Quereis saber como descifrar el Nº de bastidor de vuestro BMW?? MAS INFO...
Tema en 'Serie 5 (E34) (1987-1996)' iniciado por El Enfermo, 12 Mar 2007.
  1. El Enfermo
    El Enfermo Forista Legendario
    11 Sep 2004
    Euskadi Tropikal
    Zoom Zoom
    Pues aqui esta la respuesta.. indica el significado de cada una de las letras/numeros del famoso Nº de bastidor..
    No se si será reposteria, pero lo he encontrado y me ha parecido, cuando menos curioso..:wink:
    He encontrado mas informacion relativa a los nº de Bastidor...
    Esta en Ingles y son para los coches destinados a los Estados Unidos, (USA) pero bueno, quizas coincida la manera de codificar, o siga el mismo patron...:nose:
    Pego tal cual...
    More VIN decoding information
    [ Ray Pipkin :: 03 Nov 2000 ] [​IMG] [​IMG] [​IMG]
    The 17-digit VIN number of every car manufactured in, or imported to, the U.S. since 1981 has a check digit in its 9th position. The value of the check digit depends upon the characters in the remaining 16 locations. It is computed by the following algorithm:
    Each of the characters in the VIN is assigned a value. If the character is a digit 0-9, it is assigned that value. If the character is alphabetic, it is assigned a value as follows:
    .A=1, B=2, C=3, D=4, E=5, F=6, G=7, H=8, I=9,
    .J=1, K=2, L=3, M=4, N=5, O=6, P=7, Q=8, R=9,
    .S=2, T=3, U=4, V=5, W=6, X=7, Y=8, Z=9.
    Note that the sequence S,T,U,.. begins with 2,3,4,.. and not 1,2,3,...
    Each of the positions in the VIN is assigned a weight taken sequentially from the following list:
    .{8, 7, 6, 5, 4, 3, 2, 10, -, 9, 8, 7, 6, 5, 4, 3, 2}.
    That is, position 1 has a weight of 8, position 2 has a weight of 7, and so forth. The 9th position is the location of the check digit and does not enter into the computation.
    The check digit is computed by multiplying the value of each character by its positional weight, summing the products, and dividing the sum by 11. The remainder is the value of the check digit; if the remainder is 10, the check digit is assigned the character 'X'.
    As an example, consider the VIN
    .WBAAF931XMEE68337
    Translating the characters into values gives the result
    .62116931-45568337
    The values, when multiplied by the positional weights, give the sequence
    .{48, 14, 6, 5, 24, 27, 6, 10, -, 36, 40, 35, 36, 40, 12, 9, 14}
    whose sum is 362. Division by 11 leaves a remainder of 10, so the check digit is an 'X', as indicated.
    Y LA TRADUCCION GOOGLELIANA...
    17 el número del dígito VIN de cada coche fabricado adentro, o importó a, los E.E.U.U. desde 1981 tiene un dígito de cheque en su 9na posición. El valor del dígito de cheque depende de los caracteres en las 16 localizaciones restantes. Es computado por el algoritmo siguiente: Cada uno de los caracteres en el VIN se asigna un valor. Si el carácter es un dígito 0-9, él se asigna ese valor. Si el carácter es alfabético, él se asigna un valor como sigue:
    . A=1, B=2, C=3, D=4, E=5, F=6, G=7, H=8, I=9, . J=1, K=2, L=3, M=4, N=5, O=6, P=7, Q=8, R=9, . S=2, T=3, U=4, V=5, W=6, X=7, Y=8, Z=9.
    Observar que la secuencia S, T, U. comienza con 2.3.4. y no 1.2.3,… Cada uno de las posiciones en el VIN se asigna un peso tomado secuencialmente de la lista siguiente: .
    {8, 7, 6, 5, 4, 3, 2, 10, -, 9, 8, 7, 6, 5, 4, 3, 2}. Es decir, la posición 1 tiene un peso de 8, posición 2 tiene un peso de 7, y así sucesivamente. La 9na posición es la localización del dígito de cheque y no entra en el cómputo. El dígito de cheque es computado multiplicando el valor de cada carácter por su peso posicional, sumando los productos, y dividiendo la suma por 11. El resto es el valor del dígito de cheque; si el resto es 10, el dígito de cheque se asigna el carácter “X”. Como ejemplo, considerar el VIN .WBAAF931XMEE68337 Traducir los caracteres en valores da el resultado .62116931-45568337 Los valores, cuando son multiplicados por los pesos posicionales, dan la secuencia .
    {48, 14, 6, 5, 24, 27, 6, 10, -, 36, 40, 35, 36, 40, 12, 9, 14} de quién suma es 362. La división por 11 hojas un resto de 10, así que el dígito de cheque es un “X”, según lo indicado.
  2. chancle
    chancle Forista
    1 Jun 2006
    Bizkaia
    Pues si que es curioso. Esta bien:wink:
    SDS
  3. torpedo520I
    torpedo520I Forista Legendario Miembro del Club
    8 Oct 2003
    BCN-Platja Aro-León
    530i (E39)
    interesante. Y los posteriores al 1998 ??,:rolleyes:
  4. Firebird
    Firebird En Practicas
    8 Dic 2005
    Huelva
    No cuadra con ninguno de mis 2 coches...
  5. El Enfermo
    11 Sep 2004
    Euskadi Tropikal
    Zoom Zoom
    Konio..no me habia fijado en el detalle de los años....:err:, supongo que a partir del 98 empezaria como las matriculas de los coches... AB, AC, AD etc....
    Digo yo.... :nose:
  6. erredege
    erredege Forista
    16 Dic 2003
    E39, R28, F32.
    Gracias, muy interesante.
  7. Jokin
    Jokin Clan Leader
    12 Abr 2006
    NEVERLAND Valley ranch
    535d GT
    Muy interesante
  8. ramogon
    ramogon Guest
    la verda que es muy curioso.A ver si descrifamos el modelo a partir del 98.Haremos una labor de investigacion.Muchas gracias
  9. Daniva
    Daniva En Practicas
    8 May 2006
    "0G" del 2003 seria el mio:-s
  10. El Enfermo
    11 Sep 2004
    Euskadi Tropikal
    Zoom Zoom
    Añado en el 1er post...
  11. negro530
    negro530 Guest
    interesante
  12. Literato
    Literato Forista
    16 Feb 2006
    Marbella
    oye, está muy interesante...
  13. R.VELA
    R.VELA Forista
    8 Abr 2006
    Elche (Alicante)
    esta muy bien esto...
