Duda Significado de código de errores bmw (menú oculto)
Tema en 'Serie 5 (E39) (1995-2004)' iniciado por robertoesdecarrizo, 26 Ene 2014.
  1. robertoesdecarrizo
    robertoesdecarrizo En Practicas
    31 Ago 2011
    leon
    Hola creo que he encontrado la traducción a ingles de los código de error del menú oculto, haber si alguien sabe algo más del tema:
    DDE 5, DDE 6, DDE 6.2 and DDE 6.3
    3E90 Crankshaft RPM - No Signal
    3E91 Crankshaft RPM - Wrong Signal
    3E95 Intake air Temperature Sensor
    3EA0 Crankshaft Position Sensor
    3EA1 Crankshaft Position Sensor
    3EA5 Intake air Temperature Sensor
    3EA6 Intake air Temperature Sensor
    3EB0 RPM Calculation
    3EB5 Air flow Sensor 2
    3EB6 Air flow Sensor 2
    3EC0 Camshaft Sensor - No Signal
    3EC1 Camshaft Sensor - Wrong Signal
    3EC7 Camshaft Sensor
    3ED0 Camshaft Sensor - No Signal
    3ED1 Camshaft Sensor - Wrong Signal
    3ED5 Air Flow Sensor 2
    3ED6 Air Flow Sensor 2
    3EDC Variant Coding
    3EDD Variant Coding
    3EE0 Coolant Temperature Sensor -Short Circuit to B+ or Open
    3EE1 Coolant Temperature Sensor -Short Circuit to B-
    3EE2 Coolant Temperature Sensor
    3EE3 Coolant Temperature Sensor
    3EE5 Air Mass Flow Sensor 2
    3EE6 Air Mass Flow Sensor 2
    3EE7 Air Mass Flow Sensor 2
    3EED Power Management Closed Circuit Current
    3EF3 Coolant Temperature Sensor not Plausible
    3EF5 Intake Air Temperature Sensor 2 (HFM Reference Signal)
    3EF6 Intake Air Temperature Sensor 2 (HFM Reference Signal)
    3EF7 Intake Air Temperature Sensor 2 (HFM Reference Signal)
    3EFB Thermal Oil Level Sensor
    3EFC Thermal Oil Level Sensor
    3EFD Thermal Oil Level Sensor
    3F00 Boost Pressure Sensor -Short circuit to B+
    3F01 Boost Pressure Sensor -Short circuit to B- or Open
    3F02 Boost Pressure Sensor
    3F03 Boost Pressure Sensor -Plausibility
    3F05 MIL OFF
    3F10 Pedal Position Sensor 1
    3F11 Pedal Position Sensor 1 - Short circuit to B-
    3F13 Pedal Position Sensor 1 - Potentiometer Plausibility
    3F15 MIL ON
    3F20 Pedal Position Sensor 2
    3F21 Pedal Position Sensor 2 - Short Circuit to B-
    3F23 Pedal Position Sensor 2 - Potentiometer Plausibility
    3F25 Input Air Flow Control
    3F30 Rail Pressure Sensor - Short Circuit to B+
    3F31 Rail Pressure Sensor - Short Circuit to B-
    3F35 Input Air Flow Control at Idle Speed
    3F40 Rail Pressure Sensor - Max for Compensation
    3F41 Rail Pressure Sensor - Min for Compensation
    3F47 Brake Light or Brake Light Test Switch
    3F48 Brake Light or Brake Light Test Switch
    3F50 Vehicle Speed Signal - Too High
    3F51 Vehicle Speed Signal
    3F52 Vehicle Speed Signal
    3F53 Vehicle Speed Signal
    3F60 Pedal Position Sensor Ref. VSS
    3F62 Vehicle Speed Signal from CAN
    3F67 Filling Pressure Modulator 2
    3F70 Intake Air Temperature Sensor
    3F71 Intake Air Temperature Sensor
    3F72 Intake Air Temperature Sensor
    3F77 Boost Pressure Modulator 1
    3F82 Ambient Temp Sensor
    3F87 Boost Pressure Modulator 2
    3F97 Boost Pressure Modulator 1
    3FB0 Air Flow Meter - Signal too High or Short circuit to B+
    3FB1 Air Flow Meter - Signal too Low or Short circuit to B-
    3FB5 Control Master/Slave
    3FB6 Control Master/Slave
    3FB7 Control Unit - Internal Master
    3FC0 Air Flow Meter - Deviation too High at Idle Speed
    3FD0 Air Flow Meter - Deviation too High
    3FE0 Air Flow Meter
    3FE1 Air Flow Meter
    3FF0 Air Flow Meter
    3FF1 Air Flow Meter
    4000 Fuel Temperature Sensor
    4001 Fuel Temperature Sensor
    4010 Exhaust Gas Pressure Sensor -Short Circuit to B+
    4011 Exhaust Gas Pressure Sensor -Short Circuit to B-
    4020 EGT -Short Circuit to B+
    4021 EGT -Short Circuit to B-
    4030 EGT Before Cat -Short Circuit to B+
    4031 EGT Before Cat -Short Circuit to B-
