Video BYD Yangwan U9 , suspensión voladora DISus X: ya no importan los baches
No me extraña que Tesla ni amague con sacar el Roadster :stars:
Es hidráulica, y es fascinante como funciona. Permite lo de ir en 3 ruedas,
Salta hasta 6 metros de longitud.
Casi llama más la atención que los 1300 CV y 375 kms/h...
DISus-X
How it works:
Active Suspension Control: The DiSus-X system uses a combination of hydraulic and electronic controls to manage the vehicle's body dynamics. It can adjust damping, air suspension, and hydraulic responses in real time to control each wheel independently. This allows the car to compress and then rapidly extend its suspension, lifting all four wheels off the ground simultaneously.
Kinetic Energy Management: By quickly lowering the car's body and then rapidly extending the suspension, the system converts stored kinetic energy into a vertical thrust. This action is what makes the Yangwang U9 capable of jumping or hopping.
Precision and Speed: The system can react in milliseconds, allowing for precise control over the vehicle's movements. This precision is crucial for the jumping effect, where all four wheels need to lift off at the same time to achieve the desired height.
Functional Uses: Although the jumping feature might seem more like a party trick or a demonstration of technological capability, the underlying technology is designed for enhancing ride comfort, stability, and safety. It can adjust to road conditions, reduce body roll in corners, and even allow the car to drive on three wheels if a tire is damaged, showcasing the system's versatility.
dequincey
be em be e neun
5 Nov 2009
tengo difcultades en comprender si el video es real, IA, ...
en caso de ser real, es ademas conduccion autonoma ?
y controla el aterrizaje tras el salto ?
esta chulo, pero
joer que miedo !
marrero1970
DE TALLA GRANDE
18 Jun 2010
Cuando se ponga en modo turbo boost imagino que impedirá al conductor ( acojonado por ir montado en un canguro) frenar como si no hubiera un mañana.
Que hay pocos Collin Mcrae en el mundo.
Fantástico ...
El pequeño saltamontes .
Y sin embargo pisotea la bandera de" les persones" .
:descojon:
BOSE (sí, el fabricante de altavoces) sacó esa suspensión "voladora" creo que en los 80
Hubo un prototipo de Lexus LS, si, que saltaba un bordillo "a voluntad"
Este parece que lo detecta por sus sensores y lo hace espontáneamente.
esta chulo, pero
joer que miedo !
Si, si. lo han presentado en el CES.
marrero1970
DE TALLA GRANDE
18 Jun 2010
:descojon:
Ver el archivos adjunto 176535
Quiero ver eso en alguna carretera de las que coge @Jiro , pero por el carril derecho. Se me viene a la cabeza el tiroriroriorio de los coches de choque en las ferias de nuestros pueblos. Los empastes todos a tomar por culo
Jajaja, otra vez KIIT sale en el foro esta semana... al final los coches van a hacer cosas que veíamos de chavales en la ficción...
Yo casi que prefiero videos on board de macizas tomando alguna bebida y el chisposo conductor ordenando saltitos :LOL:
marrero1970
DE TALLA GRANDE
18 Jun 2010
Estoy perdiendo facultades . Ni caí en las macizas ....me hago mayor irremediablemente
Qué tontería de sistema, pudiendo ponerle alas y hacerlo droncoche.
En realidad no deja de ser una muestra circense de capacidad tecnológica; mostrar la velocidad y precisión de cálculo y de reacciones que se puede aplicar a la suspensión del aparato.
Bah, ahora va estar chupado ser fakir :cuniao:
Fakir Mirah Soumak bears the weight of a Citroen DS , complete with passengers, as it drives over his stomach in the Grande Place, Brussels, Belgium.
naviblue
U11M235iCB600F
4 Mar 2005
Prefiero aquellos tiempos en los que había solo un tonto en cada pueblo! Para cuando el water automático?
Pepe Pótamo
24 Abr 2003
Me meo solo de imaginar este sucedáneo de hierro amarillo en la carretera Palencia Santander, no pisa una rueda el asfalto desde Monzon hasta Aguilar…
Psché. Minucias. Los coches del dakar, van antes por un camino de cabras, que por el carri derecho de la A6 dirección Coruña, desde Benavente a Ponferrada. Hay lenguas de lava en Islandia más lisas que desde La Bañeza a Astorga por la A6.
Salta seis metros, evita socavones y pinchos. El vídeo del YangWang U9 que te dejará alucinando
El YangWang U9 es uno de los coches chinos más llamativos del mercado. Aunque no ha llegado a Europa por el momento, este supercoche eléctrico promete una velocidad punta cercana a los 400 km/h y tiene un sistema de suspensión Disus-X capaz de hacer que el coche salte. Sí, lo has leído bien. Y si pensabas que era puro marketing, la marca premium de BYD ha publicado un vídeo en el que su supercoche salta sobre todo tipo de obstáculos. Este vídeo tienes que verlo.
