Video Audi Q3 Sportback
Ahora están de moda los zarrios con el culo apretao :ANAL: y los llaman coupé :LOL:, el último en llegar al corral es este biggrin
2020 Audi Q3 Sportback Color: Dew Silver.
The Audi Q3 Sportback stands for strength and precision to an equal degree, and reflects this in all design details. The black grille of the octagonal Singleframe is strongly three-dimensional in design, and this makes it particularly sporty. The same applies for the trapezoidal air inlets and the expressive bumper with its flat blade. The coupé-like passenger cabin acts as a contrast to the distinctive attachments, which are painted in contrasting colors and thus emphasize the SUV character.
The low roofline gives way to flat D‑pillars and ends in a roof edge spoiler. As a result, the Audi Q3 Sportback appears much longer than its sister model Q3. In addition, the SUV-coupé is almost three centimeters flatter, and thus has a more muscular appearance. Above the wheels, strong contours draw attention to the quattro drive, which comes as standard with most engines. Many light and shadow effects arise on the plastic-formed rear. The low window, flanked by aero trims, and the sporty bumper, which takes up the look of the air inlets, emphasize the width of the Audi Q3 Sportback. The reversing lights contribute to this as well: they run inwards in a tapered shape, just like the flat headlights. Audi supplies the latter in three versions up to Matrix LED technology, whose adaptive high beam intelligently illuminates the road as best suits the driving situation.
The Audi Q3 Sportback offers driving fun on various terrains. In the city, on long-haul routes, or on easy terrain – the compact crossover is a dynamic all-rounder. It features progressive steering as standard, whose gear ratio becomes increasingly direct as the steering angle increases, and the sport suspension.
On request, the suspension is available with damper control, which further increases the range between dynamism and comfort. Depending on the driving situation, road condition, and personal preferences, the driver can vary the car’s characteristics via the standard dynamic handling system, Audi drive select, in six profiles, including the offroad mode. In addition to the engine and transmission set-up, this system also influences the electronically adjustable shock absorbers and the steering assistance. As an option, the hill descent control can offer support: it keeps the speed selected by the driver constant on an incline greater than 6%.
For the market launch in Europe, a gasoline and a diesel engine are available for selection for the Audi Q3 Sportback. With 169 kW (230 metric hp), the 2.0 TFSI is the most powerful engine (Audi Q3 Sportback 45 TFSI quattro S tronic). The 2.0 TDI has an output of 110 kW (150 metric hp) (Audi Q3 Sportback 35 TDI S tronic). Shortly after market launch, it will also be available as a manual transmission with a quattro drive. Additional engines will follow in the course of the year, including a more powerful diesel and an entry-level gasoline engine, which works together with a 48 V mild-hybrid system. During deceleration, it recovers energy; during acceleration from low speeds, it supports the engine. In real-life driving, it can save up to 0.4 l of fuel per 100 km (62.1 mi).
In the top engines, the quattro all-wheel drive takes on the job of force transmission as standard. Its central component is a hydraulic multi-plate clutch on the rear axle. Its electronic management combines outstanding stability and strong traction with a high level of driving enjoyment. At the limits of performance, the quattro drive works closely together with the wheel-selective torque control, It makes handling even more dynamic and stable by means of gentle brake interventions on the inside wheels with the quattro drive and the inside front wheel with the front drive. The Audi Q3 Sportback is 4.50 m (14.8 ft) long, 1.84 m (6.0 ft) wide and 1.56 m (5.1 ft) high; its wheelbase measures 2.68 m (8.8 ft). This results in a large and highly variable interior. The rear seats offer space for three people. They can be moved 130 mm (5.1 in) longitudinally as standard; their backrests are divided into three sections, and their inclination can be adjusted in seven stages. The volume of the luggage compartment ranges from 530 l (18.7 cu ft) to 1,400 l (49.4 cu ft). The loading floor can be adjusted to two levels, and the rear shelf is located beneath it. As an option, Audi will deliver an electric tailgate that can also be opened and closed with a foot motion. The front seats – electrically adjustable and heated on request – offer a sporty position and a high level of comfort. Depending on the equipment, there are sport seats with contrasting stitching and colored stripes along the side panels.