    4032 Exhaust Gas Pressure Sensor
    4060 Atmospheric Pressure Sensor DDE-Short Circuit to B+
    4061 Atmospheric Pressure Sensor DDE-Short Circuit to B-
    4062 Atmospheric Pressure Sensor DDE
    4063 Atmospheric Pressure Sensor DDE-Plausibility Ref. Boost
    4072 Automatic Gearbox Switch Signal
    4080 Brake Light or Brake Light Test Switch
    4082 Brake Light or Brake Light Test Switch
    4083 Brake Light or Brake Light Test Switch
    40A1 Alternator Signal
    40E0 Alternator
    4100 AirCon Power Output
    4101 AirCon Power Output
    4102 AirCon Power Output
    4103 AirCon Power Output
    4108 Control Master/Slave
    410C Swirl Flap Actuactor
    4117 Control Master/Slave
    4118 Control Master/Slave
    4120 DDE Main Relay is Switching too Late or too Early
    4121 DDE Main Relay is Switching too Late or too Early
    4125 Power Supply
    4126 Power Supply
    4130 Swirlflaps - Short Circuit to B+
    4135 Power Supply
    4136 Power Supply
    4140 Swirlflap
    4141 Swirlflaps - Short Circuit to B-
    4145 Power Supply
    4146 Power Supply
    4152 Swirlflaps - Open Circuit
    4153 Swirlflaps - Plausibility, Overtemp of Output Stage
    4155 Exhaust Flap Actuator
    4156 Exhaust Flap Actuator
    4157 Exhaust Flap Actuator
    4158 Exhaust Flap Actuator
    4160 Raise Pressure Pump - Short Circuit to B+
    4161 Raise Pressure Pump - Short Circuit to B-
    4162 Raise Pressure Pump - Activation Interrupted
    4163 Raise Pressure Pump - Plausibility, Overtemp of Output Stage
    4165 DPF -Flow Resistance too High
    4166 DPF -Flow Resistance too Low
    4175 Exhaust Gas Temp Sensor before DPF
    4180 Boost Pressure Actuator - Short Circuit to B+
    4185 Exhaust Gas Temp Sensor before Cat
    4186 Exhaust Gas Temp Sensor before Cat
    4188 Exhaust Gas Temp Sensor before Cat
    4190 Boost Pressure Actuator
    4191 Boost Pressure Actuator - Short Circuit to B-
    419A Atmospheric Pressure Sensor DDE
    419B Atmospheric Pressure Sensor DDE
    41A0 Boost Pressure Actuator
    41A1 Boost Pressure Actuator - Adjustment
    41A2 Boost Pressure Actuator - Open Circuit
    41A3 Boost Pressure Actuator - Plausibility, Overtemp of Output Stage
    41A6 Message CBS Reset
    41A7 Message CBS Reset
    41AA Boost Pressure Sensor
    41AB Boost Pressure Sensor
    41B0 Exhaust Gas Recirculation -Short Circuit to B+
    41B5 Transmission Fluid Temperature Sensor
    41BA Exhaust Backpressure Sensor
    41BB Exhaust Backpressure Sensor
    41C0 Activation -Fan
    41C1 Activation -Fan- Short Circuit to B-
    41C2 Activation -Fan- Activation Interrupted
    41C3 Activation -Fan- Plausibility, Overtemp of Output Stage
    41CD Exhaust Backpressure Sensor - Plausibility
    41D0 Exhaust Gas Recirculation Regulation
    41D1 Exhaust Gas Recirculation -Short Circuit to B-
    41D5 Lambda Sensor Bias -Short Circuit to B+
    41D6 Lambda Sensor Bias -Short Circuit to B-
    41D7 Lambda Sensor Bias -Open Circuit
    41E0 Exhaust Gas Recirculation Regulation
    41E2 Exhaust Gas Recirculation - Open Circuit
    41E3 Exhaust Gas Recirculation -Plausibility, Overtemp of Output Stage
    41E5 Lambda Sensor -Short Circuit to B+
    41E6 Lambda Sensor -Short Circuit to B-
    41E7 Lambda Sensor -Open Circuit
    41F0 Electric Ventilator - Short Circuit to B+
    41F1 Electric Ventilator - Short Circuit to B-
    41F2 Electric Ventilator - Activation Interrupted
    41F3 Electric Ventilator - Plausibility, Overtemp of Output Stage
    41F5 Lambda Sensor Virtual Earth -Short Circuit to B+
    41F6 Lambda Sensor Virtual Earth -Short Circuit to B-
    41F7 Lambda Sensor Virtual Earth -Open Circuit
    4203 Glow Module Communication
    4205 Lambda Sensor Heating -Short Circuit to B+
    4206 Lambda Sensor Heating -Short Circuit to B-
    4207 Lambda Sensor Heating
    420B EGR in Regen Mode
    4211 Glow Plug Cyl 1 - Short Circuit to B+
