Bueno pues os presento otros códigos de error que creo que no se reflejan en el menú oculto, ya que se deben almacenar en otras centralitas. Me parece interesante y vergonzoso que en la caja de cambios automática no haya ningún código que indique falta de nivel de aceite. BMW CCID Code List Active Front Steering AFS 273 Active Steering Fault AFS 321 Active Steering Deactivated Trailer Module AHM 4 Trailer Parking Light Left AHM 5 Trailer Parking Light Right AHM 6 Trailer Indicator Left AHM 7 Trailer Indicator Right AHM 8 Trailer Brake Lights AHM 9 Trailer Fog Light AHM 75 Trailer Electrics Failed AHM 90 Trailer Reverse Light AHM 423 Trailer Coupling Lock Car Access System CAS 14 Door Open F/R CAS 15 Door Open F/L CAS 16 Door Open R/L CAS 17 Door Open R/R CAS 18 Bonnet open CAS 19 Boot open CAS 21 Ignition Problem, Depress Brake to Start CAS 22 Starter Problem, Engine cannot Restart CAS 38 Wrong Remote Key CAS 40 Press Brake to Start CAS 65 Change Key, Key Battery Low CAS 66 Remote Control/Key Fault CAS 67 Remote Control/Key Battery Discharged CAS 68 Remote Key Stationary Function Battery Low CAS 186 ELV Steering Lock Fault. Engine cannot be restarted CAS 187 ELV Steering Lock Active. Move Steering Wheel to Restart CAS 205 Remote Key not Present CAS 206 Engine Start on next Press CAS 208 Comfort Access Deactivated CAS 209 Remote Key in Vehicle, Locking not possible CAS 217 No Remote Control CAS 303 Depress Clutch to Start CAS 335 Ignition Switched On CAS 347 Position R/N/D Not Possible CAS 348 Engage Park Before Leaving Vehicle CAS 349 Engage Park Before Switching Ignition Off CAS 413 Steering Column Unlocked Convertible Top Module CTM 401 Roof Mechanism Failure CTM 416 Luggage Compartment Partition CTM 432 Roof Drive Overload CTM 445 Vehicle Not Level Digital Motor Electronics/Digital Diesel Electronics DME/DDE 25 Preheating, Please Wait DME/DDE 26 Cruise Control Defective DME/DDE 27 Engine Oil Level Low DME/DDE 28 Engine Oil Level Below Minimum DME/DDE 29 Engine Problem, Power Reduced DME/DDE 30 Engine Problem, Stop Engine DME/DDE 31 Engine Problem, Increased Emissions DME/DDE 32 Fuel Cap Open DME/DDE 33 Engine Problem, Reduce Engine Load DME/DDE 39 Engine Overheat, Stop Engine DME/DDE 49 Particulate Filter Malfunction DME/DDE 148 Brake Light Control Failed DME/DDE 182 Oil Level Sensor Malfunction DME/DDE 212 Engine Oil Pressure, Stop Engine DME/DDE 213 Battery Not Charged DME/DDE 220 Battery Discharge Rate High DME/DDE 229 Battery Charge Low DME/DDE 247 Battery Monitoring Failed DME/DDE 257 Engine Temperature Too High, Drive Moderately DME/DDE 304 Check Battery Condition DME/DDE 305 Check Battery Terminals DME/DDE 306 Battery Charge Low DME/DDE 367 Engine Temperature Too High DME/DDE 427 Engine Oil Pressure Low Dynamic Stability Control DSC 24 DBC Dynamic Brake Control Brake Assist Failed DSC 35 DSC Failed DSC 36 DSC/DTC Deactivated DSC 42 DSC Control System/Ride Height adjustment DSC 50 Runflat Indicator Failed DSC 63 Tyre Failure DSC 71 Brake Pads Worn DSC 74 Brake Fluid Low DSC 184 Dynamic Traction Control Active DSC 236 Brake and Stability Systems Failure DSC 237 Stability Systems Failure DSC 328 Brake Pad Wear Sensor DSC 330 Hill Decent Control not Available DSC 331 Hill Decent Control Active DSC 332 Hill Decent Control Deactivated DSC 333 Hill Decent Control not Possible DSC 334 Run Flat System Requires Standardisation DSC 352 Brakes Too Hot DSC 353 Brakes Overheated DSC 354 Start Assist Inactive DSC 364 RPA Initialisation DSC 382 DSC Restricted, Brake Pressure Sensor DSC 431 Brake Loading Too High Corner Brake Control DSC/CBC 42 Brake and Driving Control Failure Tyre Pressure Control DSC/RPA 50 