Aunque supera las dos toneladas, este supercoche eléctrico de 1.305 CV de potencia es capaz de saltar gracias a su suspensión activa Disus-X. Cada amortiguador dispone de una máquina eléctrica, capaz de ejercer una tremenda fuerza. Es suficiente para que el coche pueda levantarse del suelo. Es un sistema muy similar al increíble sistema Active Ride que pude probar hace unos meses en el Porsche Panamera de tercera generación.
La suspensión activa Disus-X es capaz de actuar en milisegundos
En el caso del YangWang U9, va montado en un coche eléctrico capaz de conducir por sí mismo, gracias a sus capacidades de conducción autónoma. Para demostrar su funcionamiento, BYD ha publicado un vídeo en el que el coche acelera hasta los 120 km/h sin conductor, y supera una serie de obstáculos por sí mismo, saltando sobre ellos. Si estás pensando en KITT y el Coche Fantástico, no vas en absoluto descaminado.
Entre los obstáculos hay un enorme socavón, una serie de pinchos y una zona recubierta de polvos de colores que el coche no debe tocar. El coche supera todos los obstáculos, saltando una distancia máxima de seis metros, a una altura de hasta 35 mm. Para hacerlo impulsa primero sus ruedas delanteras, para después hacerlo desde su tren trasero. El funcionamiento es hipnótico y es real, aunque el vídeo esté fuertemente editado y retocado para que parezca más impresionante.
En circunstancias reales la utilidad de la suspensión Disus-X no es saltar sobre obstáculos, aunque sea una poderosa arma para su departamento de marketing. Su función real es compensar y eliminar los balanceos y cabeceos de la carrocería, incrementando su estabilidad longitudinal y transversal, y por tanto, mejorando su paso por curva. Un buen lugar para demostrar esto sería el Nürburgring Nordschleife, ¿no creéis?
https://www.diariomotor.com/noticia/video-saltos-yangwang-u9/
Garvan90
19 Ago 2006
Aquí el sistema automático Jump en pruebas…
nos terminaremos extinguiendo, es inevitable
El Yangwang U9 es capaz de saltar y «bailar» gracias a su suspensión, pero también ha sido multado por ello
20/01/2025
El Yangwang U9 es uno de los coches chinos más sorprendentes que hemos visto hasta la fecha. Se trata de un superdeportivo eléctrico que supera los 1.000 CV de potencia y que promete unas prestaciones de escándalo. Todavía se ha confirmado si llegará al mercado europeo, pero las expectativas en su país natal son brutales. Allí ya están por las carreteras y mostrando algunas virtudes del vehículo, que pasan por las habilidades que consigue con su suspensión. Es capaz de saltar y «bailar», pero ya ha sido multado por ello.
Este modelo cuenta con la suspensión Disus X, un sistema hidráulico muy avanzado y totalmente independiente que tiene ventajas. El Yangwang U9 podría seguir circulando con tres ruedas y, además, tiene la capacidad de pasar por encima de obstáculos. Sacaron un vídeo recientemente en el que explicaban que podía saltar hasta seis metros de longitud circulando a 120 km/h gracias a un fuerte rebote en los cuatro amortiguadores. De esta forma podría pasar un socavón, un resalto o una barrera de pinchos.
Al contar con ese sistema de suspensión independiente, el U9 también tiene un modo baile en el que va subiendo y bajando rítmicamente. Lógicamente, está pensado para un uso lúdico mientras está estacionado y sin tráfico alrededor. Sin embargo, hay usuarios que no han dudado en probarlo en medio de la vía pública y molestando al resto de conductores. En el vídeo, aparece el modelo en escena paralizando el tráfico, con la posterior aparición de la policía. Fue sancionado con una multa ante las miradas de los viandantes, como era lógico.
Esa misma unidad del Yangwang U9 también fue vista intentando hacer el salto por encima de un badén en la vía pública. Parece que el sistema funciona, pero hay que mejorar la precisión, ya que en los vídeos termina saltando después de pasar el resalto. El caso es que la marca china está poniendo a disposición del cliente tecnologías novedosas que no siempre serán utilizadas de la manera correcta por algunos usuarios.
Pasa lo mismo con el Yangwang U8, el todoterreno que puede girar sobre su mismo eje y que también prometió un modo de conducción en el agua. La firma dejó claro que era solo para emergencias como inundaciones y grandes riadas, pues el coche necesitaría pasar por el taller para una revisión después de activarlo. Sin embargo, ya se ha visto a los primeros clientes haciendo la prueba de forma lúdica…