    4212 Glow Plug Cyl 1 - Activation Interrupted
    4213 Glow Plug Cyl 1 - Plausibility, Overtemp of Output Stage
    4217 Lambda Sensor
    4221 Glow Plug Cyl 2 - Short Circuit to B+
    4222 Glow Plug Cyl 2 - Activation Interrupted
    4223 Glow Plug Cyl 2 - Plausibility, Overtemp of Output Stage
    4225 Lambda Sensor -Signal
    4226 Lambda Sensor -Signal too Low
    422A EGR in Regen Mode
    4231 Glow Plug Cyl 3 - Short Circuit to B+
    4232 Glow Plug Cyl 3 - Activation Interrupted
    4233 Glow Plug Cyl 3 - Plausibility, Overtemp of Output Stage
    4235 Control Unit Internal 21
    4236 Control Unit Internal 21
    4241 Glow Plug Cyl 4 - Short Circuit to B+
    4242 Glow Plug Cyl 4 - Activation Interrupted
    4243 Glow Plug Cyl 4 - Plausibility, Overtemp of Output Stage
    4245 Control Unit Internal 22
    4246 Control Unit Internal 22
    4251 Glow Plug Cyl 5 - Short Circuit to B+
    4252 Glow Plug Cyl 5 - Activation Interrupted
    4253 Glow Plug Cyl 5 - Plausibility, Overtemp of Output Stage
    4258 Control Unit Internal 23
    425D Accelerator Pedal Potentiometer Plausibility
    4261 Glow Plug Cyl 6 - Short Circuit to B+
    4262 Glow Plug Cyl 6 - Activation Interrupted
    4263 Glow Plug Cyl 6 - Plausibility, Overtemp of Output Stage
    4267 Lambda Sensor Shunt Detection
    4271 Glow Plug Cyl 7 - Short Circuit to B+
    4272 Glow Plug Cyl 7 - Activation Interrupted
    4273 Glow Plug Cyl 7 - Plausibility, Overtemp of Output Stage
    4275 Lambda Sensor Heater
    4276 Lambda Sensor Heater
    4281 Glow Plug Cyl 8 - Short Circuit to B+
    4282 Glow Plug Cyl 8 - Activation Interrupted
    4283 Glow Plug Cyl 8 - Plausibility, Overtemp of Output Stage
    4288 Lambda Sensor Heater
    428B Boost Pressure Control of Large Turbo Control Deviation
    4293 Control Unit Internal Error 16
    4296 Lambda Sensor
    4298 Lambda Sensor
    429A Boost Pressure Control of Large Turbo Control Deviation
    42B5 RPM Control
    42C0 Oil Pressure Indicator Lamp - Short Circuit to B+
    42C1 Oil Pressure Indicator Lamp - Short Circuit to B-
    42C2 Oil Pressure Indicator Lamp - Activation interrupted
    42C3 Oil Pressure Indicator Lamp - Plausibility, Overtemp of Output Stage
    42D5 Injector Cylinder 7
    42D6 Injector Cylinder 7
    42D7 Injector Cylinder 7
    42D8 Injector Cylinder 7
    42E2 Changeover Rail Pressure Control
    42F2 Changeover Rail Pressure Control
    42F5 Injector Cylinder 8
    42F6 Injector Cylinder 8
    42F7 Injector Cylinder 8
    42F8 Injector Cylinder 8
    4302 Quantity Regulation Valve - Activation interrupted
    4303 Quantity Regulation Valve - Plausibility, Overtemp of Output Stage
    4310 Quantity Regulation Valve - Short Circuit to B+
    4321 Quantity Regulation Valve - Short Circuit to B-
    4332 Rail Pressure Regulation Valve - Activation Interrupted
    4333 Rail Pressure Regulation Valve - Plausibility, Overtemp of Output Stage
    4340 Rail Pressure Regulation Valve - Short Circuit to B+
    4351 Rail Pressure Regulation Valve - Short Circuit to B-
    4360 Rail Pressure Regulation Valve - Current Regulation
    4361 Rail Pressure Regulation Valve - Current Regulation
    4362 Rail Pressure Regulation Valve - Current Regulation
    4373 Air Flow Mass not Plausible
    4378 Rail Pressure Regulation Valve - Defect
    4382 Rail Pressure Valve Position Test
    4390 Boost Air Temperature Sensor - Short Circuit to B+
    4391 Boost Air Temperature Sensor - Short Circuit to B-
    4392 Boost Air Temperature Sensor
    4397 Position Test Volume Adjust Valve
    43A0 Start-block Relay
    43A1 Start-block Relay
    43A2 Start-block Relay
    43A3 Start-block Relay
    43C0 Throttle Valve Actuator -Short Circuit to B+
    43D1 Throttle Valve Actuator -Short Circuit to B-
    43E2 Throttle Valve Actuator -Open Circuit
    43E3 Throttle Valve Actuator -Plausibility, Overtemp of Output Stage
