Duda Check: cantidad de combustible. ¿ Puede que el tanque izquierdo indique mal?
Alejandro87
E38 y xantia pelado.
11 Dic 2010
He encontrado en la famosa web de las reparaciones del E38, la siguiente info. Por lo que yo entiendo, el 0 que nos marca a todos en el tanque izquierdo, al parecer es un error de medición del sensor de ese lado. Se comentaba que se debía a que la gasolina se desplazaba al tanque derecho, pero mirarlo y contarme qué conclusión sacais.
He borrado varias fotos porque no deja postear más de 15, pero ahí está el enlace si lo queréis ver entero.
http://www.meeknet.co.uk/e38/Sender/Index.htm
BMW E38 LHS FUEL SENDER REPLACEMENT
FUEL TANK INFORMATION
My E38 735i has had erratic fuel readings ever since I got it. It was very difficult to work out exactly what was going on as it seemed to just guess how much fuel there was in the tank. One minute I could have 1/4 of a tank, the next minute the amber warning lamp would come on.
E38's have (effectively) two fuel tanks, the tank assembly is like a pair of saddle bags that go across the transmission tunnel and lives under the rear seats.
There is only one fuel pump which is fitted to the RHS saddle bag. The pump sits in a bucket (called a surge tank) and has fuel delivered to it from both the left saddle bag and the right. This is done by using 'Suction jets' which are part of the fuel-return line. These work on the venturi principle where fuel whizzing past them cause a partial vacuum and this partial vacuum slurps fuel up. Here is a diagram of the E38 fuel tank showing where the Suction jets live and the general shape of the tank:
The E38 has two fuel senders, unlike the E32 which only has the one. Using the 'hidden secrets' of the OBC you can view the reading from both fuel senders (Test No 6). Here is the display that I was getting:
The first figure (0.0) is from the LHS sender, the next (13.5) is from the RHS sender, the last figure (13.5L) is the two figures added together and is the figure used for the instrument-panel fuel gauge. It is pretty obvious that the LHS sender is not giving any reading.
I've been watching Test No 6 for some time now, sometimes the LHS would give a reading, sometimes not. You can actually slosh the fuel from one saddle bag to the other using 'sport' turns. I could see that if the fuel was in the RHS 'bag' then I would get a good reading on the fuel gauge, after a good 'sport' turn to the right, the fuel would slosh into the LHS 'bag' and the fuel gauge would drop down (very slowly) as most of the fuel was in the LHS and that gauge still measured '0.0'.
So, time for a new LHS fuel sender, these are around £30 from BMW (I tried EuroCarParts but they wanted £33 and they didn't have one in stock even though the web site showed them to be £27 and in stock).
Here's what one looks like:
And a close-up look at the laser-trimmed resistors on a substrate:
Start by giving the fat 'O' ring a liberal amount of Silicone grease, you don't want the smell of petrol getting in the cabin. Here are the tools that you need (not many for this job!):
Lift out the rear seat. The seat-base just pulls up and disconnects a clip on either side, just about in the centre of each passenger seat area:
Under the seat you will find the loom that runs to the sender:
Carefully peel off the furry insulation:
And carefully pull out the big grommet being careful not to put too much pressure on the loom:
Here's the connector, I am poking the clip that needs to be pressed in as you pull out the plug:
The foam insulation that covers the sender needs to be cut along the perforation with a sharp knife:
Now remove the domed cover over the sender using a Pozi-drive screwdriver:
Once the cover is removed use a paint brush to clean the area around and under the sender plate. I didn't do this and wished I had once I got the sender off!
It is important at this stage that all the doors are opened, otherwise a build-up of petrol fumes could be hazardous
The sender can be removed using an adjustable pipe-wrench as shown, just a quarter of a turn does it:
The fuel sender wiggles out of the hole, do not apply any force as this wiggles out easily. If the area was clean, fitting the new sender is straight-forward, however, I spent a little time trying to keep dirt getting in the tank. For anti-explosion reasons I didn't take any pictures with the sender removed.
Here's the new sender going in:
Cover back on:
Insulation back on, connector back in and refit the big grommet, this pushes in as far as the first shoulder:
Furry insulation sticks back on:
The rear seat can now be fitted in place, push in the back of the bolster first from one side and guide it around the seat-belt trunion:
Do this one side at a time from the outside of the car, go back to the first side and push the bolster as far back as possible, repeat for the other side and then press down in the middle of each seat area and the clips should click back into place. Make sure all seat belts are still available!
Right, ignition ON and try Test No 2:
That's better!
If you want to try and repair the sender rather than replace it (quite easy) then the next section is for you!
I decided to buy a new sender because I hate working with the fuel tank, just too much chance of contamination and explosions...but....as long as you cleaned the sender area before removing the sender then it is possible to remove it and then cover the hole with gaffer tape while you fiddle with the sender.
Right, here are the readings you should get from the sender:
So, connect a DVM to the contact points on the sender flange and wiggle the float around. My sender was good unless the float was pulled in one direction. The picture shows the contact points , float DOWN, float UP, float pulled to the side:
That was the reason for the erratic readings, the sender would work sometimes but not others. We can perform the usual 'contact bend' on the wiper which puts a bit more pressure on it and moves it to a new bit of track. There is no need to clean the wiper area.....petrol is the best contact cleaner I know of!
To add pressure first pull the float 'coat hanger' from the two clips:
And pull the wiper arm away from the body so that access can be given to the wiper arm contact. Use a pair of long-nosed pliers to give it a bit of a tweak downwards and add a slight kink, this will move the wiper to a new area and add a bit of pressure:
Reassemble the sender a give it a good test with the DVM....all OK now!
All done...time for a cup of tea!
ahora no tengo ni puñetera gana de leerme ese ladrillo pero en llano y recta al cabo de un rato con el motor en marcha el lado izquierdo se vacía siempre que haya menos de medio tanque lleno. Comprobado en infinidad de ocasiones por mi.
Alejandro87
11 Dic 2010
Ah no sabía ese detalle de que tiene que tener menos de medio tanque para que se vacie.
Yo salvo viajes largo suelo echar 20 euros, y siempre lo vi en 0.0.
La bomba chupa desde el lado derecho y el sistema lleva siempre la gasolina a ese lado aunque en curvas fuertes a derechas se puede pasar parte al otro lado. Pero evidentemente cuando llevas más de medio tanque lo habitual en recta es que el lado derecho lleve 40 litros y el izquierdo el resto (hablo de los de 85 litros que tienen 40 en cada lado (los 5 adicionales no los marcan los aforadores).
