BMW M30 Individual ITB DCOE Weber I6 530 535
Tema en 'Foro Latinoamérica BMW FAQ' iniciado por guillermogiusti, 30 Jun 2009.
  1. guillermogiusti
    guillermogiusti
    28 Jun 2009
    Tigre - Argentina
    LO MEJOR QUE HE VISTO PARA MIS BIMMERS 6 EN LINEA.... EN AÑOS
    GRACIAS AL APORTE DE MI AMICHI DESCORCHATEENS.../realmente, te pasaste!
    me viene genial para el otro M30 que no tiene admision, lo puedo ir armando afuera de carrera
    y luego en 1 dia lo meto en la 6! y a la pista!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    US $1,949.00 (cuanto saldra puesto aca??? pero.....)
    http://cgi.ebay.com/ebaymotors/BMW-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    EXTRUDABODY
    BMW M30 ITB Weber Replacements
    DCOE based on Weber Manifold
    Weber 45mm/1.75" straight bore or 45mm Taper Bore Replacements.
    All Parts are
    100% CLEAR & RED Anodized with ALL Stainless Hardware. Nothing to Rust or Corrode!
    Kit Contents:
    3 x 45mm/1.75" ID straight bore or Taper bore Throttle bodies.
    1 set of M30 Manifolds
    1 x 24" Fuel Rail, -6AN Fittings and Hardware kit. "Comes drilled". No drilling charge required.
    1 x TPS Sensor and a Mini-Harness
    6 x Airhorns or Velocity Stacks, (see note #9)
    1 x Throttle Cable Mounting kit. Contents of kit: Throttle Stop, Throttle Cam, Throttle Cable holder/adjuster. This in incorporated into the Jack Shaft to ease retrofiting.
    6 x Clamp-on Air Filters.
    1 x Jack Shaft Linkage Kit
    1 x Vacuum Log aids in the tuning Process with regards to MAP Sensors
    100% Made in the USA. We are doing our Part for the US Economy!
    NOTES:
    1. Fuel rail is not drilled for injectors. Add our $35 Custom Drilling Service at the end of the auction if you want us to do the drilling. We need to know the "C to C" dimension of your manifold to drill the rail for you.
    2. Fuel Rail can be drilled for either 11mm or 14mm O-ring type injectors.
    3. Rail Mounting Hardware is set-up for "Standard" Size/body Bosch Injectors.
    4. Throttle Bodies fit DCOE, IDF, DHLA Manifolds among others.
    5. Can be made to work on VW Air-Cooled engines by cutting Rail in half, and buying an additional -6AN fitting Kit from our store.
    6. Throttle Bodies can be mounted Horizontal or Vertical to fit various Side Draft or Down Draft Manifolds.
    7. Fuel Injectors, Manifold, and hoses are not included.
    8. Independent flow testing rates the Throttle Bodies at 293cfm for the 45mm Straight bore and 295cfm for the 45mm Taper Bores for each cylinder.
    9. Where's the Velocity Stacks? See the CAD Drawing below with the Airflow painted in "YELLOW"? The Velocity stacks are built into the throttle body.
    10. Standard Weber Velocity Stacks can also be fitted for the old School Look.
    11. Extrudabody Airhorns work with the Extrudabody Filters to give excellent flow characteristics while protecting your engine!
    12. We reccommend buying the 6 cylinder Linkage kit with all Inline 6 cylinders due to the miss-matched nature of most CAST Manifolds. available in our store.
    13. Manifolds are CAST Aluminum, some porting is to be expected to achieve the utmost fitment and flow on the Port Side and ITB side of the manifolds. Just the nature of Cast Aluminum.
    14. Designed to work with MAP sensor based EFI controllers, which may require aftermarket ECU or other type on Piggy Back controlers that manipulate the stock Electronics.
    15. Not provided: Injectors, Vacuum Line, intake gaskets.
    16. MAF sensor to be used with stock electronics or Plenum: It is possible to build a Plenum that will allow this kit to work with your stock MAF Sensor, but it is not provided by me. You would need to contact a local fabricator to work out fitment and installation.
    "Questions"
    Your Products look to be very high quality, have you tried this set-up fit a Metric Mechanic 4.0ltr Motor?
    ANSWER: Hey L. Thanks for the Compliment, we try to make it as complete as possible, with Quality built in! If the 4ltr Metric Mechanic motor uses a standard M30 Head then it should all bolt up, but clearance issues on engine components will need to be addressed! We have not tried to match it up with any specific engines or crate Motor that may be available. If your looking for Hp/Tq numbers we can not give you those as each engine combination is different based on CAM Specs, Head Porting, Compression ETC! We Also caution every one when comparing the Extrudabody ITB's to Weber or even other Throttle Body Companies, because throttle plate size is a POOR indicator of what you need or what a Throttle Body will do based on a given size throttle plate! All throttle body's and Carbs do not flow the same amount of AIR. Extrudabody ITB's were flowed by an independent flow tester against other's only to find they OUT FLOWED them 10cfm for a given size. It was not even close when comparing Extrudabody ITB's and a WEBER Carb even with the largest choke available! All this said the Extrudabody 45mm ITB's flow 293cfm, the Tapers flow 295cfm. So use actual CFM through the ITB/Carb to judge your engine's needs not throttle plate size! Hope this helps!
    Shipping is set at $30 in the lower 48 States, all other destinations require additional shipping charges.
    We ship world wide and ask if you buy from outside the USA you pay with Paypal with an approved address!
  2. EL NINJA
    EL NINJA Hay vida mas allá de las 8000 RPM , Rotary Power Miembro del Club
    15 Dic 2007
    Badajoz
    RX-8 HI Power
    Dan ganas de tenerlo de adorno en una vitrina, que bello es y lo bien que tiene que ir el coche con eso montado.
  3. Mario525
    Mario525 Forista Legendario Moderador Miembro del Club
    10 Abr 2004
    Argentina
    Serie 3 G20
    Muy interesante.... realmente para exposicion