    43F0 Electrical Aux Heater - Short Circuit to B+
    43F1 Electrical Aux Heater - Short Circuit to B-
    43F2 Electrical Aux Heater - Activation Interrupted
    43F3 Electrical Aux Heater - Plausibility, Overtemp of Output Stage
    4403 Control Unit Internal Error 17
    4410 Injector Cylinder 1- Activation
    4411 Injector Cylinder 1- Activation
    4412 Injector Cylinder 1- Activation
    4413 Injector Cylinder 1- Activation
    4417 Control Master/Slave
    441C Injector Cylinder 1 - Earth Side Activation or Open Circuit
    4420 Injector Cylinder 2- Activation
    4421 Injector Cylinder 2- Activation
    4422 Injector Cylinder 2- Activation
    4423 Injector Cylinder 2- Activation
    4428 Control Master/Slave
    442C Injector Cylinder 2 - Earth Side Activation or Open Circuit
    4430 Injector Cylinder 3- Activation
    4431 Injector Cylinder 3- Activation
    4432 Injector Cylinder 3- Activation
    4433 Injector Cylinder 3- Activation
    4438 Control Master/Slave
    443C Injector Cylinder 3 - Earth Side Activation or Open Circuit
    4440 Injector Cylinder 4- Activation
    4441 Injector Cylinder 4- Activation
    4442 Injector Cylinder 4- Activation
    4443 Injector Cylinder 4- Activation
    444C Injector Cylinder 4 - Earth Side Activation or Open Circuit
    4450 Injector Cylinder 5- Activation
    4451 Injector Cylinder 5- Activation
    4452 Injector Cylinder 5- Activation
    4453 Injector Cylinder 5- Activation
    445C Injector Cylinder 5 - Earth Side Activation or Open Circuit
    4460 Injector Cylinder 6- Activation
    4461 Injector Cylinder 6- Activation
    4462 Injector Cylinder 6- Activation
    4463 Injector Cylinder 6- Activation
    446C Injector Cylinder 6 - Earth Side Activation or Open Circuit
    4473 Control Unit Internal Error 18
    4480 Control Unit Internal Error 19
    4491 Control Unit Internal Error 20
    44A0 Injectors: Activation Cylinder. 1, 2, 3
    44A1 Injectors: Activation Cylinder. 1, 2, 3
    44A3 Injectors: Activation Cylinder. 1, 2, 3
    44AC Injectors: Activation Cylinder. 1, 2, 3
    44B0 Injectors: Activation Cylinder. 1, 2, 3
    44B1 Injectors: Activation Cylinder. 4, 5, 6
    44B3 Injectors: Activation Cylinder. 4, 5, 6
    44BC Injectors: Activation Cylinder. 4, 5, 6
    44C0 Number of Requested Injections Limited
    44C1 Number of Requested Injections Limited
    44C2 Number of Requested Injections Limited
    44D0 Alternator
    44D2 Alternator
    44D3 Alternator
    44E2 Alternator
    44E3 Alternator
    44F0 Rail Pressure not Plausible
    4500 Exhaust Gas Recirculation- Deviation
    4501 Exhaust Gas Recirculation- Negative Deviation or Air Mass too High
    4506 Exhaust Gas Recirculation- Deviation
    4507 Exhaust Gas Recirculation- Posative Deviation or Air Mass too Low
    4512 Thermal Oil Level Sensor
    4513 Thermal Oil Level Sensor
    4521 Boost Pressure Actuator - Regulation Pressure too High
    452A DPF System
    4530 Boost Pressure Actuator - Regulation Pressure too Low
    4536 Power Management
    453B PT Can Bus
    453C PT Can Bus
    453D PT Can Bus
    4541 Thermal Oil Level Sensor
    454B Private CAN bus(master)
    454C Private CAN bus(master)
    454D Private CAN bus(master)
    4550 Boost Pressure Modulation 2
    4560 Rail Pressure Sensor - Plausibility -Pressure too Low
    4570 Rail Pressure not Plausible
    4580 Rail Pressure Sensor - Plausibility -Pressure too High
    4587 Fuel Filter
    4590 Rail Pressure not Plausible
    45A0 Rail Pressure Sensor - Plausibility -Pressure too High
    45A5 Boost Air Temp Sensor 2- Signal
    45A6 Boost Air Temp Sensor 2- Signal
    45C0 Rail Pressure not Plausible
    45E3 Control Master/Slave
    45F2 Control Master/Slave
    45F3 Control Master/Slave
    4600 Rail Pressure Sensor - Plausibility -Pressure too Low
    4605 DPF System
    4610 Rail Pressure not Plausible