Tyre Monitoring Failure DSC/RPA 63 Tyre Failure X Drive Control DXC 350 4X4 System Failure DXC 351 4X4 and DSC Failure DXC 369 4X4, DSC and ABS Failure DXC 370 4X4, DSC, ABS and EBV Failure Electronic Gearbox Control/Sequential Sports Gearbox EGS/SSG 103 Gearbox Overheating- Drive with Care EGS/SSG 104 Gearbox Overheating- Reduced Output EGS/SSG 105 Gearbox Overheated - Stop Vehicle EGS/SSG 171 Transmission Failsafe Active EGS/SSG 172 Transmission Malfunction EGS/SSG 178 Transmission in Neutral, Engage Parking Brake EGS/SSG 179 Transmission Malfunction EGS/SSG 248 Brake Signal Malfunction, Gears May Be Selected Without Brake EGS/SSG 250 Brake Signal Malfunction, Gears May Be Selected Without Brake EGS/SSG 254 Transmission Malfunction EGS/SSG 287 Clutch Overheated EGS/SSG 288 Transmission Malfunction, Failsafe Activated EGS/SSG 289 Transmission Malfunction, Failsafe Activated EGS/SSG 290 Transmission Malfunction, Journey May Be Continued With Care EGS/SSG 291 Transmission Malfunction, Failsafe Activated EGS/SSG 292 Transmission Malfunction, Re-Select Gear EGS/SSG 293 Press Brake and Select Neutral to Start EGS/SSG 302 Park Not Engaged EGS/SSG 307 Transmission Malfunction, Multiple Failures EGS/SSG 322 Transmission Teach-in Active EGS/SSG 323 Clutch Teach-in Active EGS/SSG 325 Transmission in Neutral EGS/SSG 326 Transmission in Drive EGS/SSG 368 Transmission Failsafe Active EGS/SSG 419 Drive Malfunction EGS/SSG 420 Transmission Malfunction Electronic Height Control EHC 45 Level Control System Failure EHC 245 Level Control System Failure Electric Fuel Pump EKP 216 Fuel Pump Fault EKP 309 Fuel Pump Malfunction Electronic Power Steering EPS 73 EPS Inoperative EPS 385 Steering Assistance Failed High Beam Assistant FLA 374 Main Beam Assist Defective FLA 375 Main Beam Assist Not Active FLA 377 Main Beam Assist Sensativity Footwell Module FRM 87 Right Rear Light Failure FRM 88 Dipped Beam Left Failure FRM 89 Dipped Beam Right Failure FRM 111 Number Plate Light Left Failure FRM 113 Sidelights Switched On FRM 114 Rear Fog Light Failure FRM 115 Reverse Light Right Failure FRM 116 Indicator Rear Left Failure FRM 117 Reverse Light Left Failure FRM 118 Rear Light Right Failure FRM 119 Indicator Front Right Failure FRM 120 Dipped Beam Left Failure FRM 121 Dipped Beam Right Failure FRM 122 Indicator Front Right Failure FRM 123 Rear Light Right Failure FRM 124 Indicator Right Failure FRM 125 Indicator Rear Right Failure FRM 126 Fog Light Right Failure FRM 127 Side Indicator Left Failure FRM 128 Left High Beam Failure FRM 129 Rear Fog Light Failure FRM 130 Right High Beam Failure FRM 131 Parking Light Left Front Failure FRM 132 Front Right Side Light Failure FRM 133 Right Rear Light Failure FRM 134 Right Brake Light Failure FRM 135 Centre Brake Light Failure FRM 136 Left Brake Light Failure FRM 137 Number Plate Light Right Failure FRM 138 Fog Light Left Failure FRM 196 Indicator Front Right Failure FRM 197 Indicator Front Left Failure FRM 231 Light System Failure FRM 256 Headlight Leveling System Failure FRM 259 Window Anti-Trap Deactivated FRM 261 Window Anti-Trap Failure FRM 345 Brake/Tail Light Failure Right FRM 346 Brake/Tail Light Failure Left FRM 371 Number Plate Light Failure FRM 372 Brake Force Display Light Failure Left FRM 373 Brake Force Display Light Failure Right FRM 378 Sidelight/Daytime Lights Defective- Left FRM 379 Sidelight/Daytime Lights Defective- Right FRM 380 Turn Signal Lights Defective- Left FRM 381 Turn Signal Lights Defective- Right FRM/ALC 295 Adaptive Cornering Lights Failure FRM 437 Parling Lights On Instrument Cluster IKE 13 Radio Key in Lock IKE 41 Service Due IKE 55 Parking Brake Active IKE 60 