Ayyyy ayyyyyy
6 Abr 2002
Bosch creará un sistema automático que reconoce las señales de maxima velocidad (europeas) para limitar en esa circunstancia al vehiculo :roll: :roll: :roll:
BOXBERG, Germany – Robert Bosch GmbH has a new device that may keep lead-foot drivers out of trouble with the law.
At the supplier's test track here, Bosch demonstrates its roadsign recognition system on a Mercedes-Benz S-Class. A complementary metal oxide semiconductor (CMOS) camera placed below the rear-view mirror surveys the road ahead and is programmed to identify speed-limit and other traffic signs.
Bosch system recognizes speed-limit signs in Europe (above) as well as those in U.S.
For the demonstration, the prototype Mercedes S-Class is set up with a black-and-white video display of the road ahead, with the roadsign highlighted in color. Once identified, the vehicle gives audible notification to the driver: “Speed limit, 50.”
The system works as intended, notifying the driver each time the speed limit changes. The device could be handy in city traffic, where speed limits frequently change, often on the same road.
It can be programmed for a customer's preference. For instance, a visual notice can be given to the driver, rather than an audible one. Plus, the system can be programmed to notify the driver only if the vehicle is exceeding the speed limit by 5 mph or 10 mph (8 or 16 km/h).
Speed-limit signs across Europe may use slightly different type styles, but their basic designs are the same: round and white, with black type and a red ring around the perimeter. In the U.S., speed-limit signs generally are rectangular, white and black. The device is designed to detect either type.
Bosch says the CMOS camera has high dynamic range, allowing it to work equally well at night or during the day, as well as in snow and rain.
Bosch is unable to talk about the system's cost because it does not yet have a customer. However, several auto makers have expressed interest in the technology, which is nearly ready for production.
X
Xan
Bueno, ahora solo nos falta la trampa para que el "apaño" funcione bien, no?. :-P
Pues además: para 2015 en Inglaterra TODAS LAS CARRETERAS DE PEAJE (TODAS) entre 2 euros po rkm y 3 centimos d eeuro según horas y saturación :eek:
Sistema via satélite; dicen que a acambio bajarán drásticamente los impuestos a la gasolina (verlo para creerlo)
A mi, con independencia de otras cosas, lo que menos me gusta es que un funcionario (y menos un emplado de una contrata, o subcontrata de subcontrata ) sepa donde c**o y a qué horas voy y vendo y cómo :bash:
C
calzoncillo-man
!!!!!!Chisssssssssssssssssssssssssssssst calla Gus no sea que ZP este por el foro y le des ideas¡¡¡¡¡¡
X
Xan
Cierto, al parecer al Gobierno Britanico , el hecho de cobrar tasas a los automóviles que accedieran al centro de Londres les esta dando muy malas ideas, ](*,)
C
calzoncillo-man
Xan dijo:
Acuerdate de la famosa POL TAX que le costo las elecciones a la Tacher hace unos años.
PD La famosa Pol Tax era un impuesto por el cual se igualaban la tasas de matriculacion de los vehiculos, por lo cual pagaba lo mismo un Seat Panda que un Rolls Royce. :madfawk:
Uys, es verdad :???: Ya callo, ya callo... :???:
T
Toni Montana
Vamos a peor ... en 5 años en bici todos ...
(por cierto, han probado "el sistemita" sobre un S-Class) :finga:
pLEy
21 Ago 2002
Lo triste es que tarde o temprano esas normativas llegan a nuestro pais, sean o no igual de efectivas. :bash:
G
Geode
De algo tenia que valer ser los atapuerquenses de Europa (y medio mundo)... Tendremos mas libertad durante mas tiempo.
En Japon las autopistas ya ponen multas ellas solitas.
guakarimaso
530IA touring
3 Oct 2002
Gus dijo:
:bash:
a mi lo del peaje me parece increible :madfawk: ni aunque regalaran la gasolina osea un viaje a Madrid des de oviedo 400 euros ir y 400 volver no puede ser:madfawk:
CARLOSZ3
15 Abr 2004
Juer, a que lumbreras se le ocurriran estas ideas?:supz:
6 Abr 2002
joer lo del peaje e carreteras y autovias me parce un grave retroceso, eso encarecerá absolutamente TODO, por aquí ya "insinuó" el amigo Borrel algo se eso, no sé si os acordais :roll: , pero vamos que después de pagar un 29 % de impuestos por la compra de un coche tengas que pagar ademas por circular con ñel es de traca........pero que digo, si eso es lo que hacemos con el impuesto de circulación de los ayuntamientos....y ademas debemos de pagar por aparcar............ me voy a la cama despertarme dentro de 15 años :roll:
randy_oz
2 Abr 2003
Gus dijo:
Esto no necesitaria algo en la Constitucion? Y el derecho a la intimidad? Es pa fliparlo... como minimo al Bush le han prohibido que el FBI acceda y guarde informacion sobre los libros que la gente lee y coge de las bibliotecas ](*,) ](*,)
Salu2 ;-)
aranda
18 Jun 2004
me quedo sin palabras , sólo puedo decir : LAMENTABLE
T
Till
Pues... y eso afectará también a futuros vehículos de hidrógeno y demás? Porque si lo intentan justificar con reducción de contaminación, pseee, pos fale, al menos se buscan excusa, pero si luego tienes un Prius Mk VII que va con agua salá y aún así te toca pagar 10 € de peaje por ir al centro comercial del pueblo de al lado...
A ver si se inventan un transportador de esos de Star Trek porque al final no vamos a poder salir de casa en coche... :(