    4618 DPF -Plausibility -Pressure Reference
    4620 Rail Pressure Sensor - Plausibility -Pressure too High
    4628 DPF System
    4630 Rail Pressure not Plausible
    4640 Rail Pressure not Plausible
    4645 EGR Controller
    4650 Rail Pressure not Plausible
    4656 Control Unit Internal 24
    4660 Power Supply
    4661 Power Supply
    4665 DPF Bank 1
    4666 DPF Bank 1
    4667 DPF Bank 1
    4670 Power Supply 1 - Short Circuit to B+
    4671 Power Supply 1 - Short Circuit to B-
    4677 Throttle Valve Actuator
    4680 Power Supply 2 - Short Circuit to B+
    4681 Power Supply 2 - Short Circuit to B-
    4687 Throttle Valve Actuator
    4690 Power Supply
    4691 Power Supply
    4697 Throttle Valve Actuator
    46A0 Control Unit Internal Error 1
    46A1 Control Unit Internal Error 1
    46A2 Control Unit Internal Error 1
    46A3 Control Unit Internal Error 1
    46A7 Swirl Flap Actuator
    46B0 Control Unit Internal Error 2
    46B1 Control Unit Internal Error 2
    46B2 Control Unit Internal Error 2
    46B3 Control Unit Internal Error 2
    46B7 Swirl Flap Actuator
    46C0 Control Unit Internal Error 3
    46C1 Control Unit Internal Error 3
    46C2 Control Unit Internal Error 3
    46C3 Control Unit Internal Error 3
    46C7 Swirl Flap Actuator
    46D0 Control Unit Internal Error 4
    46D1 Control Unit Internal Error 4
    46D2 Control Unit Internal Error 4
    46D3 Control Unit Internal Error 4
    46D5 Compressor Bypass Activation
    46D6 Compressor Bypass Activation
    46D7 Compressor Bypass Activation
    46D8 Compressor Bypass Activation
    46E0 Control Unit Internal Error 5
    46E1 Control Unit Internal Error 5
    46E2 Control Unit Internal Error 5
    46E3 Control Unit Internal Error 5
    46E5 Wastegate Valve Activation
    46E6 Wastegate Valve Activation
    46F0 Control Unit Internal Error 6
    46F1 Control Unit Internal Error 6
    46F2 Control Unit Internal Error 6
    46F3 Control Unit Internal Error 6
    4700 Control Unit Internal Error 7
    4701 Control Unit Internal Error 7
    4702 Control Unit Internal Error 7
    4703 Control Unit Internal Error 7
    4707 Wastegate Valve Activation
    4708 Wastegate Valve Activation
    4710 Control Unit Internal Error 8
    4711 Control Unit Internal Error 8
    4712 Control Unit Internal Error 8
    4713 Control Unit Internal Error 8
    4720 Control Unit Internal Error 9
    4721 Control Unit Internal Error 9
    4722 Control Unit Internal Error 9
    4723 Control Unit Internal Error 9
    4730 Quantity Regulation Current Regulation
    4731 Quantity Regulation Current Regulation
    4732 Quantity Regulation Current Regulation
    4740 Control Unit Internal Error 11
    4747 Injectors - Amplifier Adjustment(control unit internal)
    4750 Control Unit Internal Error 12
    4753 Control Unit Internal Error 12
    475A Exhaust Backpressure Sensor- Bank 2
    475B Exhaust Backpressure Sensor- Bank 2
    4763 Control Unit Internal Error 13
    4765 Injector Cyl 1 - Activation
    4766 Injector Cyl 1 - Activation
    4767 Injector Cyl 1 - Activation
    4768 Injector Cyl 1 - Activation
    476A Injector Cyl 4/5/6 Buffer Voltage Measurement(control unit internal)
    476B Injector Cyl 4/5/6 Buffer Voltage Measurement(control unit internal)
    4770 Control Unit Internal Error 14
    4771 Control Unit Internal Error 14
    4772 Control Unit Internal Error 14
    4773 Control Unit Internal Error 14
    477C Injectors Activation Duration(control unit internal)
    4780 Control Unit Internal Error 15
    4781 Control Unit Internal Error 15
    4782 Control Unit Internal Error 15
    4783 Control Unit Internal Error 15
    4785 Injector Cyl 2 - Activation
    4786 Injector Cyl 2 - Activation
    4787 Injector Cyl 2 - Activation
    4788 Injector Cyl 2 - Activation
    478C Injector Activation Duration(control unit internal)
    4792 Monitoring Master/Slave