Reacciones: agc
https://www.km77.com/coches/audi/q3/2020/sportback/estandar/q3-sportback/informacion
Audi Q3 Sportback (2020) | Información general
Carlos Fernández (@CarlosFP_77)
Este nuevo modelo está basado en el Audi Q3 (2019), con respecto al que se diferencia principalmente por la forma de la parte posterior de la carrocería, que presenta un techo con una caída más pronunciada. Las entregas comenzarán en otoño.
Las dimensiones exteriores son 4,50 metros de longitud, 1,84 m de anchura y 1,56 m de altura. Es 16 milímetros más largo y 29 milímetros más bajo que el Q3. Otros cambios en el exterior vienen dados por varias molduras acabadas en color negro brillante (entre ellas, la parrilla), un alerón trasero más prominente y paragolpes específicos.
El BMW X4 tiene una carrocería de formas similares, si bien es considerablemente más grande (mide 4,75 metros de longitud).
El volumen del maletero (varía según la configuración de los asientos traseros) es 530 litros como máximo, lo mismo que el del Q3 y cinco litros más que el del BMW X4. Es un valor bueno para un todoterreno de su tamaño (listado de aquellos que miden entre 4,40 y 4,60 metros de longitud, ordenados por el volumen de su maletero).
Al igual que en el Q3, la banqueta trasera de asientos se puede desplazar longitudinalmente por unos carriles a lo largo de 12 cm y tiene un respaldo que se puede abatir en tres partes. El portón puede tener accionamiento eléctrico y una función de apertura manos libres (se activa dando un puntapié al aire bajo el paragolpes trasero).
En el momento del lanzamiento estará disponible con un motor de gasolina de 230 CV y tracción a las cuatro ruedas (versión 45 TFSI S tronic quattro) y otro Diesel de 150 CV con tracción delantera (versión 35 TDI S tronic). Ambos van siempre asociados a un cambio de marchas automático de doble embrague y siete relaciones. Poco después se ofrecerá el mismo motor Diesel con tracción a las cuatro ruedas y cambio manual.
A lo largo del año 2020, Audi introducirá a la gama dos versiones más: una con un motor Diesel más potente y otra, que dará acceso a la gama, con un motor de gasolina asociado a un sistema de hibridación ligero con una red eléctrica de 48 voltios (35 TFSI).
El aspecto del habitáculo es prácticamente idéntico al del Audi Q3. La principal diferencia es que la cota de espacio para la cabeza en las plazas traseras es menor debido a la caída del techo (cuando lo midamos sabremos cuánto). El sistema multimedia presenta, como novedad, la función de control por voz Alexa, un producto de la empresa Amazon.
agc
La trasera tipo X4, me gusta más que la versión normal.
Nanouk
Allá por el 2008, el interior de un e92 le daba un buen repaso al de un A5, bajo mi modesta opinión.
Ahora mismo, el interior de este Q3 se lo da con sopas al del X4. La pantalla con los relojes está mucho mejor conseguida y la pantalla central la veo mucho mejor integrada.
Muerto me he quedado cuando el maletero del Q3 Sportback es mayor que el del X4 y el coche es considerablemente menos largo. ¿Tan mal aprovechado tiene el X4 su habitáculo y maletero? ¿Es porque el X4 está diseñado para tener el tren trasero y el Audi no?
Una pena por BMW :(
EÄRENDIL
La puerta trasera es diminuta, en las fotos del interior se aprecia mejor...... y siguen poniendo la pantallita en el sitio erróneo....
MiniFER
Vicepresidente Ejecutivo
Para lo que son este tipo de coches, creo que les ha quedado logrado.
Al Q3 actual ya me he subido y aunque no es de mi estilo me parece un producto resultón.
Yo con esos “presupuestos” me iría claramente a un A3, no tardará en aparecer el nuevo.
Lo que son las cosas, los medios apenas hablan de él; es que si no se trata de un SUV es difícil ser noticia actualmente.
Malavida79
Hoy he acompañado a un compañero a Audi a dejar su coche en el taller y hemos estado cotilleando el bicho. Muy, muy, muy bonito. Exteriormente e interiormente, lo siento por el X4, pero el Audi es realmente bonito.
