BMW i8 Spyder
biggrin
Following on from its its i3 and i8 Concepts, BMW has released details of a third model to its i model range, the i8 Concept Spyder.
As with the Coupe, the i8 Concept Spyder is a plug-in hybrid that utilizes two separate power sources. Driving the rear wheels is a turbocharged three-cylinder petrol unit which develops 164 kW (223 hp) and 300 Nm of torque, while at the front a lithium-ion battery – which takes just 1.45 hours for a full charge – supplies electricity to a 96 kW (131 hp) motor allowing a range of 27-30 km (17 – 19 miles) on its own. With the two powerplants combined, the Spyder can hit 100 km/h (62 mph) in just 5 seconds and reach a limited top speed of 250 km/h (155 mph), and that’s from a car capable of consuming a mere 3 l/100km (94 mpg imp) in the European test cycle. A major contributor to those figures is the use of lightweight materials; with a passenger cell constructed from carbon-fibre-reinforced plastic (CFRP) and drive modules made predominantly from aluminium, this open-topped machine tips the scales at just 1630 kg – not much more than the current 3 Series.
Apart from the obvious lack of a roof, the low-slung Spyder is near identical to its hard-topped sibling, with its most striking feature being those upward-swivelling, windowless doors. A notable feature is the fact that remote functions can be accessed via the owner’s smartphone. Basically, this allows owners to set the operating temperature of the interior before they reach their car, locate it in a large car park or transfer a route so the smartphone can give directions once the driver becomes a pedestrian. Eerily, it can access your diary (like a four-wheeled, obsessive partner) and, when plugged into a power socket, ensure that you have a full charge so you won’t miss your appointment.
street20
27 Mar 2008
a mi me gusta, e innovación le sobra, además lo que tiene en el maletero es un patinete eléctrico no?... mmm ya pensando en las ciudades en las que se va a cortar el paso a los coches a sus calles más centrales... me gusta!!! además, que 3l/100 y 5 seg para el 0-100 me parecen muy buenas prestaciones.
_Dani_
audi S3 210cv
29 May 2007
Pues a mi me encanta
jaudi
S4 & SLK350
22 Abr 2009
Quítale tanta tontería de atrás y en su lugar mete el V10 y hablamos
Boeing735
13 Nov 2011
Yo menos las llantas que son feillas lo demás me gusta todo!!
julfost
Muy guapo el concept, a ver si vemos algo parecido en la realidad
DR666
316ti M - SD 300
30 May 2009
:xray::xray::xray: Impresionante, me parece espectacular y con un consumo de risa.
Lucas M
13 May 2003
Deseo con todas mis fuerzas poder hacerme con uno
gantxos
535d 530d e39
19 Jun 2011
que se parece a un z4,ja,ja,ja.
ayovi
Land Rover
23 Jun 2007
:-k:-k:-k:-k:-k:-k:-k Quiero uno, en negro
monio
Volvo S60 D5
17 Nov 2009
Que cosa más fea leche......:bash:
27 Jul 2010
Ahora es cuando aquél que tiene un bmw con 500000 km y 40 años dice...vaya mierda de coche...que feo...prefiero el mio...vaya con bmw....ya no saben hacer coches...etc,etc...