    4793 Monitoring Master/Slave
    4795 Injector Cyl 3 - Activation
    4796 Injector Cyl 3 - Activation
    4797 Injector Cyl 3 - Activation
    4798 Injector Cyl 3 - Activation
    47A5 Injector Cyl 4 - Activation
    47A6 Injector Cyl 4 - Activation
    47A7 Injector Cyl 4 - Activation
    47A8 Injector Cyl 4 - Activation
    47AB Private CAN Bus(Slave)
    47AC Private CAN Bus(Slave)
    47AD Private CAN Bus(Slave)
    47B5 Injector Cyl 5 - Activation
    47B6 Injector Cyl 5 - Activation
    47B7 Injector Cyl 5 - Activation
    47B8 Injector Cyl 5 - Activation
    47BB Power Train CAN Bus(Slave)
    47BC Power Train CAN Bus(Slave)
    47BD Power Train CAN Bus(Slave)
    47C5 Injector Cyl 6 - Activation
    47C6 Injector Cyl 6 - Activation
    47C7 Injector Cyl 6 - Activation
    47C8 Injector Cyl 6 - Activation
    47D5 Injector Cyl 7 - Activation
    47D6 Injector Cyl 7 - Activation
    47D7 Injector Cyl 7 - Activation
    47D8 Injector Cyl 7 - Activation
    47E5 Injector Cyl 8 - Activation
    47E6 Injector Cyl 8 - Activation
    47E7 Injector Cyl 8 - Activation
    47E8 Injector Cyl 8 - Activation
    4803 Torque Control ACC
    480A DPF -Bank 1
    4810 Torque Control ACC
    481A DPF -Bank 1
    4830 Intake Air Temperature Sensor
    4831 Intake Air Temperature Sensor
    483D Throttle Actuator
    4841 Exhaust Gas Recirculation Regulation 2
    484A Accelerator Pedal Potentiometer -Signal
    4850 Exhaust Gas Recirculation Regulation 2
    4857 Swirl Flap Actuator
    4863 Vehicle Speed Regulation
    4867 Swirl Flap Actuator
    486D Control Unit Software Fault
    4877 Swirl Flap Actuator
    487A Lambda Sensor Bank 2 - Bias Voltage
    487B Lambda Sensor Bank 2 - Bias Voltage
    487C Lambda Sensor Bank 2 - Bias Voltage
    4887 Swirl Flap Actuator
    488A Lambda Sensor Bank 2 - Pump Current
    488B Lambda Sensor Bank 2 - Pump Current
    488C Lambda Sensor Bank 2 - Pump Current
    4896 Swirl Flap Actuator
    489A Lambda Sensor Bank 2 - Virtual Ground
    489B Lambda Sensor Bank 2 - Virtual Ground
    489C Lambda Sensor Bank 2 - Virtual Ground
    48A2 CAN Communication with ASC
    48A3 CAN Communication with ASC
    48B2 CAN Communication with ASC
    48B3 CAN Communication with ASC
    48B5 Injectors Voltage Measurement(control unit internal)
    48B6 Injectors Voltage Measurement(control unit internal)
    48B7 Injectors Voltage Measurement(control unit internal)
    48BC Lambda Sensor Bank 2
    48C2 CAN Communication with EGS
    48C5 Injectors Voltage Measurement(control unit internal)
    48C6 Injectors Voltage Measurement(control unit internal)
    48C7 Injectors Voltage Measurement(control unit internal)
    48CA Lambda Sensor Bank 2
    48CB Lambda Sensor Bank 2
    48D2 CAN Communication with Instrument Cluster
    48D3 CAN Communication with Instrument Cluster
    48DA Control Unit Internal 25
    48DB Control Unit Internal 25
    48EA Control Unit Internal 26
    48EB Control Unit Internal 26
    48F2 CAN BUS Hardware
    48F3 CAN BUS Hardware
    48F7 Injectors Wiring Loom
    48FD Control Unit Internal 27
    4900 DSC Torque Intervention
    4907 Injectors Selector Switch(control unit internal)
    490B Control Unit Internal 28
    4912 CAN BUS Hardware Defect in Operation
    4913 CAN BUS Hardware Fault in Initialisation
    4917 Injectors Charge Switch(control unit internal)
    4920 Transmission Link
    4925 Throttle Valve Actuator 2 Activation
    492A Lambda Sensor Bank 2 Heater
    492B Lambda Sensor Bank 2 Heater
    4936 Throttle Valve Actuator 2 Activation
    493D Lambda Sensor Bank 2
    4947 Throttle Valve Actuator 2 Activation
    4948 Throttle Valve Actuator 2 Activation
    494D Lambda Sensor Bank 2
    4957 Throttle Valve Actuator 2
    495A Exhaust Temp Sensor before DPF Bank 2
    495B Exhaust Temp Sensor before DPF Bank 2
    4967 Throttle Valve Actuator 2
