Alguien me podria facilitar este esquema? ya que instale el navi CCC y al meter la maquina el otro dia me dijeron que el ventilador no funcionaba, asi que...igual me equivoque a la hora de conectar los pines...un saludo y gracias.
CCC Fan If you are lucky, you will find one of the remaining business-to-pro retrofit fan harnesses out there. I was able to get one from a salvage yard who chopped-out the entire radio connector including the fan harness and pins. If you have to make one, here’s how it hooks up. The little fan on the back of the CCC connects via small harness from connector x14055 (3-pins) to connector x13813 (12-pin connector, left (closest to center) port on back of CCC) and powers the fan. • Connect Pin #1 (RT/SW – Volts(+)) from fan to Pin #1 of connector x13813 at CCC • Connect Pin #2 (WS – Diag) from fan to Pin #11 of connector x13813 at CCC • Connect Pin #3 (BR/SW – Volts(-)) from fan to Pin #5 of connector x13813 at CCC
Aqui tienes el enlace del documento completo: http://home.comcast.net/~Booster/idrive/E90_idrive_retrofit.pdf