Speedometer Failure IKE 62 Vehicle Speed Limit Exceeded IKE 78 Vehicle Speed Limit Exceeded IKE 79 Low External Temperature IKE 165 Low External Temperature IKE 167 Reset Clock IKE 275 Low Fuel IKE 279 Driver's Seat Insecure IKE 280 Passenger's Seat Insecure IKE 281 Service Due IKE 284 Service Overdue IKE 285 Service OK IKE 286 Fuel Low / Range IKE 301 Seatback Monitoring Failed IKE 308 Parking Brake Applied Junction Box JB 164 Windscreen Washer Fluid Low JB 166 Engine Coolant Level Low JB 207 Central Electronics Failure, Stop Vehicle JB 415 Battery Discharge Rate High JB 430 Transport Mode Active Longitudinal Dynamics Management LDM 1 Active Cruise Control Disabled, Poor Conditions LDM 2 Active Cruise Control Disabled, Poor Signal LDM 3 Active Cruise Control Failure LDM 59 Active Cruise Control Disabled, Parking Brake LDM 69 Active Cruise Control Disabled, Speed too Low LDM 85 Active Cruise Control Disabled, Hill Descent LDM 176 Active Cruise Control Disabled, Sensor Error LDM 276 Engine Speed Too High LDM 277 Active Cruise Control Disabled, Gear Selection LDM 278 Engine Speed Too Low LDM 337 Dynamic Cruise Control Failure LDM 338 Dynamic Cruise Control Deactivated, Parking Brake LDM 339 Dynamic Cruise Control Deactivated, Excessive Braking LDM 340 Dynamic Cruise Control Deactivated, Poor Conditions LDM 341 Dynamic Cruise Control Deactivated, Gear Selection LDM 342 Dynamic Cruise Control Deactivated, Speed Too Low Electric Sunroof MDS 260 Sunroof Anti-Trap Deactivated MDS 262 Sunroof Anti-Trap Failure Multiple Restraint System MRS 46 Fasten Seat Belt MRS 91 Fasten Seat Belt MRS 92 Front Passenger Seat Belt Pretensioner Fault MRS 93 Driver's Seat Belt Pretensioner Fault MRS 94 Rear Left Seat Belt Pretensioner Fault MRS 95 Rear Right Seat Belt Pretensioner Fault MRS 97 Multiple Restraint System Fault MRS 106 Rear Left Side Airbag Fault MRS 107 Rear Right Side Airbag Fault MRS 108 Driver's Airbag Fault MRS 109 Passenger Airbag Fault MRS 181 System Check Failed MRS 266 Rollover Protection Malfunction MRS 389 Fasten Driver's Seat Belt MRS 390 Fasten Passenger's Seat Belt Park Distance Control PDC 195 Park Distance Control Failure Tyre Pressure Control RDC 139 Front Left Tyre Pressure RDC 140 Rear Right Tyre Pressure RDC 141 Rear Left Tyre Pressure RDC 142 Check Tyre Pressures RDC 143 Front Right Tyre Pressure RDC 144 Tyre Pressure Monitoring Fault RDC 145 Tyre Pressure Monitoring Deactivated RDC 147 Tyre Puncture Detected RDC 149 Tyre Pressure Monitoring Failure RDC 192 Tyre Pressure Monitoring Deactivated, System Initialising RDC 265 Check Tyre Pressures, Mismatch RDC 327 Tyre Pressure Monitoring Deactivated, System Initialising Telecommunications Module TCU 296 SOS Deactivated, Check Phone TCU 297 BMW Assist Deactivated TCU 298 BMW Assist Not Possible TCU 299 SOS Call System Failure TCU 300 BMW Assist Deactivated, Check SIM.
Hay 6 códigos que dice; Thermal Oil Level Sensor , no habrá alguno que se refiera al aceite del cambio? Muy interesante pero donde y como se ven estos códigos?
Ayer por casualidad leí el otro hilo de códigos que publicaste. Muchas gracias en ambos casos por la valiosa info.
Interesante aporte, ahora sólo falta saber desde donde se pueden leer. He estado comprobando con el pasoft y no coinciden. Saludos y gracias !
No tengo ni idea de como se ven estos códigos ya que se supone que estan en otras centralitas no en la ecu, donde si están los códigos de error del otro hilo. Supongo que habrá un software específico a ver si alguien sabe más del tema. Me parece interesante y triste el tema de los fallos de la caja de cambios automático ya que aunque lo metas en la máquina da poca información.