    496A DPF Bank 2
    497A DPF Bank 2
    4991 Message : Instrument Cluster
    4992 Message : Instrument Cluster
    4997 Throttle Valve Actuator 2
    49A2 Message : Ambient Temperature
    49B0 Message : Torque Request
    49C0 Message : Torque Request
    49D2 Message : Torque Request
    49E0 Message : Torque Request
    49E7 Throttle Actuator
    49F2 Message : Vehicle Speed
    49F3 Message : Vehicle Speed
    4A02 Terminal 15
    4A03 Terminal 15
    4A07 Alternator
    4A08 Alternator
    4A10 BSD Interface
    4A13 BSD Interface
    4A15 Alternator
    4A17 Alternator
    4A18 Alternator
    4A22 Boost Air Pressure Actuator 2 Activation
    4A23 Boost Air Pressure Actuator 2 Activation
    4A25 Intelligent Battery Sensor
    4A27 Intelligent Battery Sensor
    4A28 Intelligent Battery Sensor
    4A30 Multifunction Steering Wheel- Toggle Bit
    4A31 Multifunction Steering Wheel- Frequency Counter
    4A32 Multifunction Steering Wheel- No Signal
    4A33 Multifunction Steering Wheel- Signal not Plausible
    4A35 Intelligent Battery Sensor
    4A37 Intelligent Battery Sensor
    4A38 Intelligent Battery Sensor
    4A41 EWS Interface
    4A42 EWS Interface
    4A43 EWS Interface
    4A45 Intelligent Battery Sensor
    4A47 Intelligent Battery Sensor
    4A48 Intelligent Battery Sensor
    4A50 EWS Code Storage
    4A51 EWS Code Storage
    4A56 Power Management Battery
    4A58 Power Management Battery
    4A60 EWS Manipulation
    4A61 EWS Manipulation
    4A62 EWS Manipulation
    4A63 EWS Manipulation
    4A65 Power Management Vehicle Electrical System
    4A66 Power Management Vehicle Electrical System
    4A67 Power Management Vehicle Electrical System
    4A70 Reference Values Incorrect
    4A80 Intake Air Hose
    4AA2 CAN Communication with EGS
    4AA3 CAN Communication with EGS
    4AB0 Electrical Aux Heater
    4AD5 Zero Quantity Adaptation Injector 1
    4AD6 Zero Quantity Adaptation Injector 1
    4AE0 E-Box Ventilator -Short circuit to B+
    4AE1 E-Box Ventilator -Short circuit to B-
    4AE2 E-Box Ventilator -Activation Interrupted
    4AE3 E-Box Ventilator -Plausibility, Overtemp of Output Stage
    4AE5 Zero Quantity Adaptation Injector 2
    4AE6 Zero Quantity Adaptation Injector 2
    4AF0 Control Unit Temperature Sensor
    4AF1 Control Unit Temperature Sensor
    4AF5 Zero Quantity Adaptation Injector 3
    4AF6 Zero Quantity Adaptation Injector 3
    4B00 Control Unit Temperature
    4B05 Zero Quantity Adaptation Injector 4
    4B06 Zero Quantity Adaptation Injector 4
    4B10 Smooth Running Regulation -Correction Quantity too High
    4B11 Smooth Running Regulation -Correction Quantity too Low
    4B15 Zero Quantity Adaptation Injector 5
    4B16 Zero Quantity Adaptation Injector 5
    4B20 Electro ventilator -Blocked
    4B22 Electro Ventilator
    4B25 Zero Quantity Adaptation Injector 6
    4B26 Zero Quantity Adaptation Injector 6
    4B35 Oil Sensor
    4B36 Oil Sensor
    4B37 Oil Sensor
    4B38 Oil Sensor
    4B45 Injector Cyl 1 Energy Consumption Measurement
    4B50 Quantity Compensation
    4B55 Injector Cyl 2 Energy Consumption Measurement
    4B60 Quantity Compensation
    4B65 Injector Cyl 3 Energy Consumption Measurement
    4B75 Injector Cyl 4 Energy Consumption Measurement
    4B80 Rail Pressure not Plausible
    4B85 Injector Cyl 5 Energy Consumption Measurement
    4B90 Rail Pressure Control at Engine Start
    4B95 Injector Cyl 6 Energy Consumption Measurement
    4BA0 Intake Air Temperature Sensor -Signal too High or Short
    4BA1 Intake Air Temperature Sensor -Signal too Low
    4BB0 Air Flow Sensor Power Supply
    4BB1 Air Flow Sensor Power Supply
    4BB5 Air Flow Meter -Signal too Low
    4BB6 Air Flow Meter -Signal too High
    4BC0 Air Flow Meter -Signal too Low
    4BC1 Air Flow Meter -Signal too High
    4BC2 Air Flow Meter -Short Circuit
