just in the process of doing some interior elements, i know my car is a bit different i have to renew the lateral panels of the central console it is essentially a non-AC car but with and odd aftermarket AC that was probably installed in 1974, lateral cuts are not very nice, but it has the advantage of the more beautiful central console área of the non-AC version this is it: wanted to renew them in nice new vinyl the main issue is that the lateral panels are not flat, they have a slight bent in top área, that is the key business of this job. draw the contours. so cut the panels: in order to bend the panel use a file and make a channel and use a bit of wood forcé it into the cannel glue it together for super strong finish see the angle that you have to achieve done,a nice solution from the 70-ties
on another step to finish the Wood pieces: clering some of the thickness, and building some space for the shifter console
adapted shape to AC evaporator place the front rubber profile i have found two different ways of producing this shape place the foam polish the trim alu profile as mentioned the right specimen was made in a different way so i have to reproduce the LH idea, using this special adhesive that really glues rubber strongly i prepared the top corner
Más los celebramos los "visuarios" eres mí ídolo "bricoladeador, ...colajeador..." como fuere deba decirse...
Te ha quedado "nikelao". Como siempre, gracias por compartir. Aunque no tengamos E9, los truquis de restauración pueden venir bien para otros aparatos
La oxtia. Tu en el cole en manualidades y con la txapa kume debías de ser un maquina de cuidado. Increíble lo que te has montado. Programa en la tele pero ya. "Restaurando clásicos paso a paso" por dequincey. No me iba a perder ni un capitulo. Me quito el sombrero, no, me despeloto directamente.
Que bien después del laborioso trabajo de restauración y mejora, nos podemos seguir deleitando y aprendiendo
