy-R. While this new record can't be considered official since it's done with a tuned car, it is worth mentioning the modified MINI here is fully street legal even though it went through a series of changes.
    The German tuners bumped output of the four-cylinder 1.6-liter turbocharged engine from 211 HP (155 kW) to an impressive 290 HP (213 kW) and also installed a Drexler limited slip differential, KW coilover suspension while the stock tires were replaced with a new set of Dunlop Direzza 03G. Recaro Pole Position seats were also installed and combined with several other lightweight components have reduced the weight of the MINI JCW GTS by Schirra Motoring by 175 kg (385 lbs) which means the vehicle now weighs only 1,005 kg (2,215 lbs).
    davidW, Gus, Nacho Martinez y 3 otros les gusta esto.
  2. Gulf627
    Gulf627 Clan Leader
    14 May 2005
    Europa
    E86/S54-G80/S58
    Hace tiempo puse un post sobre una prueba de sportauto donde comparaban justamente el mini jcw normal, el schirra "de calle" y el de vln (carreras de resistencia) y los tiempazos en Hockenheimring eran tremendos. El mini de vln era más rápido que cualquier superdeportivo (gracias en gran medida a los slicks)
    A Gus y ingouriarba13 les gusta esto.
  3. Panda
    Panda Forista Legendario
    23 Dic 2010
    Jaén
    E82 120d
    Menudo cohete... increible lo bien que va ese cambio manual
  4. Gabri_faq
    Gabri_faq Forista Senior
    13 Jun 2009
    Robleda/salamanca
    330ci 04'
    que estrés , en todo momento tiene que ir corrigiendo con el volante, parece que es un coche que no puede ir recto
  5. Cris
    Cris Clan Leader
    22 Jul 2005
    cerca muy cerca...
    ///M3 ///M330 ci
    es rapidisimo!
  6. Ibi-TDI
    Ibi-TDI Clan Leader
    2 Feb 2004
    Buen pepino, pero parece dicifil de manejar.
    Sobre los tiempos, al no ser de calle no me dicen nada. Pero tener un trasto asi para entrar en circuitos tiene que ser una pasada.
    A X-11 le gusta esto.
  7. paramo M power
    paramo M power Forista Legendario
    2 Ene 2008
    en cazurrolandia
    rural
    Como anda el bicho
  8. restrallas
    restrallas Forista
    16 Feb 2014
    bmw 530d e60
    menuda bomba
  9. X-11
    X-11 Forista
    28 May 2009
    Tenerife
    Ex-520i E34
    La preparacion le quita todo el merito, es como si yo pillara un RS, lo preparara a tope y se lo diera a algun piloto.
    No es de serie y quien mas pasta meta sera el primero
  10. Gus
    A 1800 kms del Ring
    Tremendo! :goodpost:
  11. davidW
    15 Oct 2002
    Hell´s kitchen
    Estocástico
    Rapidísimo y parece hasta fácil de conducir una vez en curva :sneaky:
  12. Gus
    A 1800 kms del Ring
    Solo con el cambio de retrovisores exteriores habrán ahorrado 20 kilitos :LOL:
    A Csar le gusta esto.
  13. Barbinski
    18 Mar 2004
    St Qgat de Entrerradares.
    Q5-Q3sb-S2R1000
    Patrocinado por:
    Para aligerar peso y más barato que el carbono....
  14. JAVMAD
    JAVMAD Repartidor... Moderador Miembro del Club
    3 Oct 2005
    F60&T8-Plug&RS
    Un Mini John Cooper Works, modificado por Schirra Motor, ha establecido un nuevo récord para un coche de tracción delantera en Nürburgring. Con un tiempo de 7 minutos y 44 segundos, esta cifra es 10 segundos inferior al récord oficial conseguido por el Renault Mégane R.S. 275 Trophy-R.
    Un Mini John Cooper Works, modificado por Schirra Motor, bate el récord para un coche de tracción delantera en Nürburgring. Con un tiempo de 7 minutos y 44 segundos, esta cifra es 10 segundos inferior al récord oficial conseguido por el Renault Mégane R.S. 275 Trophy-R. El preparador alemán tomó el motor 1.6 turbo de cuatro cilindros y 211 CV (155 kW), y ha apretado hasta conseguir unos impresionantes 290 CV (213 kW). Para sacar el máximo rendimiento también se instaló un diferencial de desplazamiento limitado Drexler, suspensión regulable KW y unos neumáticos Dunlop Direzza 03G. Igualmente se realizó una dieta de adelgazamiento quitando piezas innecesarias e instalando otras más ligeras, como los asientos Recaro Pole Position. El peso en vacío del Mini JCW GTS, que así lo denomina Schirra Motor, queda en 1.005 kilogramos, 175 menos que la versión de serie.
    Link a la noticia: http://www.autobild.es/noticias/mini-preparado-bate-record-nuerburgring-236263
    A Poti T y Choche5 les gusta esto.
  15. Poti T
    Poti T Forista Legendario
    16 Nov 2004
    Parque Nacional
    Elle McPherson
    Lo ví ayer....que sobrada como vá el molinillo!!
  16. kilimanjarto1
    kilimanjarto1 Forista
    18 Ene 2013
    j*der el mini, parece que intenta matarte todo el rato.