    4BC5 Intake Air Temperature Sensor
    4BC6 Intake Air Temperature Sensor
    4BC7 Intake Air Temperature Sensor
    4BD2 ARS Torque Request
    4BD5 Engine Support
    4BD6 Engine Support
    4BD7 Engine Support
    4BD8 Engine Support
    4BE2 Message : Transmission data
    4BE7 Message : Transmission data 2
    4BF2 Message : Air Conditioning
    4BF7 Message : Range
    4C00 Message : Cruise Control
    4C01 Message : Cruise Control
    4C02 Message : Cruise Control
    4C06 Message : ARS Status
    4C07 Message : ARS Status
    4C12 Message : DSC Status
    4C15 Message : Terminal 15
    4C16 Message : Terminal 15
    4C17 Message : Terminal 15
    4C20 Message : DSC Torque
    4C21 Message : DSC Torque
    4C22 Message : DSC Torque
    4C23 Message : DSC Torque
    4C27 Message : Vehicle Speed
    4C28 Message : Vehicle Speed
    4C45 Injector Cyl 7 Energy Consumption Measurement
    4C55 Injector Cyl 8 Energy Consumption Measurement
    4C65 Zero Quantity Adaptation Injector 7
    4C66 Zero Quantity Adaptation Injector 7
    4C75 Supply Voltage Air Mass Flow Sensor 2
    4C76 Supply Voltage Air Mass Flow Sensor 2
    4C95 Zero Quantity Adaptation Injector 8
    4C96 Zero Quantity Adaptation Injector 8
    4CA2 Message : Power Management
    4CB2 Message : Power Management
    4CB3 Message : Power Management
    4CF3 DPF -Plausibility -Exhaust Gas Pressure
    4D00 Exhaust Backpressure Sensor Bank 1
    4D03 Exhaust Backpressure Sensor Bank 1
    4D25 Exhaust Temp Sensor before Catalytic Converter Bank 2
    4D26 Exhaust Temp Sensor before Catalytic Converter Bank 2
    4D45 Exhaust Temp Sensor before DPF Bank 2
    4D46 Exhaust Temp Sensor before DPF Bank 2
    4D56 DPF Bank 2
    4D65 DPF System
    4D75 DPF System
    4D81 Boost Pressure Actuator 2 Activation
    4D98 Exhaust Backpressure Sensor Bank 2
    4DA3 Boost Pressure Control
    4DA5 Exhaust Backpressure Sensor Bank 2
    4DA8 Exhaust Backpressure Sensor Bank 2
    4DB0 EGR Controller 2 Activation
    4DC1 EGR Controller 2 Activation
    4DD2 EGR Controller 2 Activation
    4DD3 EGR Controller 2 Activation
    4DD5 Exhaust Temp Sensor before DPF Bank 2
    4DE0 Monitoring Master/Slave - Private CAN
    4DE1 Monitoring Master/Slave - Private CAN
    4DE3 Monitoring Master/Slave - Private CAN
    4DF0 Message : Transmission Torque
    4DF1 Message : Transmission Torque
    4DF2 Message : Transmission Torque
    4DF3 Message : Transmission Torque
    4DF5 Exhaust Temp Sensor before DPF Bank 2
    7073 Automatic Gearbox Switch Signal
    CD87 CAN Bus Communication Error
    CD8B CAN Bus -Control Module has Left the Bus
    A e46adictouring, ZOOLOGICO y Manol les gusta esto.
  2. Manol
    Manol ▒▒▒▒▒▒ Miembro del Club
    1 Oct 2006
    Cádiz
    E46 M43B19
    Buen aporte. Gracias. :guiño:
  3. Manol
    1 Oct 2006
    Cádiz
    E46 M43B19
    No lo sé, lo que si veo, es que empieza con la DDE 5 y el E39, concretamente el 530d es la DDE 4.
    Entonces no sí valdrán o coincidirán.
    De todas formas, apostaría que casi todas coinciden.
  4. el sello de la casa
    el sello de la casa Forista Miembro del Club
    30 May 2010
    X3 E83 35d
    Madre la de cosas que se pueden j*der ....
  5. Manol
    1 Oct 2006
    Cádiz
    E46 M43B19
    En función de lo que llevas, en el Seat 600 no había nada de eso. :descojon:
    A el sello de la casa le gusta esto.
  6. kueto27
    kueto27 En Practicas
    10 Mar 2013
    Leon
    530DA Pre 184cv
    Buen aporte, gracias compañero
  7. ZOOLOGICO
    ZOOLOGICO Me gusta conducir.... , ahora voy en scooter.
    23 May 2007
    530D F10
    Super interesante tu aporte, al menos para mí eran desconocidos.
    Gracias
  8. Richy
    Richy Forista
    8 Ene 2007
    Gracias por la info :)
  9. e46adictouring
    e46adictouring En Practicas
    20 Jul 2015
    320 d touring
    gracias por los errores compañero:goodpost::goodpost::goodpost:
